asa 5505 dsl / mtu based ssl problem
julian
Hi everyone,
We moved our office to a different location (including our dsl conncetion). We also updated our asa from 8.0.3 to 8.0.4.
Since then, I'm having trouble opening the webportal from customers having a dedicated line.
I'm getting the certificate, can confirm it but the page won't load. When setting down the MTU size on the client everything works fine. Using a DSL or UMTS Line also works like a charm.
î've set:
mtu inside 1500
mtu outside 1492
sysopt connection tcpmss 1452
crypto ipsec df-bit clear-df inside
crypto ipsec df-bit clear-df outside
i also attached an packet trace showing tcp checksum errors while loading the page.
Anybody has an idea?
andrew.prince
Level 10
Level 10
Julian,
You are contributing to the issue with "sysopt connection tcpmss 1452"
Change it back to the default "1380" or lower - I suggest lower I use "1300"
And the commands
AFAIK they do not apply to the SSL connections
