12-27-2011 12:20 PM - edited 03-11-2019 03:07 PM
Hi everyone, I was hoping that I could get some help for an issue we are having and i'm about to rip my hair out.
Out setup consists of two locations, one ASA 5505 (security license) \ at our main site and the other is a remote site with a cisco 1921 acting as the edge device.
The ASA 5505 acting as an edge device at our main site. From our ISP, two vlans come into the ASA (one for public internet traffic, one for the remote site, set up as a VC). The main site and the remote site are both separate LAN subnets, with a third subnet acting as a serial between the two locations.
At our main site, the ASA can access the public internet just fine, it can also ping to the gateway address on the 1921 (for their lan10.34.60.245: below) and receive a reply. This tells me that the Route commands are all set up fine as well as NAT translations to the public internet. The idea in this case is to have the remote site send all data back to the ASA5505 (think of the VC as one long cable connecting the two) and the ASA will handle the actual public internet connectivity as well as allowing connectivity to their private LAN (to access servers). I.E both LANs need to be able to talk to eachother.
the remote site as we stand now is able to ping the other end of the serial IP (10.1.1.1) but that's it. It can't ping the main site LAN gateway and it can't ping anything on the public internet.
I've narrowed the problem down to something on this ASA that isn't allowing these private LANs to communicate however I have no idea what it is. Any help would be very much appreciated.
here is some info to help
REMOTE SITE LAN =
10.34.60.0/24 (gateway is 10.34.60.245)
Serial IP on the VC: 10.1.1.0/30
ASA sh run:
interface Vlan1
nameif inside
security-level 100
ip address 10.25.102.245 255.255.255.0
interface Vlan783
nameif Internet
security-level 0
ip address X.X.X.X 255.255.255.252
interface Vlan789
nameif remotesite
security-level 100
ip address 10.1.1.1 255.255.255.252
interface Ethernet0/0
switchport trunk allowed vlan 783,789
switchport mode trunk
speed 10
duplex full
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name workgroup
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list ingress extended deny ip 0.0.0.0 0.255.255.255 any
access-list ingress extended deny ip 127.0.0.0 255.255.255.0 any
access-list ingress extended deny ip 169.254.0.0 255.255.0.0 any
access-list ingress extended deny ip 172.16.0.0 255.255.240.0 any
access-list ingress extended deny ip 192.0.2.0 255.255.255.0 any
access-list ingress extended deny ip 192.168.0.0 255.255.0.0 any
access-list ingress extended deny ip 224.0.0.0 255.255.255.224 any
access-list ingress extended permit ip any any
access-list inside_nat0_outbound extended permit ip 10.25.102.0 255.255.255.0 10.34.60.0 255.255.255.0
access-list egress extended permit ip any any
access-list remotesite extended permit ip any any
pager lines 24
logging buffer-size 40960
mtu inside 1500
mtu Internet 1500
mtu remotesite1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any Internet
icmp permit any remotesite
no asdm history enable
arp timeout 14400
global (inside) 11 interface
global (Internet) 1 interface
global (remotesite) 10 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 10.25.102.0 255.255.255.0
nat (inside) 10 0.0.0.0 0.0.0.0
nat (remotesite) 1 10.34.60.0 255.255.255.0
nat (remotesite) 11 0.0.0.0 0.0.0.0
static (inside,remotesite) 10.25.102.100 10.25.102.100 netmask 255.255.255.255
static (inside,remotesite) 10.1.1.100 10.1.1.100 netmask 255.255.255.255
access-group egress in interface inside
access-group ingress in interface Internet
access-group remotesite in interface remotesite
route Internet 0.0.0.0 0.0.0.0 204.186.244.193 1
route inside 10.25.102.0 255.255.255.0 10.25.102.145 1
route remotesite10.34.60.0 255.255.255.0 10.1.1.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
ssh timeout 5
console timeout 0
12-27-2011 01:08 PM
Hello John,
Can you provide the following output :
-packet-tracer input remote site tcp 10.34.60.15 1025 10.25.102.15 80
Julio
12-27-2011 01:23 PM
Sure, here it is
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 10.25.102.0 255.255.255.0 inside
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: NAT-EXEMPT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype:
Result: DROP
Config:
match ip remotesite 10.34.60.0 255.255.255.0 inside any
dynamic translation to pool 1 (No matching global)
translate_hits = 1, untranslate_hits = 0
Result:
input-interface: remotesite
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
12-27-2011 01:52 PM
Hello John,
Thanks for the information. We are almost there
Please add the following and let me know the result
No nat (remotesite) 1 10.34.60.0 255.255.255.0
Then try it and if it does not work, use the packet tracer one more time and let me know the result.
Do please rate helpful posts
Julio
12-27-2011 01:55 PM
I'll give it a shot tomorrow and report what I find, man I hope this fixes it. Spent too many hours trying to figure it out.....
EDIT: I'm feeling confident about this, tried the packet-tracer command again and got the following:
Phase: 12
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 10026, packet dispatched to next module
Result:
input-status: up
output-status: up
Action: allow
Won't know tomorrow until i actually deploy it, but so far it looks good. I'll let you know what happens.
and also, thank you very much
12-27-2011 01:58 PM
Hello John,
Sure, let me know.
The packet tracer show us that the packets comming from the Remote site are not maching any global statement, so that should do it.
Edit: That is great! Seems that its gonna work.
Julio
12-29-2011 08:55 AM
Looks like I'm still having issues.
the ASA can't ping the router's interface IP of 10.1.1.2 over the VC anymore, previously it could
Here is the packet tracer command, showing it is getting dropped
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group remotesitein interface remotesite
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype:
Result: DROP
Config:
nat (remotesite) 5 10.1.1.0 255.255.255.252
match ip remotesite 10.1.1.0 255.255.255.252 inside any
Result:
input-status: up
Here are the NAT and global commands:
nat (remotesite) 1 10.1.1.0 255.255.255.252
12-29-2011 09:19 AM
Hello Jonh,
Are those the only nat statements we have in there:
because packet tracer shows this one:
And the nats you provide are the following:
I do not see Nat (remotesite) 5 in there.
From the ASA we have not change something that could affect that the ASA could ping the other site, so seems like something else change on the behavior of the router because it is not allowing pings anymore.
Please take out the following statements:
no nat (remotesite) 1 10.1.1.0 255.255.255.252
no nat (remotesite) 1 10.34.60.0 255.255.255.0
Julio
12-29-2011 09:40 AM
nat (remotesite) 5 10.1.1.0 255.255.255.252 was set up when I was troublshooting and has since been removed.
so at this point, I put in the following commands:
Obviously, now the packettracer command is showing drops on both the networks (serial and other LAN)
Phase: 5
Type: NAT
Subtype:
Result: DROP
Config:
Phase: 6
Type: NAT
Subtype:
Result: DROP
Config:
Here are the current NAT settings I have enabled.
I tried taking removing the no nat commands for the 10. networks and thought that maybe I could make a sweeping no nat command of just 10.0.0.0 255.0.0.0, but I got the error "ERROR: nat element not found"
I checked with someone on site and the router is on and working, so its not that. Also in the routing table, 10.1.1.0 shows up as directly connected, no there has to be a link there at the moment.
12-29-2011 09:54 AM
Hello John,
I want you to remove the nat (remotesite) 1 as I asked on previous post
The ASA is directly connected to the router so they should be able to ping each other,
capture test interface remotesite match icmp x.x.x.x ( router other site) x.x.x.x (this asa remote site interface)
Now try to ping from the router to the asa
Please provide show capture test, packet tracer again and show nat and global
12-29-2011 11:07 AM
Sorry, I misunderstood you.
Anywho,
I reinstated the no nat commands and whenever I try to do that
capture test interface remotesite match icmp x.x.x.x ( router other site) x.x.x.x (this asa remote site interface) command, it reports with error :"ERROR: ERROR: IP address,mask doesn't pair", which doesn't made sense to me at all
I'm beginning to think that this is an issue with the router opposite the ASA. I'm about 99% sure that the config changes I've made in the past few days haven't altered anything that would have denied access to that router. the only thing I can think at this point is that the router lost the link, or for some reason lost its config. This would be unfortunate since its about 20 miles away from me right now.
I'm including the sh run here to see if there are any issues that I may be missing that wouldn't allow the ping requests to 10.1.1.2, but it looks like i'll be taking a drive
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan783
nameif Internet
security-level 0
ip address 204.186.244.194 255.255.255.252
interface Vlan789
nameif remotesite
security-level 100
speed 10
duplex full
interface Ethernet0/1
banner motd -----------------------------------------------------------------------------------------------------------
boot system disk0:/asa822-k8.bin
ftp mode passive
pager lines 24
mtu inside 1500
mtu Internet 1500
mtu remotesite1500
no failover
arp timeout 14400
route remotesite 10.34.60.0 255.255.255.0 10.1.1.2 1
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
12-29-2011 11:15 AM
Hello John,
That is correct, and you are pinging from the ASA right?
That should work.. Regards,
Julio
12-29-2011 12:11 PM
yeah, i was pinging from the ASA to 10.1.1.2 the entire time.
I'll be going out tomorrow to check it out and fix the issue, I'll report back as to how it went.
Thank you very much for your help jcarvaja, I really appreciate it
12-29-2011 12:28 PM
Hello John,
Sure let me know.
My pleasure!
Julio
01-03-2012 07:12 AM
Still isn't working. the remote site router can ping the IP of the ASA interface at 10.1.1.1 with no problem. Whenever it tries to ping the LAN of the ASA or the public internet, it fails.
The ASA can ping botht the serial IP of 10.1.1.2 and the LAN of the router with no problem.
