05-04-2013 09:51 AM - edited 03-11-2019 06:38 PM
I'm currently facing a problem with a ASA5505 and It's drivin me nuts !!!
I thing I've set it up from factory defaults...
From the CLI, I can ping an the outside interface, the GW and an outside IP (ex:8.8.8.8).
So I believe that there's no connectivity issue and the configuration is correct.
However, for a reason that I don't know, users can't have access to web pages.
The product license allow me to have 50 host connected. Currently I've only got one host connected...
When I enable syslog, I can see the following messages :
Deny traffic for protocol 17 src inside: 192.168.1.20/64429 dot ouside:8.8.4.4/53, licensed host limit of 0 exceeded.
Where this limitation can come from ??
Have you any Idea ??
Solved! Go to Solution.
05-04-2013 11:22 AM
sh ver
Cisco Adaptive Security Appliance Software Version 8.4(6)
Device Manager Version 7.1(2)102
Compiled on Fri 26-Apr-13 09:00 by builders
System image file is "disk0:/asa846-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 15 mins 12 secs
Hardware: ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW016 @ 0xfff00000, 2048KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.06
Number of accelerators: 1
0: Int: Internal-Data0/0 : address is c84c.75e3.d013, irq 11
1: Ext: Ethernet0/0 : address is c84c.75e3.d00b, irq 255
2: Ext: Ethernet0/1 : address is c84c.75e3.d00c, irq 255
3: Ext: Ethernet0/2 : address is c84c.75e3.d00d, irq 255
4: Ext: Ethernet0/3 : address is c84c.75e3.d00e, irq 255
5: Ext: Ethernet0/4 : address is c84c.75e3.d00f, irq 255
6: Ext: Ethernet0/5 : address is c84c.75e3.d010, irq 255
7: Ext: Ethernet0/6 : address is c84c.75e3.d011, irq 255
8: Ext: Ethernet0/7 : address is c84c.75e3.d012, irq 255
9: Int: Internal-Data0/1 : address is 0000.0003.0002, irq 255
10: Int: Not used : irq 255
11: Int: Not used : irq 255
Licensed features for this platform:
Maximum Physical Interfaces : 8 perpetual
VLANs : 3 DMZ Restricted
Dual ISPs : Disabled perpetual
VLAN Trunk Ports : 0 perpetual
Inside Hosts : 50 perpetual
Failover : Disabled perpetual
VPN-DES : Enabled perpetual
VPN-3DES-AES : Enabled perpetual
AnyConnect Premium Peers : 2 perpetual
AnyConnect Essentials : Disabled perpetual
Other VPN Peers : 10 perpetual
Total VPN Peers : 12 perpetual
Shared License : Disabled perpetual
AnyConnect for Mobile : Disabled perpetual
AnyConnect for Cisco VPN Phone : Disabled perpetual
Advanced Endpoint Assessment : Disabled perpetual
UC Phone Proxy Sessions : 2 perpetual
Total UC Proxy Sessions : 2 perpetual
Botnet Traffic Filter : Disabled perpetual
Intercompany Media Engine : Disabled perpetual
This platform has a Base license.
Serial Number: JMX1425421C
Running Permanent Activation Key: 0x7335c65a 0x3ce19aca 0x60734d74 0x94885c3c 0x83122f90
Configuration register is 0x1
Configuration last modified by cisco at 08:55:49.299 UTC Sat May 4 2013
05-04-2013 11:22 AM
debug:
6|May 04 2013|09:00:29|725007|192.168.10.20|49370|||SSL session with client inside:192.168.10.20/49370 terminated.
6|May 04 2013|09:00:29|106015|192.168.10.20|49370|192.168.10.1|443|Deny TCP (no connection) from 192.168.10.20/49370 to 192.168.10.1/443 flags FIN ACK on interface inside
6|May 04 2013|09:00:29|302014|192.168.10.20|49370|192.168.10.1|443|Teardown TCP connection 268 for inside:192.168.10.20/49370 to identity:192.168.10.1/443 duration 0:00:00 bytes 726 TCP Reset-O
6|May 04 2013|09:00:29|605005|192.168.10.20|49370|192.168.10.1|https|Login permitted from 192.168.10.20/49370 to inside:192.168.10.1/https for user "cisco"
6|May 04 2013|09:00:29|725002|192.168.10.20|49370|||Device completed SSL handshake with client inside:192.168.10.20/49370
6|May 04 2013|09:00:29|725001|192.168.10.20|49370|||Starting SSL handshake with client inside:192.168.10.20/49370 for TLSv1 session.
6|May 04 2013|09:00:29|302013|192.168.10.20|49370|192.168.10.1|443|Built inbound TCP connection 268 for inside:192.168.10.20/49370 (192.168.10.20/49370) to identity:192.168.10.1/443 (192.168.10.1/443)
6|May 04 2013|09:00:27|305012|192.168.10.20|55115|192.168.1.66|55115|Teardown dynamic UDP translation from inside:192.168.10.20/55115 to outside:192.168.1.66/55115 duration 0:00:38
6|May 04 2013|09:00:27|305012|192.168.10.20|55558|192.168.1.66|55558|Teardown dynamic UDP translation from inside:192.168.10.20/55558 to outside:192.168.1.66/55558 duration 0:00:38
4|May 04 2013|09:00:25|450001|192.168.10.20|55726|192.168.1.1|53|Deny traffic for protocol 17 src inside:192.168.10.20/55726 dst outside:192.168.1.1/53, licensed host limit of 0 exceeded.
6|May 04 2013|09:00:25|305011|192.168.10.20|55726|192.168.1.66|55726|Built dynamic UDP translation from inside:192.168.10.20/55726 to outside:192.168.1.66/55726
6|May 04 2013|09:00:23|305012|192.168.10.20|51189|192.168.1.66|51189|Teardown dynamic UDP translation from inside:192.168.10.20/51189 to outside:192.168.1.66/51189 duration 0:00:38
6|May 04 2013|09:00:16|302016|0.0.0.0|68|255.255.255.255|67|Teardown UDP connection 222 for outside:0.0.0.0/68 to identity:255.255.255.255/67 duration 0:02:34 bytes 2700
6|May 04 2013|09:00:14|302016|192.168.1.1|67|255.255.255.255|68|Teardown UDP connection 223 for outside:192.168.1.1/67 to identity:255.255.255.255/68 duration 0:02:32 bytes 1096
4|May 04 2013|09:00:13|450001|192.168.10.20|54981|192.168.1.1|53|Deny traffic for protocol 17 src inside:192.168.10.20/54981 dst outside:192.168.1.1/53, licensed host limit of 0 exceeded.
6|May 04 2013|09:00:13|302015|192.168.10.1|67|192.168.10.20|68|Built outbound UDP connection 262 for inside:192.168.10.20/68 (192.168.10.20/68) to identity:192.168.10.1/67 (192.168.10.1/67)
6|May 04 2013|09:00:13|302015|192.168.10.20|68|255.255.255.255|67|Built inbound UDP connection 261 for inside:192.168.10.20/68 (192.168.10.20/68) to identity:255.255.255.255/67 (255.255.255.255/67)
6|May 04 2013|09:00:05|305011|192.168.10.20|54981|192.168.1.66|54981|Built dynamic UDP translation from inside:192.168.10.20/54981 to outside:192.168.1.66/54981
4|May 04 2013|09:00:01|450001|192.168.10.20|51344|192.168.1.1|53|Deny traffic for protocol 17 src inside:192.168.10.20/51344 dst outside:192.168.1.1/53, licensed host limit of 0 exceeded.
6|May 04 2013|09:00:01|305011|192.168.10.20|51344|192.168.1.66|51344|Built dynamic UDP translation from inside:192.168.10.20/51344 to outside:192.168.1.66/51344
6|May 04 2013|08:59:59|606003|192.168.10.20||||ASDM logging session number 0 from 192.168.10.20 started
6|May 04 2013|08:59:59|605005|192.168.10.20|49369|192.168.10.1|https|Login permitted from 192.168.10.20/49369 to inside:192.168.10.1/https for user "cisco"
6|May 04 2013|08:59:59|725002|192.168.10.20|49369|||Device completed SSL handshake with client inside:192.168.10.20/49369
6|May 04 2013|08:59:59|725001|192.168.10.20|49369|||Starting SSL handshake with client inside:192.168.10.20/49369 for TLSv1 session.
6|May 04 2013|08:59:59|302013|192.168.10.20|49369|192.168.10.1|443|Built inbound TCP connection 251 for inside:192.168.10.20/49369 (192.168.10.20/49369) to identity:192.168.10.1/443 (192.168.10.1/443)
6|May 04 2013|08:59:59|725007|192.168.10.20|49368|||SSL session with client inside:192.168.10.20/49368 terminated.
6|May 04 2013|08:59:59|106015|192.168.10.20|49368|192.168.10.1|443|Deny TCP (no connection) from 192.168.10.20/49368 to 192.168.10.1/443 flags FIN ACK on interface inside
6|May 04 2013|08:59:59|302014|192.168.10.20|49368|192.168.10.1|443|Teardown TCP connection 250 for inside:192.168.10.20/49368 to identity:192.168.10.1/443 duration 0:00:00 bytes 699 TCP Reset-O
5|May 04 2013|08:59:59|111010|||||User 'cisco', running 'N/A' from IP 192.168.10.20, executed 'logging enable'
5|May 04 2013|08:59:59|111008|||||User 'cisco' executed the 'logging enable' command.
||||||||-- Syslog Connection Started --
