ASA 5505 monitoring problem
blore560025
Hi All,
I enabled snmp config  ASA 5505 with Version 7.2(4), the NMS/reporting system can give graphs for CPU & Memory usages. But I can't see any elements about physical interfaces. Any help on this is highly appriciated.
Blore
brquinn
Blore,
The ASA will report interface statistics for each physical interface and vlan interface separately. If you perform a walk on the ifDescr attributes, you will see that the physical interfaces are separate from the named vlan interfaces. Make sure that your SNMP tool is configured to monitor the correct OID to correlate with the appropriate physical interface.
C:\Documents and Settings\Administrator>snmpwalk -v 2c -c public -On 192.168.2.1 ifDescr
.1.3.6.1.2.1.2.2.1.2.2 = STRING: Adaptive Security Appliance 'Internal-Data0/0'interface
.1.3.6.1.2.1.2.2.1.2.3 = STRING: Adaptive Security Appliance 'Ethernet0/0' interface
.1.3.6.1.2.1.2.2.1.2.4 = STRING: Adaptive Security Appliance 'Ethernet0/1' interface
.1.3.6.1.2.1.2.2.1.2.5 = STRING: Adaptive Security Appliance 'Ethernet0/2' interface
.1.3.6.1.2.1.2.2.1.2.6 = STRING: Adaptive Security Appliance 'Ethernet0/3' interface
.1.3.6.1.2.1.2.2.1.2.7 = STRING: Adaptive Security Appliance 'Ethernet0/4' interface
.1.3.6.1.2.1.2.2.1.2.8 = STRING: Adaptive Security Appliance 'Ethernet0/5' interface
.1.3.6.1.2.1.2.2.1.2.9 = STRING: Adaptive Security Appliance 'Ethernet0/6' interface
.1.3.6.1.2.1.2.2.1.2.10 = STRING: Adaptive Security Appliance 'Ethernet0/7' interface
.1.3.6.1.2.1.2.2.1.2.11 = STRING: Adaptive Security Appliance 'Internal-Data0/1' interface
.1.3.6.1.2.1.2.2.1.2.12 = STRING: Adaptive Security Appliance '_internal_loopback' interface
.1.3.6.1.2.1.2.2.1.2.13 = STRING: Adaptive Security Appliance 'Virtual254' interface
.1.3.6.1.2.1.2.2.1.2.14 = STRING: Adaptive Security Appliance 'inside' interface
.1.3.6.1.2.1.2.2.1.2.15 = STRING: Adaptive Security Appliance 'outside' interface
.1.3.6.1.2.1.2.2.1.2.16 = STRING: Adaptive Security Appliance 'Vlan300' interface
.1.3.6.1.2.1.2.2.1.2.17 = STRING: Adaptive Security Appliance 'labnet' interface
.1.3.6.1.2.1.2.2.1.2.18 = STRING: Adaptive Security Appliance 'fakeif' interface
I hope this helps.
Brendan
