ASA 5505 PPPOE traffic statistic doubled between inside / outside
Julien Potier
Hi guys,
I've an ASA 5505  connecting to a vdsl modem. The ASA is doing the PPPoE encapsulation. I've noticed the traffic amount on the outside interface is always twice the bandwidth it receives on its inside interface. I can't believe the PPP encapsulation is taking that much. Only two interfaces (inside and outside)
MTU on the outside is the same as the inside.
Any thoughts ?
Cheers,
7 Replies 7
jocamare
Level 4
Level 4
Of how much bandwidth are we talking about?
Is the ASA dropping packets? Many packets?
julomban
Level 3
Level 3
Hi Julien,
This is not normal and you need to check if you have a "permit ip any any" rule or anything that is allowing inbound traffic.
Could you please share the configuration of your ASA?
Juan Lombana
Julien Potier
Well it does it regardless the amount of traffic going through the appliance (from few kbps to 10-20Mbps). I initially noticed it while using a P2P application. There is always a lot of udp denied packets but difficult to say how much. I would be surprised if it's the only reason. Secondly I've since tried with a normale http transfer of a large file. It does the same, no packet deny. So for example traffic on inside is 10656 Kbps traffic on outside is 21223kbps. Xlate shows 22 connections, Conn shows 29. Firewall is running 8.2.5
outside access list is the implicit deny all
Nothing to exciting in the config. I use the asa for home broadband and testing/training
ASA Version 8.2(5)
hostname Fortknox2
domain-name ****.****.org
enable password ****** encrypted
passwd ******* encrypted
names
name 192.168.0.250 Kurp
name 192.168.0.30 Laptop-192.168.0.30
name 192.168.0.253 AAA-Authentication-proxy
name 192.168.0.26 Hilda_0022.fb55.8de0
name 192.168.0.16 Chris_b482.fe5d.ef62
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
description Inside
interface Ethernet0/2
description Outside
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group pppoe-dsl-grp
ip address pppoe setroute
regex mail-uri "^\/mail\/"
regex mail "mail\.google\.com"
regex morePorn "porn\.[a-zA-Z]*\.com"
regex facebook "^[w]{3}\.faceb[o]{1,}k\.com"
regex porn "porn\.com"
time-range in-hours
periodic weekdays 17:00 to 23:59
periodic weekdays 0:00 to 1:00
periodic weekend 0:00 to 23:59
boot system disk0:/asa825-k8.bin
ftp mode passive
clock timezone GMT/BST 0
clock summer-time GMT/BST recurring last Sun Mar 1:00 last Sun Oct 2:00
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 208.67.222.222
name-server 208.67.220.220
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network Global-inside
description Global Dynamic Hide NAT inside to outside
object-group network Kurp-PC
object-group network Inside_Net-192.168.0.0
object-group service Bittorent udp
port-object range 1024 65535
object-group service DM_INLINE_TCP_1 tcp
port-object eq ftp
port-object eq www
port-object eq https
object-group service DM_INLINE_TCP_2 tcp
port-object eq 8880
port-object eq 9443
port-object eq www
object-group service DM_INLINE_TCP_3 tcp
port-object eq www
object-group service DM_INLINE_TCP_4 tcp
port-object eq www
access-list inside_access_in extended permit udp any any eq domain
access-list inside_access_in extended permit tcp host Laptop-192.168.0.30 host AAA-Authentication-proxy object-group DM_INLINE_TCP_2 inactive
access-list inside_access_in extended deny tcp host Laptop-192.168.0.30 any object-group DM_INLINE_TCP_1 inactive
access-list inside_access_in extended permit icmp any any
access-list inside_access_in extended permit udp any any eq ntp
access-list inside_access_in remark Auto all
access-list inside_access_in extended permit ip any any
access-list AAA-network-auth extended permit tcp host Kurp any object-group DM_INLINE_TCP_4 inactive
access-list AAA-network-auth extended permit tcp host Laptop-192.168.0.30 any object-group DM_INLINE_TCP_3 inactive
access-list AAA-network-auth extended deny ip any any inactive
pager lines 24
logging enable
logging list No_Logging message 305011
logging list No_Logging message 302014-302016
logging list No_Logging message 302013
logging list No_Logging message 106014
logging asdm-buffer-size 256
logging asdm notifications
logging mail critical
logging message 106014 level informational
mtu inside 1492
mtu outside 1492
ip verify reverse-path interface inside
ip verify reverse-path interface outside
no failover
icmp unreachable rate-limit 10 burst-size 3
icmp permit any inside
icmp permit host ***.***.52.1 outside
icmp deny any outside
asdm image disk0:/asdm-649-103.bin
asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 192.168.0.0 255.255.255.0
access-group inside_access_in in interface inside
timeout xlate 0:30:00
timeout conn 0:30:00 half-closed 0:05:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:10:00 absolute uauth 0:03:00 inactivity
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
mac-list aaa_mac_exempt permit 90e6.ba15.5718 ffff.ffff.ffff
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
aaa authentication match AAA-network-auth inside LOCAL
aaa authentication telnet console LOCAL
aaa authentication http console LOCAL
aaa authorization command LOCAL
aaa proxy-limit 64
aaa mac-exempt match aaa_mac_exempt
aaa authentication secure-http-client
aaa local authentication attempts max-fail 16
aaa authentication listener http inside port 8888 redirect
aaa authentication listener https inside port 9443 redirect
http server enable
http 192.168.0.0 255.255.255.0 inside
http **.***.52.1 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
virtual http AAA-Authentication-proxy
virtual telnet AAA-Authentication-proxy
auth-prompt prompt !!! Authorized personel only !!!!
auth-prompt accept Ahh Freeman !
auth-prompt reject Degage connard !!!
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint KURP-CA-Trustpoint
enrollment url http://192.168.0.252:80/CertSrv/mscep/certnew
crl configure
telnet timeout 5
ssh 192.168.0.0 255.255.255.0 inside
ssh **.***.52.1 255.255.255.255 outside
ssh timeout 60
console timeout 10
vpdn group pppoe-dsl-grp request dialout pppoe
vpdn group pppoe-dsl-grp localname ***@***.com
vpdn group pppoe-dsl-grp ppp authentication chap
vpdn username ***@***.com password *****
dhcpd ping_timeout 100
dhcpd address 192.168.0.10-192.168.0.200 inside
dhcpd dns 213.120.234.66 213.120.234.74 interface inside
dhcpd lease 86400 interface inside
dhcpd ping_timeout 100 interface inside
dhcpd enable inside
priority-queue outside
no threat-detection rate scanning-threat rate-interval 3600 average-rate 4 burst-rate 8
threat-detection rate scanning-threat rate-interval 600 average-rate 5 burst-rate 10
threat-detection rate scanning-threat rate-interval 3600 average-rate 25 burst-rate 50
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics
threat-detection statistics host number-of-rate 3
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
dynamic-filter enable
dynamic-filter drop blacklist
dynamic-filter whitelist
name stream2watch.me
address 88.80.13.254 255.255.255.255
name i.sportlemon.tv
name www.sportlemon.tv
name sportlemon.tv
ntp server 64.90.182.55 source outside prefer
ntp server 64.113.32.5 source outside
ntp server 131.107.13.100 source outside prefer
ssl server-version tlsv1-only
webvpn
port 9443
enable inside
enable outside
anyconnect-essentials
tunnel-group-list enable
username *** password *** encrypted privilege 0
username kurp password *** encrypted privilege 15
tunnel-group DefaultRAGroup webvpn-attributes
group-alias DefaultRA enable
tunnel-group DefaultWEBVPNGroup webvpn-attributes
group-alias DefaultWebVPN enable
class-map type regex match-any productivity-sites
match regex facebook
class-map type regex match-any porn-sites
match regex porn
match regex morePorn
class-map type inspect http match-all HTTP-URI-inspect
match request args regex mail
match not request uri regex mail-uri
class-map type inspect http match-all asdm_medium_security_methods
match not request method head
match not request method post
match not request method get
class-map type inspect http match-any HTTP-URL-inspect
match request args regex class porn-sites
match request args regex class productivity-sites
class-map AIC-inspect-ALL
match default-inspection-traffic
policy-map type inspect im IM-logging
parameters
match protocol msn-im yahoo-im
  log
policy-map type inspect http Http-inspect-medium
parameters
  protocol-violation action drop-connection log
class asdm_medium_security_methods
  drop-connection
policy-map type inspect http HTTP-inspect-pmap
parameters
class HTTP-URL-inspect
  drop-connection log
class HTTP-URI-inspect
  drop-connection
policy-map global-policy
class AIC-inspect-ALL
  inspect dns dynamic-filter-snoop
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect icmp
  inspect icmp error
  inspect mgcp
  inspect pptp
  inspect rtsp
  inspect sip
  inspect skinny
  inspect snmp
  inspect tftp
  inspect ipsec-pass-thru
service-policy global-policy global
smtp-server 173.194.67.108 173.194.64.109
privilege cmd level 3 mode exec command perfmon
privilege cmd level 5 mode exec command dir
privilege cmd level 3 mode exec command ping
privilege cmd level 3 mode exec command who
privilege cmd level 3 mode exec command logging
privilege cmd level 3 mode exec command failover
privilege cmd level 3 mode exec command vpn-sessiondb
privilege cmd level 3 mode exec command packet-tracer
privilege cmd level 5 mode exec command export
privilege show level 5 mode exec command import
privilege show level 5 mode exec command running-config
privilege show level 3 mode exec command reload
privilege show level 3 mode exec command mode
privilege show level 3 mode exec command firewall
privilege show level 3 mode exec command asp
privilege show level 3 mode exec command cpu
privilege show level 3 mode exec command interface
privilege show level 3 mode exec command clock
privilege show level 3 mode exec command dns-hosts
privilege show level 3 mode exec command access-list
privilege show level 3 mode exec command logging
privilege show level 3 mode exec command vlan
privilege show level 3 mode exec command ip
privilege show level 3 mode exec command ipv6
privilege show level 3 mode exec command failover
privilege show level 3 mode exec command asdm
privilege show level 3 mode exec command arp
privilege show level 3 mode exec command route
privilege show level 3 mode exec command ospf
privilege show level 3 mode exec command aaa-server
privilege show level 3 mode exec command eigrp
privilege show level 3 mode exec command crypto
privilege show level 3 mode exec command vpn-sessiondb
privilege show level 3 mode exec command ssh
privilege show level 3 mode exec command dhcpd
privilege show level 3 mode exec command vpnclient
privilege show level 3 mode exec command blocks
privilege show level 3 mode exec command wccp
privilege show level 3 mode exec command dynamic-filter
privilege show level 3 mode exec command webvpn
privilege show level 3 mode exec command module
privilege show level 3 mode exec command uauth
privilege show level 3 mode exec command compression
privilege show level 3 mode configure command interface
privilege show level 3 mode configure command clock
privilege show level 3 mode configure command access-list
privilege show level 3 mode configure command logging
privilege show level 3 mode configure command ip
privilege show level 3 mode configure command failover
privilege show level 5 mode configure command asdm
privilege show level 3 mode configure command arp
privilege show level 3 mode configure command route
privilege show level 3 mode configure command aaa-server
privilege show level 3 mode configure command crypto
privilege show level 3 mode configure command ssh
privilege show level 3 mode configure command dhcpd
privilege show level 5 mode configure command privilege
privilege clear level 3 mode exec command dns-hosts
privilege clear level 3 mode exec command logging
privilege clear level 3 mode exec command arp
privilege clear level 3 mode exec command aaa-server
privilege clear level 3 mode exec command crypto
privilege clear level 3 mode exec command dynamic-filter
privilege cmd level 3 mode configure command failover
privilege clear level 3 mode configure command logging
privilege clear level 3 mode configure command arp
privilege clear level 3 mode configure command crypto
privilege clear level 3 mode configure command aaa-server
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:b0f643d0118f17086762dfe1864268f1
There are some things that are happening on the outside but not on the inside.
NTP
Smart CallHome
There are also things that happen in both but probably not in the same way all the time.
SSH
ASDM
My point is that you might be seeing a normal behavior of the ASA.
This is what i would do to confirm it:
Clear all the connections, including the ones that go to the ASA. Use the "clear local all" command for that.
If possible, i would connect to the device using a console cable so i won't generate traffic on the inside.
I would monitor the interface utilization on the outside, the inside counters should increment a little bit in case there is still some traffic. This without traffic flowing across.
Then capture all the traffic on my outside interface for a short period of time.
After that, i would run a simple ICMP test to the internet [4.2.2.2] and check the interface stats again.
Finally, i packet capture for all the ICMP traffic going to the internet [4.2.2.2] on both interfaces in order to compare the amount of traffic captured on both sides.
This should tell you if what you are seeing might be considered as normal or not, also, will show you if there is a problem of any sort.
lennartki
I've got the same thing going on. Were you ever able to solve this?
ASA Version: 9.2(2)4
ASDM Version: 7.3(1)101
We have the same issue on our ASA 5506-X (and previously also on our ASA 5505):
Cisco Adaptive Security Appliance Software Version 9.6(1)
Device Manager Version 7.6(1)
It does not seem to indicate a problem, but rather some small bug.
I've noticed the same problem.
Any solutions?
