ASA 5510, Access other interface problem
zafar12233
I have just configured my brand new ASA 5510 with ASA Version 8.0(4). i am having a little problem that is: i cannot access(nor even ping) DMZ interface and other interface from Inside Host, mean while i can access the servers behind DMZ and other interfaces.
when i ping to DMZ interface i found the below msgs in logging.
Built inbound ICMP connection for faddr 192.168.10.33/512 gaddr 172.16.250.5/0 laddr 172.16.250.5/0
Details:
% ASA-6-302020: Built {in | out}bound ICMP connection for faddr {faddr | icmp_seq_num} gaddr {gaddr | cmp_type} laddr laddr
An ICMP session was established in the fast-path when stateful ICMP is enabled using the inspect icmp command.
Teardown ICMP connection for faddr 192.168.10.33/512 gaddr 172.16.250.5/0 laddr 172.16.250.5/0
details:
%ASA-6-302021: Teardown ICMP connection for faddr {faddr | icmp_seq_num}
An ICMP session was removed in the fast-path when stateful ICMP is enabled using the inspect icmp command.
i tried alot but couldnt get success.
please help!
3 Accepted Solutions
A host residing on an interface can only ping its adjacnet ASA interface.It cannot ping the far end
interface of ASA. For example if you have a host on inside, this host can only ping the
inside interface of ASA and no other interface (eg: outside or dmz). Although the Hosts connected to "Far end interfaces" can be pinged, "Far end interface" cannot be pinged by a host . This is a security feature on ASA firewalls.
Syed Iftekhar Ahmed
Syed Iftekhar Ahmed
Its there since PIX days.
Its exists for all ASA codes.
Syed Iftekhar Ahmed
5 Replies 5
Syed Iftekhar Ahmed
Syed Iftekhar Ahmed
Thank you So Much for your Reply Mr. Iftikhar,
I got your point, i sensed that too, but wasnt sure, once again thanks 🙂
i have a question that this security feature is only available in ASA ver. 8.0(4) or its ASA feature regardless of ASA Version?
Thank you,
Zafar-
Syed Iftekhar Ahmed
Thanks once again 🙂
