03-19-2017 11:39 PM - edited 03-12-2019 02:05 AM
we are having asa5510 firewall in our office in which we were connected 20mbps internet. but recently we upgraded to 400mpbs internet but when we check the speed test its showing only 100 mbps. so can anyone advice me whether asa 5510 outside interface supports 400mbps connection. is there anything i can do in the firewall in order to support all 400 mbps connection
Solved! Go to Solution.
03-20-2017 12:08 AM
(Moved thread to Security > Firewalling)
An ASA 5510 with the default Base license is limited to 100 Mbps Fast Ethernet interfaces. If you have the upgraded Security Plus license, you get two interfaces bumped up to 1 Gbps. However the aggregated throughput of the appliance is only 300 Mbps. Note AGGREGATED i.e., not for a single flow.
in practical application, if you want to fully utilize your 400 Mbps circuit you should consider upgrading your platform (which has been end of sales for several years) to something like an ASA 5516-X.
03-20-2017 12:08 AM
