ASA 5515-X and NAT problems
arani
Hi all
Does anyone have experience with the new ASA 5515-X and software version asa861-k8-smp?
We are experiencing problems with NAT through some interfaces (and not through others)
ASA let's you insert NAT commands (using objects) but when you issue a "show run", command are not present in configuration via CLI.
The same via ASDM. You can insert nat statements, and you can see them via ASDM but not in the CLI.
Some ideas?
Kind regards.
Please explain exactly what you try to do. Perhaps it's just a wrong configuration.
Dear Iwen
The issue was not about wrong configuration.
Today the device is working correctly with no issues and with no changes to the original configuratio.
During the weekend we have changed version asa861-k8-(1) with asa861-k8-(2) end rebooted.
Kind regards.
