ASA 5520 booting problem
singraj2001
I have new ASA5520. After configured and upgrade with ASA 8.0(3) image its works for few times (few times means after restarted several times). But now the error comes as "Booting system, Please wait..." nothing else appear.
Can anyone suggest what could be the problem. Thanks
S.Rajkumar
9 Replies 9
varrao
Level 11
Level 11
Hi Rajkumar,
Cam you paste the complete conole messages that you get, moreover do you have any carshinfo saved onto the firewall??
Varun
Varun Rao
Hi Varun,
Just appear this message only in console
Then nothing else appear.
I cannot even go to console...
S.Rajkumar
Can you keep the device powered down for 10 minutes and then try and power it up.
Varun
Varun Rao
Yes Varun, Try to power after 30 mins also the same.
S.Rajkumar
Then I would suggest you to open a TAC case for it, could be a hardware issue and you might need an RMA for it.
-Varun
Varun Rao
From the front panel of the ASA. The power light is green and stable. But the Ststus light green and blinking and there is no active even i connected the UTP cable from G0/1 to my PC. Thanks
S.Rajkumar
Try loading the image on the ASA through rommon mode:
Here are the steps for loading  image from rommon mode:
Step1 Power  off the adaptive security appliance, and then power it on.
Step 2 During  startup, press the Escape key when  you are prompted to enter ROMMON mode.
Step3 In  ROMMOM mode, define the interface settings to the adaptive security appliance,  including the IP address, TFTP server address, gateway address, software image  file, and port, as follows:
rommon #1> ADDRESS=10.132.44.177
rommon #2> SERVER=10.129.0.30
rommon #3> GATEWAY=10.132.44.1
rommon #4> IMAGE=f1/asa800-232-k8.bin
rommon #5> PORT=Ethernet0/0
Please make sure that the Tftp  server is connected to the interface.
Step 5 To  validate your settings, enter the set command.
rommon #6> set
Step 6 Ping the  TFTP server by entering the ping  server command.
rommon #7> ping server
Step 7 Load the  software image by entering the tftp command.
rommon #8> tftp
Step 8 Reload  the security appliance to run the new image.
rommon #9> reload
After the software image is  successfully loaded, the security appliance automatically exits ROMMOM mode.
Here is the document to do the  same:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/trouble.html
If this does not work, then you would need to RMA the device.
Varun
Varun Rao
Thanks for your reply,
Anyway cannot go to ROMMON mode also. I think need to send RMA as per your info.
Thanks once again.
S.Rajkumar
No issues
-Varun
Varun Rao
