ASA 5520 translation problem
hisham.khreisat
I have the following in my deployment:
Server --- ACE 4710 --- ASA 5520 -- Router
from the server I can ping the inside ASA.but can't ping outside ASA or inside Router.
from the ASA I can ping Outside Router, Server, and The Virual IP Address of ACE.
the following configuration for ASA 5520:
hostname MOI-Elec
domain-name default.domain.invalid
enable password qagxmUWZehLHpnt3 encrypted
passwd qagxmUWZehLHpnt3 encrypted
names
dns-guard
interface GigabitEthernet0/0
description --- To GW_1 ---
nameif outside1
security-level 0
ip address 172.20.1.240 255.255.255.0
interface GigabitEthernet0/1
description --- To GW_2 ---
nameif outside2
security-level 0
no ip address
interface GigabitEthernet0/2
description --- SERVER DMZ ---
nameif SERVER-DMZ
security-level 100
ip address 192.168.20.10 255.255.255.0
interface GigabitEthernet0/3
shutdown
nameif asd
security-level 100
no ip address
interface Management0/0
nameif mngmt-asdm
security-level 100
ip address 10.10.10.10 255.255.255.0
ftp mode passive
access-list temp extended permit icmp any any
access-list temp extended permit ip any any
access-list cap1 extended permit ip any host 172.20.1.240
access-list cap1 extended permit ip host 172.20.1.240 any
pager lines 24
logging enable
logging buffered errors
mtu outside1 1500
mtu outside2 1500
mtu SERVER-DMZ 1500
mtu asd 1500
mtu mngmt-asdm 1500
no failover
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
static (SERVER-DMZ,outside1) 192.168.20.20 192.168.20.20 netmask 255.255.255.255
access-group temp in interface outside1
access-group temp in interface outside2
access-group temp in interface SERVER-DMZ
route outside1 0.0.0.0 0.0.0.0 172.20.1.251 1
route SERVER-DMZ 172.20.0.0 255.255.0.0 192.168.20.30 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
username admin password LLO/MKcU/To/3BlR encrypted
http server enable
http 0.0.0.0 0.0.0.0 SERVER-DMZ
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 15
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 50
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect dns maximum-length 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
Cryptochecksum:ac69173ace9b8f69bfff97c28a9f35d5
: end
The following Configuration on ACE 4710:
Generating configuration....
resource-class rc1
  limit-resource all minimum 10.00 maximum unlimited
  limit-resource sticky minimum 10.00 maximum unlimited
boot system image:c4710ace-mz.A3_2_0.bin
peer hostname moi-lb
hostname moi-lb2
interface gigabitEthernet 1/1
  description ace-outside to ASA G0/0
  switchport access vlan 3
  no shutdown
interface gigabitEthernet 1/2
  description ace-inside to DMZ-SW G1/1
  switchport access vlan 2
  no shutdown
interface gigabitEthernet 1/3
  switchport access vlan 1000
  no shutdown
interface gigabitEthernet 1/4
  ft-port vlan 10
  no shutdown
clock timezone Jor 0 0
context Admin
  member rc1
access-list all line 8 extended permit ip any any
access-list all line 16 extended permit icmp any any
probe tcp tcp-7777
  port 7777
  interval 15
  passdetect interval 60
  open 1
rserver host app-205
  ip address 172.20.100.205
  inservice
serverfarm host app-servers
  predictor leastconns
  probe tcp-7777
  fail-on-all
  rserver app-205
    inservice
sticky ip-netmask 255.255.255.255 address source group1
  timeout 15
  replicate sticky
  serverfarm app-servers
class-map type management match-any REMOTE_ACCESS
  description Remote access traffic match 2
  2 match protocol telnet any
  3 match protocol ssh any
  4 match protocol icmp any
  5 match protocol https any
class-map match-all vip-app
  2 match virtual-address 192.168.20.20 tcp eq 7777
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
  class REMOTE_ACCESS
    permit
policy-map type loadbalance first-match vip-lb
  class class-default
    sticky-serverfarm group1
policy-map multi-match lb-vip-policy
  class vip-app
    loadbalance vip inservice
    loadbalance policy vip-lb
    loadbalance vip icmp-reply
interface vlan 2
  ip address 172.20.0.251 255.255.0.0
  no icmp-guard
  access-group input all
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  no shutdown
interface vlan 3
  ip address 192.168.20.30 255.255.0.0
  no icmp-guard
  service-policy input lb-vip-policy
  no shutdown
interface vlan 1000
  description ---management vlan---
  ip address 172.26.255.2 255.255.255.0
  peer ip address 172.26.255.1 255.255.255.0
  no shutdown
ft interface vlan 10
  ip address 10.0.0.11 255.255.255.0
  peer ip address 10.0.0.10 255.255.255.0
  no shutdown
ft peer 1
  heartbeat interval 100
  heartbeat count 20
  ft-interface vlan 10
ft group 1
  peer 1
  associate-context Admin
  inservice
ft track interface track-vlan2
  track-interface vlan 2
  peer track-interface vlan 2
  priority 25
  peer priority 25
ft track interface track-vlan3
  track-interface vlan 3
  peer track-interface vlan 3
  priority 30
  peer priority 30
ip route 0.0.0.0 0.0.0.0 192.168.20.10
anyone have any Idea about why the ASA 5520 doen't permit to go out side of my inside server network to outside.
please help
5 Replies 5
Shrikant Sundaresh
Hi Hisham,
You cannot ping the ASA interfaces which are not directly facing your device.
So if you are on the inside, you can only ping the inside interface.
Now coming to the router, I see that there is no nat configured on the ASA. So unless you have a route configured on the router, with a route back to the server subnet, the router will not be able to reply to the icmp packet.
Run "debug icmp trace 1" command on the ASA, and check if you see icmp request going from the server to the router, but no replies coming back.
This would indicate an issue with the routing on the router.
Also, please check if nat-control is enabled (show run all | in nat-control)
IF it is enabled, then you need to disable it (no nat-control) or configure a nat rule for traffic going from inside to outside.
Hope this helps.
-Shrikant
P.S.: Please mark the question resolved if it has been answered. Do rate helpful posts. Thanks
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.04.05 13:21:12 =~=~=~=~=~=~=~=~=~=~=~=
internal#sh run
Building configuration...
Current configuration : 1276 bytes
version 12.4
hostname internal
boot-start-marker
boot-end-marker
!card type command needed for slot 1
card type e1 2
!card type command needed for slot 3
!card type command needed for slot 4
enable secret 5 $1$mV65$5mOlGHjWThTljxYFF2OUb/
no aaa new-model
resource policy
no network-clock-participate slot 2
ip cef
voice-card 0
no dspfarm
controller E1 2/0
framing NO-CRC4
channel-group 0 timeslots 1-31
controller E1 2/1
ip address 172.20.1.251 255.255.255.0
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial2/0:0
description E1 LINK TO MUHAFDA
ip address 172.19.8.249 255.255.255.252
ip route 0.0.0.0 0.0.0.0 Serial2/0:0
ip route 172.0.0.0 255.0.0.0 GigabitEthernet0/0
i
ip http server
no ip http secure-server
control-plane
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
This is the router configuration
Hi Hisham,
Could you also please attach the output of the following command on the ASA
packet-tracer input icmp 8 0 detail
This shows the packet flow of the icmp request through the ASA.
-Shrikant
Hello There,
I'll do what asked from me tomorrow morning, but I would like to mention that I have already did a capture, as the following
Server (172.20.100.205/16) ---- (Inside: 172.20.0.251/16) ACE (outside: 192.168.20.30/24) --- (inside:192.168.20.30/24)ASA(outside:172.20.1.240/24) ---- (172.20.1.251/24)Router.
I did the ping from the server to inside router (172.20.1.251)
access-list cap extended permit ip host 172.20.100.205 host 172.20.1.251
access-list cap extended permit ip host 172.20.1.251 host 172.20.100.205
capture test access-list cap interface inside-ASA
sh capture gave me
0 packets !!!! no results appear. !!!!
If you please any one can review the configuration carefully and tell me, If there is any wrong configuration ACE,ASA,Router.
I hope you can find any way to get out of this problem !!!!!
Thank you all,
Hisham Khreisat
Hi Hisham,
I have never really worked with an ACE before, so I am not sure about its configs. Though trying to judge the config based on what i know about routers and ASA, it seems ok except for if you can apply "service policy" multiple policy's on an interface or not. You would need to verify that, but most probably it must be correct.
Secondly, an anomaly i see, is in the subnet mask of the outside interface of the ACE. You have given a /16 subnet mask, while a /24 subnet mask on the corresponding ASA interface. I am not sure if that would impact packet flow, but you could correct it and check again.
Lastly, and most importantly, if the capture showed no packets on the ASA, means it is a fault on the ACE because no packets reached the ASA.
Thus output of the packet-tracer command would be no use at all, since it shows the packet trace after the packet reaches the ASA.
So we need to concentrate on the link between ACE and ASA, and figure out why the ACE is not sending traffic to the ASA.
-Shrikant
P.S.: Please mark the question resolved, if it has been answered. Do rate helpful posts. Thanks.
