10-07-2016 08:53 PM - edited 03-12-2019 01:22 AM
Does anyone know if there is any known issues with the ASA 5525 and the HP2920?
We migrated over and we weren't able to get to part of the network. The configuration looks correct.
10-08-2016 04:19 PM
Nope, check both configs.
10-09-2016 10:17 AM
by "we weren't able to get to part of the network." I think you are referring to certain VLANs, is that correct? Could you describe what exactly did not work?
This is most likely an issue with DOT1Q Trunking. Make sure VLAN Trunking is correctly configured on the switch/firewall.
If you need any support post the procurve and asa configuration.
