ASA 8.2.5 Problem to make VPN connection from LAN to Outside
maior.biz
Hi, i have a 5510 with SDM 8.2.5
from clients connected to LAN i cant open a VPN connection! (using windows client L2TP or PPTP)
there is not rules tho block this ports, why i cant connect?
thisi is my configuration, tks
FIREWALLP01# show running-config
: Saved
ASA Version 8.2(5)
hostname FIREWALLP01
domain-name MAIOR.local
enable password 28kg/dOQX80WtMHA encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 79.xx.xx.73 ROUTERP01
name 79.xx.xx.75 Pubblica_HTTP
name 79.xx.xx.76 Pubblica_VOIP
name 192.168.90.2 SERVERP02
name 192.168.90.3 SERVERP03
name 192.168.92.4 SERVERP04
interface Ethernet0/0
nameif Pubblica_SIADSL
security-level 0
ip address 79.xx.xx.74 255.255.255.248
interface Ethernet0/1
nameif LAN
security-level 100
ip address 192.168.90.254 255.255.255.0
interface Ethernet0/2
nameif DMZ
security-level 98
ip address 192.168.92.254 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
dns domain-lookup Pubblica_SIADSL
dns domain-lookup LAN
dns domain-lookup DMZ
dns domain-lookup management
dns server-group DefaultDNS
name-server SERVERP02
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service rtp udp
port-object range 9000 9049
access-list Pubblica_SIADSL_access_in extended permit udp any host Pubblica_VOIP object-group rtp
access-list Pubblica_SIADSL_access_in extended permit object-group TCPUDP any host Pubblica_VOIP eq sip
access-list Pubblica_SIADSL_access_in extended permit object-group TCPUDP any host Pubblica_HTTP eq sip
access-list LAN_nat0_outbound extended permit ip any 192.168.90.0 255.255.255.0
pager lines 24
logging asdm informational
mtu Pubblica_SIADSL 1500
mtu LAN 1500
mtu DMZ 1500
mtu management 1500
ip local pool VPN_pool 192.168.90.120-192.168.90.129 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-625-53.bin
no asdm history enable
arp timeout 14400
global (Pubblica_SIADSL) 1 interface
global (DMZ) 1 interface
nat (LAN) 0 access-list LAN_nat0_outbound
nat (LAN) 1 0.0.0.0 0.0.0.0
static (DMZ,Pubblica_SIADSL) Pubblica_HTTP SERVERP04 netmask 255.255.255.255
static (LAN,Pubblica_SIADSL) Pubblica_VOIP SERVERP03 netmask 255.255.255.255
access-group Pubblica_SIADSL_access_in in interface Pubblica_SIADSL
route Pubblica_SIADSL 0.0.0.0 0.0.0.0 ROUTERP01 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
webvpn
  url-list value Link
aaa-server SERVERP02 protocol ldap
aaa-server SERVERP02 (LAN) host SERVERP02
ldap-base-dn DC=MAIOR,DC=local
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-password *****
ldap-login-dn CN=Administrator,CN=Users,DC=MAIOR,DC=local
server-type microsoft
http server enable
http 192.168.1.0 255.255.255.0 management
http authentication-certificate management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto  dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set  TRANS_ESP_3DES_SHA ESP-3DES-SHA
crypto map Pubblica_SIADSL_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_ MAP
crypto map Pubblica_SIADSL_map interface Pubblica_SIADSL
crypto isakmp enable Pubblica_SIADSL
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
management-access management
dhcpd address 192.168.1.2-192.168.1.254 management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable LAN
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server value 192.168.90.2
vpn-tunnel-protocol IPSec l2tp-ipsec
default-domain value MAIOR.local
username test password P4ttSyrm33SV8TYp encrypted
username test attributes
service-type remote-access
tunnel-group DefaultRAGroup general-attributes
address-pool VPN_pool
authentication-server-group SERVERP02
default-group-policy DefaultRAGroup
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *****
tunnel-group DefaultRAGroup ppp-attributes
authentication pap
no authentication chap
no authentication ms-chap-v1
tunnel-group DefaultWEBVPNGroup general-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:4774f1e5b912c7f299328746e2fa3c1e
: end
FIREWALLP01#
Maykol Rojas
Hi Raffaele,
Very simple, PPTP uses GRE as an escpsulation protocol, which means that it will not let the firewall see the ports or the TCP sessions carried on int the VPN connection. Since the firewall cannot see the ports, it will only see IP protocol 47, which are the GRE packets.
If you put your logs on the ASDM you will see that the firewall will say portmap translation creation failed for IP protocol 47.
What you need to do is to add the inspection for PPTP, that will allow the firewall to pre-allocate a channel for PPTP traffic and GRE in order to let it pass thru, here is what you can do :
       inspect pptp
Just copy and paste those commands on the configuration mode of the ASA and then try to connect, that should serve you well. If still cant connect, do a clear local-host and then try again.
Let me know how it goes.
Mike
Mike
Maykol Rojas
Hi Raffaele,
       inspect pptp
Mike
Mike
