ASA 9.12 and 9.13 nat problem! please help.
takkerZAB
Hello.
i have config on asa 5525-x v9.10.2 and before it. Config working fine!!! when I updated to the 9.12.2 or 9.13.1 version, an error appeared. Line 2 can not be added.  "ERROR: NAT unable to reserve ports"
Why is this not working? Not working on any port 3333 or 2222 or 3389 after update.
nat (internet,dmz) source static any any destination static 1.1.1.1 10.200.5.1 service 3333 3333 no-proxy-arp
nat (inside,dmz) source static any any destination static 1.1.1.1 10.200.5.1 service 3333 3333 no-proxy-arp
Full config on after "write erase"
interface GigabitEthernet0/0
nameif inside
security-level 100
ip address 192.168.141.254 255.255.255.0
interface GigabitEthernet0/1
nameif internet
security-level 0
ip address 192.168.142.254 255.255.255.0
interface GigabitEthernet0/2
nameif dmz
security-level 50
ip address 192.168.143.254 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network 1.1.1.1
host 1.1.1.1
object network 10.200.5.1
host 10.200.5.1
object service 3333
service tcp destination eq 3333
12 Replies 12
you getting the error message "ERROR: NAT unable to reserve ports" means your port are already used. try to change the port number. that will fix the issue.
please do not forget to rate.
Hello. i have clean config (write erase) Only this 2 nat line. This problem with any port. Any!
2222,3333,1234,5432
On 9.10 this config works fine!
Can anyone explain why it works at 9.10, but not at 9.12?
Please, help. I need to upgrade to a new version, but nat is not working properly. How to fix the problem?
hi could you please share your configuration of firewall you can hide the real ip address i shall test in lab environment. you moving away form 9.x to 9.12?
once you provide me the configuration i shall get back to you
Hello.
I test on asa 5525-x and ASAv. Same problem.
All config is default. I do "write erase". "Reload". And then enter these lines from console:
nameif inside
security-level 100
nameif internet
security-level 0
nameif dmz
security-level 50
host 1.1.1.1
host 10.200.5.1
object service 3333
You could try using "any" interface instead of inside / internet. I would suggest to do this during a service window.
no nat (internet,dmz) source static any any destination static 1.1.1.1 10.200.5.1 service 3333 3333 no-proxy-arp
nat (any,dmz) source static any any destination static 1.1.1.1 10.200.5.1 service 3333 3333 no-proxy-arp
Please remember to select a correct answer and rate helpful posts
takkerZAB
Please help. The problem is still not resolved.
Asa software 9.13(1.3), 9.12(3.4) not aviable at cisco download center
check to see if the ports are already being used:
show conn | in 3333
show asp table socket
ccosgb
Solution: asa9-12-3-7-smp-k8.bin
Revision:  Version 9.12(3)7 – 03/03/2020
Files:  asa9123-7-smp-k8.bin, cisco-asa-fp2k.9.12.3.7.SPA, cisco-asa.9.12.3.7.SPA.csp
Defects resolved since 9.12(3)2:
CSCvp70833
ASA/FTD: Twice nat Rule with same service displaying error "ERROR: NAT unable to reserve ports"
I’ll check this release soon.
Finally everything works! For a whole year this bug prevented me from updating the system. Glory to me and the developers, who first broke everything, then fixed it.
