ASA 9.20(2)21 on FPR1120 can't find path to system://running-config
BrentCoats0047
I upgraded to version 9.20(2)21 on quite a few ASAs and now my SCP config backup command fails with "scp: no such file or directory" for the command "scp user@<fwaddress>:system://running-config newfilename.cfg" from PS.  Anyone know what the path change is in this version?
This works fine in version 9.18(4)24
Tech2019
I'm having the same issue.  I have a remote script that copies the running-config via SCP on a daily basis.  The script has been working for years.  It stopped working since the upgrade to 9.20.
