ASA - communication between AnyConnect (Interface1) to remote network through the VPN (Interface2)
Marek Pawlowski
Dear Experts,
I'm facing a problem with communication between two interfaces (outside) with different public IPs. On one of them, I have an AnyConnect server and on a second one, terminated VPNs to the data centres. I would like to allow traffic from Interface1 (from AnyConnect address pool) to the remote network (through the VPN terminated on an Interface2).
I've checked the box "Enable traffic between two or more interfaces with the same security[...]", but on both interfaces, I have access-lists so it does not apply in my case. Packet tracer shows that packets are dropped on an implicit rule, but I've added permit to the ACL.
What else I can do?
Hi @Marek Pawlowski
Potentially you'll need a NAT exemption rule, from src interface1 to dst interface2 to ensure that traffic between those networks are not unintentially natted. Provide your configuration if you require further assistance
Hi @Rob Ingram,
I've tried to add something similar, but it doesn't help.
Below you can find a sh run result
: Saved
: Serial Number: xxxxxxxxxx
: Hardware:   ASA5516, 8192 MB RAM, CPU Atom C2000 series 2416 MHz, 1 CPU (8 cores)
ASA Version 9.8(4)26
names
no mac-address auto
ip local pool AnyConnect_pool 192.168.222.10-192.168.222.200 mask 255.255.255.0
ip local pool PG_AnyConnect_pool 192.168.223.10-192.168.223.30 mask 255.255.255.224
ip local pool Any_INFRA_LW 192.168.224.10-192.168.224.50 mask 255.255.255.0
interface GigabitEthernet1/1
 description Inside
 nameif InsideSRV
 security-level 90
 ip address 192.168.194.1 255.255.254.0 standby 192.168.194.2
interface GigabitEthernet1/2
 nameif DMZPublic
 security-level 10
 no ip address
interface GigabitEthernet1/2.41
 vlan 41
 nameif Public_DMZ
 security-level 10
 ip address 194.213.22.1 255.255.255.0 standby 194.213.22.254
interface GigabitEthernet1/2.42
 vlan 42
 nameif Public2_DMZ
 security-level 10
 ip address 193.59.39.1 255.255.255.128 standby 193.59.39.2
interface GigabitEthernet1/2.43
 vlan 43
 nameif Public3_DMZ
 security-level 10
 ip address 77.65.153.1 255.255.255.128 standby 77.65.153.2
interface GigabitEthernet1/4
 description Public network routed
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/4.101
 vlan 101
 nameif ASA_to_Core
 security-level 90
 ip address 192.168.101.1 255.255.255.0 standby 192.168.101.2
interface GigabitEthernet1/4.255
 vlan 255
 nameif wifi_guest
 security-level 20
 ip address 172.16.1.1 255.255.255.0 standby 172.16.1.2
interface GigabitEthernet1/5
 description To_BGP_Router
 nameif To_ISPs_77.65.153.254
 security-level 0
 ip address 77.65.153.254 255.255.255.240 standby 77.65.153.253
interface GigabitEthernet1/6
 nameif To_ISPs
 security-level 0
 ip address 193.59.39.254 255.255.255.240 standby 193.59.39.253
interface GigabitEthernet1/7
 description STATE Failover Interface
interface GigabitEthernet1/8
 description LAN Failover Interface
interface Management1/1
 management-only
 no nameif
 no security-level
 no ip address
boot system disk0:/asa992-36-lfbff-k8.SPA
boot system disk0:/asa9-13-1-lfbff-k8.SPA
no ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup InsideSRV
dns domain-lookup DMZPublic
dns domain-lookup Public_DMZ
dns domain-lookup Public2_DMZ
dns domain-lookup management
dns domain-lookup ASA_to_Core
dns domain-lookup wifi_guest
dns domain-lookup To_ISPs
dns domain-lookup To_ISPs_77.65.153.254
dns domain-lookup Public3_DMZ
dns server-group DefaultDNS
 name-server 192.168.194.201 InsideSRV
 domain-name intra.anixe.pl
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network NETWORK_OBJ_192.168.194.0_23
 subnet 192.168.194.0 255.255.254.0
object network VPNSiteToSiteRouter
 host 194.213.22.250
 description Router do VPN Site-to-Site
object network Public_194.213.22.2
 host 194.213.22.2
object network NETWORK_OBJ_194.213.22.0_24
 subnet 194.213.22.0 255.255.255.0
object network BEYOND_10.117.104.0
 subnet 10.117.104.0 255.255.255.0
object network BEYOND_10.33.18.0
 subnet 10.33.18.0 255.255.255.0
object network ATM_10.5.1.0
 subnet 10.5.1.0 255.255.255.0
object network ATM_10.5.143.0
 subnet 10.5.143.0 255.255.255.0
object network ATM_10.6.253.0
 subnet 10.6.253.0 255.255.255.0
object network ATM_10.4.0.0
 subnet 10.4.0.0 255.255.0.0
object network Anyconnect_Address_Pool
 subnet 192.168.222.0 255.255.255.0
object network wheels_acc_80
 host 192.168.195.18
object network logmachine.anixe.pl
 host 192.168.194.53
object network 10.117.106.0
 subnet 10.117.106.0 255.255.255.0
object service 5671
 service tcp destination eq 5671
 description wheels_acc
object service 15672
 service tcp destination eq 15672
 description wheels_acc_15672
object network NETWORK_OBJ_192.168.195.142
 host 192.168.195.142
object network RFC_10.0.0.0
 subnet 10.0.0.0 255.0.0.0
object network Hostmonitor_Public
 host 194.213.22.140
object network OVH_178.32.205.187
 host 178.32.205.187
object network FlyTap_77.79.212.74
 host 77.79.212.74
object network acc-paysecure_public.223
 host 194.213.22.223
object network Management_network
 subnet 192.168.254.0 255.255.255.0
object network GULF_178.32.205.187
 host 178.32.205.187
object network FlyTap_ATM_77.79.212.101
 host 77.79.212.101
object network FlyTap_R3Admin_77.79.212.72
 host 77.79.212.72
object network Tap_Ebroker_91.198.90.105
 host 91.198.90.105
object network HITIT_ACC_129.1.20.10
 host 129.1.20.10
object network Beyond_Network_outside
 subnet 92.43.117.0 255.255.255.0
object network Beyond_109.205.52.0
 subnet 109.205.52.0 255.255.255.0
object network Beyond_net_109.205.52.0
object network KCH_MACBook_192.168.195.100
 host 192.168.195.100
object network Public_PCI-194.213.22.65
 host 194.213.22.65
object network ATM_10.6.0.0
 subnet 10.6.0.0 255.255.255.0
object network ATM_10.6.1.0
 subnet 10.6.1.0 255.255.255.0
object network ATM_10.6.254.0
 subnet 10.6.254.0 255.255.255.0
object network 194.213.22.72
 host 194.213.22.72
object service 9000
 service tcp destination eq 9000
 description TeamCity
object service 8443
 service tcp destination eq 8443
object service 8080
 service tcp destination eq 8080
object service 1055
 service tcp destination eq 1055
object service 5057
 service tcp destination eq 5057
object service 8000
 service tcp destination eq 8000
object network 194.213.22.181
 host 194.213.22.181
object service 4567
 service tcp destination eq 4567
object service 8889
 service tcp destination eq 8889
object service 465
 service tcp destination eq 465
object service 993
 service tcp destination eq 993
object service 995
 service tcp destination eq 995
object service 587
 service tcp destination eq 587
object service 60000
object service 1529
 service tcp destination eq 1529
object service 1194_tcp
 service tcp destination eq 1194
object service 1194_udp
 service udp destination eq 1194
object service 1022
 service tcp destination eq 1022
object network 194.213.22.104
 host 194.213.22.104
 description TAPTest2012
object network 194.213.22.103
 host 194.213.22.103
 description OldTensai
object service 81
 service tcp destination eq 81
object network 194.213.22.105
 host 194.213.22.105
 description Cacti
object service 873
 service tcp destination eq 873
object service 990
 service tcp destination eq 990
object network 193.59.39.2
 host 193.59.39.2
object network 194.213.22.223
 host 194.213.22.223
object network KCH-WRO-001_192.168.195.136
 host 192.168.195.136
object service Range6000
object service range6k
 service tcp destination range 6000 6600
object network 10.4.4.254
 host 10.4.4.254
object network HER01
 host 10.30.130.224
object network 10.83.48.120
 host 10.83.48.120
object network 10.83.48.19
 host 10.83.48.19
object network CiscoSX-20-vcs12
 host 192.168.195.143
object network CiscoSX-20-vcs11
object network INSIDE_PAT_IP
 host 192.168.195.254
object network FTI_10.83.42.210
 host 10.83.42.210
object network FTI_10.83.41.17
 host 10.83.41.17
object network 10.90.0.225
 host 10.90.0.225
object network GCloud_10.0.2.0
 subnet 10.0.2.0 255.255.255.0
object network GCloud_10.0.3.0
 subnet 10.0.3.0 255.255.255.0
object network 10.97.2.224
 host 10.97.2.224
object network 10.97.2.225
 host 10.97.2.225
object network 10.97.2.226
 host 10.97.2.226
object service 445
 service tcp destination eq 445
object network 10.83.43.191
 host 10.83.43.191
object network 52.58.112.76
 host 52.58.112.76
object network 85.255.10.103
 host 85.255.10.103
object network anx-cl-agent
 host 194.213.22.113
object network anx-cl-server
 host 194.213.22.114
object network CyberLogic
 host 46.103.121.154
object service RDP_UDP
 service udp destination eq 3389
object service RDP_TCP
 service tcp destination eq 3389
object network 97.65.24.2
 host 97.65.24.2
object network 190.166.237.250
 host 190.166.237.250
object network 41.33.48.194
 host 41.33.48.194
object network 41.33.114.210
 host 41.33.114.210
object network 41.187.76.33
 host 41.187.76.33
object network 41.33.124.18
 host 41.33.124.18
object network 41.33.102.34
 host 41.33.102.34
object network 41.33.145.242
 host 41.33.145.242
object network 213.249.13.46
 host 213.249.13.46
object network 213.249.49.201
 host 213.249.49.201
object network 83.235.16.9
 host 83.235.16.9
object network PG-AnyConnect-Pool_192.168.223.0
 range 192.168.223.10 192.168.223.30
object network 10.30.2.225
 host 10.30.2.225
object network Serwer_Radius
 host 192.168.194.100
object service 8082
 service tcp destination eq 8082
object service 8089
 service tcp destination eq 8089
object service 8085
 service tcp destination eq 8085
object service 8083
 service tcp destination eq 8083
object service 8086
 service tcp destination eq 8086
object network 10.83.48.131
 host 10.83.48.131
object network CyberLogic_2
 host 178.59.16.232
object network 194.213.22.133
 host 194.213.22.133
object network PCILogs
 host 192.168.194.111
object network 192.168.194.118
 host 192.168.194.118
object network 35.234.74.0
 host 35.234.74.0
object service 9200
 service tcp destination eq 9200
object network 192.168.195.121
 host 192.168.195.121
object service 27017
 service tcp destination eq 27017
object network 192.168.194.170
 host 192.168.194.170
object service 2525
 service tcp destination eq 2525
object network 10.90.8.224
 host 10.90.8.224
object network 10.35.2.224
 host 10.35.2.224
object network 10.35.2.225
 host 10.35.2.225
object network 10.90.8.225
 host 10.90.8.225
object service 9201
object network NBCACC
 host 192.168.194.32
object service 3269
 service tcp destination eq 3269
object service 3268
 service tcp destination eq 3268
object service 636
 service tcp destination eq ldaps
object network 10.233.2.0
 subnet 10.233.2.0 255.255.255.0
object network NETWORK_OBJ_192.168.195.185
 host 192.168.195.185
object network 194.213.22.99
 host 194.213.22.99
 description Gulf Acc v2
object network 192.168.194.194
 host 192.168.194.194
 description MPA-WN
object network 10.233.4.2
 host 10.233.4.2
object network PCI-TEST_194.213.22.212
 host 194.213.22.212
object network 194.182.86.149
 host 194.182.86.149
object network 176.107.130.245
 host 176.107.130.245
object network 195.181.215.158
 host 195.181.215.158
object network 10.33.19.0
 subnet 10.33.19.0 255.255.255.0
object network 192.168.194.134
 host 192.168.194.134
object network 35.246.224.209
 host 35.246.224.209
object network Infra-Host
object network 10.10.0.0
 subnet 10.10.0.0 255.255.0.0
object network JZU_WIFI_192.168.195.106
 host 192.168.195.106
object network JZU_ETH_192.168.195.172
 host 192.168.195.172
object network NewFPMC
 host 192.168.194.196
object network GuestsANX
 subnet 172.16.1.0 255.255.255.0
object network 10.33.21.0
 subnet 10.33.21.0 255.255.255.0
object network 10.33.20.0
 subnet 10.33.20.0 255.255.255.0
object network CACTI
 host 192.168.195.128
object network 10.33.23.0
 subnet 10.33.23.0 255.255.255.0
object network 192.168.194.93
 host 192.168.194.93
object network 37.187.101.6
 host 37.187.101.6
object network AnyConnect-Infra-LW
 subnet 192.168.224.0 255.255.255.0
object network 10.33.24.0
 subnet 10.33.24.0 255.255.255.0
object network ATH_Office_LAN_192.168.59.0
 subnet 192.168.59.0 255.255.255.0
object network 10.83.43.222_Bamboo
 host 10.83.43.222
object network 10.83.20.162_FTI-BI
 host 10.83.20.162
object network 10.83.20.163_FTI-BI
 host 10.83.20.163
object service SSH
 service tcp destination eq ssh
object service 4443
 service tcp destination eq 4443
object network InsideSRV-network-23
object network 194.213.22.21
 host 194.213.22.21
object network 109.233.88.8
 host 109.233.88.8
object network 77.65.153.241
 host 77.65.153.241
object network 10.2.0.0
 subnet 10.2.0.0 255.255.0.0
object network ATH-EDGE_62.74.200.103
 host 62.74.200.103
object network 192.168.222.160
 host 192.168.222.160
object network 10.2.0.2
 host 10.2.0.2
object network 10.2.0.3
 host 10.2.0.3
object network 192.168.222.177
 host 192.168.222.177
object network 10.1.100.81
 host 10.1.100.81
object network 95.211.42.219_LW
 host 95.211.42.219
object-group network DM_INLINE_NETWORK_1
 network-object object ATM_10.4.0.0
 network-object object ATM_10.5.1.0
 network-object object ATM_10.5.143.0
 network-object object ATM_10.6.253.0
object-group network DM_INLINE_NETWORK_2
 network-object object BEYOND_10.117.104.0
 network-object object BEYOND_10.33.18.0
object-group network DM_INLINE_NETWORK_3
 network-object 192.168.194.0 255.255.254.0
 network-object 10.117.104.0 255.255.255.0
 network-object 10.117.105.0 255.255.255.0
 network-object 10.33.18.0 255.255.255.0
 network-object 10.4.0.0 255.255.0.0
 network-object 10.5.1.0 255.255.255.0
 network-object 10.5.143.0 255.255.255.0
 network-object 10.83.0.0 255.255.0.0
 network-object object 10.117.106.0
 network-object object ATM_10.6.1.0
 network-object 10.6.0.0 255.255.255.0
 network-object 10.6.253.0 255.255.255.0
 network-object 10.6.254.0 255.255.255.0
 network-object object 10.33.23.0
object-group network DM_INLINE_NETWORK_4
 network-object 192.168.254.0 255.255.255.0
 network-object object Anyconnect_Address_Pool
object-group network DM_INLINE_NETWORK_6
 network-object object 194.213.22.223
 network-object object Hostmonitor_Public
object-group service DM_INLINE_SERVICE_1
 service-object tcp destination eq www
 service-object tcp destination eq https
 service-object object 15672
 service-object object 5671
object-group network DM_INLINE_NETWORK_10
 network-object host 194.213.22.154
 network-object host 194.213.22.160
object-group network DM_INLINE_NETWORK_9
object-group network DM_INLINE_NETWORK_11
 network-object host 194.213.22.147
 network-object host 194.213.22.148
 network-object host 194.213.22.191
object-group network DM_INLINE_NETWORK_12
 network-object host 194.213.22.117
 network-object host 194.213.22.118
 network-object host 194.213.22.120
 network-object host 194.213.22.122
 network-object host 194.213.22.123
 network-object host 194.213.22.124
 network-object host 194.213.22.125
 network-object host 194.213.22.126
 network-object host 194.213.22.127
 network-object host 194.213.22.128
object-group network DM_INLINE_NETWORK_14
 network-object object FlyTap_77.79.212.74
 network-object object FlyTap_ATM_77.79.212.101
 network-object object FlyTap_R3Admin_77.79.212.72
object-group network DM_INLINE_NETWORK_29
 network-object 194.213.22.0 255.255.255.0
object-group network DM_INLINE_NETWORK_15
 network-object object Beyond_Network_outside
 network-object object Beyond_109.205.52.0
 network-object object Beyond_net_109.205.52.0
object-group network DM_INLINE_NETWORK_19
 network-object object ATM_10.6.254.0
 network-object object ATM_10.6.0.0
object-group network DM_INLINE_NETWORK_20
object-group network DM_INLINE_NETWORK_5
 network-object object KCH_MACBook_192.168.195.100
 network-object object KCH-WRO-001_192.168.195.136
 network-object object JZU_ETH_192.168.195.172
 network-object object JZU_WIFI_192.168.195.106
 network-object object PG-AnyConnect-Pool_192.168.223.0
object-group service DM_INLINE_SERVICE_2
 service-object icmp
 service-object object 873
object-group service DM_INLINE_SERVICE_11
 service-object icmp
 service-object tcp destination eq ssh
object-group network LogicalTrust
 network-object object 52.58.112.76
 network-object object 85.255.10.103
 network-object object 176.107.130.245
 network-object object 194.182.86.149
 network-object object 195.181.215.158
 network-object object 37.187.101.6
object-group network DM_INLINE_NETWORK_46
 network-object object AnyConnect-Infra-LW
object-group service DM_INLINE_TCP_3 tcp
 port-object eq www
 port-object eq https
object-group protocol TCPUDP
 protocol-object udp
 protocol-object tcp
object-group service DM_INLINE_TCP_4 tcp
 port-object eq www
 port-object eq ssh
object-group service DM_INLINE_SERVICE_3
 service-object ip
 service-object object 1055
 service-object object 5057
object-group service DM_INLINE_SERVICE_4
 service-object object 4567
 service-object object 8000
 service-object object 8889
object-group service DM_INLINE_SERVICE_5
 service-object icmp
 service-object object 465
 service-object object 587
 service-object object 993
 service-object object 995
 service-object tcp destination eq imap4
 service-object tcp destination eq pop3
 service-object tcp destination eq smtp
object-group service DM_INLINE_SERVICE_10
 service-object icmp
object-group network DM_INLINE_NETWORK_13
object-group network DM_INLINE_NETWORK_23
 network-object object GCloud_10.0.2.0
 network-object object GCloud_10.0.3.0
object-group network DM_INLINE_NETWORK_24
 network-object object 10.2.0.0
object-group service DM_INLINE_SERVICE_7
 service-object tcp-udp destination eq domain
 service-object tcp destination eq ftp
 service-object tcp destination eq ftp-data
object-group service DM_INLINE_TCP_1 tcp
 port-object eq www
 port-object eq ssh
object-group service DM_INLINE_SERVICE_9
 service-object icmp
 service-object tcp destination eq domain
 service-object udp destination eq domain
object-group service DM_INLINE_SERVICE_12
 service-object icmp
 service-object object 81
object-group network DM_INLINE_NETWORK_7
 network-object object CiscoSX-20-vcs11
 network-object object CiscoSX-20-vcs12
object-group service DM_INLINE_TCP_5 tcp
 port-object eq www
 port-object eq ssh
object-group service DM_INLINE_SERVICE_8
 service-object object 990
object-group network DM_INLINE_NETWORK_8
object-group service DM_INLINE_SERVICE_14
 service-object icmp time-exceeded
 service-object icmp traceroute
 service-object icmp unreachable
 service-object icmp6 echo-reply
 service-object icmp6 time-exceeded
object-group network DM_INLINE_NETWORK_17
object-group network DM_INLINE_NETWORK_18
object-group network DM_INLINE_NETWORK_25
object-group network DM_INLINE_NETWORK_28
object-group service DM_INLINE_SERVICE_16
 service-object icmp
object-group network DM_INLINE_NETWORK_30
object-group network DM_INLINE_NETWORK_31
object-group network DM_INLINE_NETWORK_32
object-group network DM_INLINE_NETWORK_33
object-group network DM_INLINE_NETWORK_34
object-group network DM_INLINE_NETWORK_35
object-group network DM_INLINE_NETWORK_36
object-group network DM_INLINE_NETWORK_37
object-group network DM_INLINE_NETWORK_38
object-group network DM_INLINE_NETWORK_39
object-group network DM_INLINE_NETWORK_40
object-group network DM_INLINE_NETWORK_41
object-group network DM_INLINE_NETWORK_42
object-group network DM_INLINE_NETWORK_43
object-group network DM_INLINE_NETWORK_44
object-group network DM_INLINE_NETWORK_45
object-group service DM_INLINE_SERVICE_17
 service-object icmp
object-group network DM_INLINE_NETWORK_52
object-group network DM_INLINE_NETWORK_53
object-group network DM_INLINE_NETWORK_55
object-group network DM_INLINE_NETWORK_57
object-group service DM_INLINE_SERVICE_18
 service-object icmp
object-group network DM_INLINE_NETWORK_59
object-group network DM_INLINE_NETWORK_60
object-group network DM_INLINE_NETWORK_61
object-group network DM_INLINE_NETWORK_62
object-group network DM_INLINE_NETWORK_63
object-group network DM_INLINE_NETWORK_64
object-group network DM_INLINE_NETWORK_56
object-group network DM_INLINE_NETWORK_47
object-group network DM_INLINE_NETWORK_48
object-group network DM_INLINE_NETWORK_49
object-group network DM_INLINE_NETWORK_50
object-group network DM_INLINE_NETWORK_51
object-group network DM_INLINE_NETWORK_54
object-group network DM_INLINE_NETWORK_21
 network-object object NewFPMC
 network-object object CACTI
object-group network DM_INLINE_NETWORK_65
 network-object object anx-cl-agent
 network-object object anx-cl-server
object-group network DM_INLINE_NETWORK_66
object-group network DM_INLINE_NETWORK_67
object-group service DM_INLINE_SERVICE_19
 service-object object RDP_TCP
 service-object object RDP_UDP
object-group network MeetingPointGroup
 network-object host 152.206.108.34
 network-object host 177.237.78.34
 network-object host 194.224.194.106
 network-object host 194.224.194.26
 network-object host 194.224.194.66
 network-object host 194.224.194.90
 network-object host 194.224.195.250
 network-object host 195.158.111.187
 network-object host 195.158.91.167
 network-object host 195.175.18.82
 network-object host 195.175.18.94
 network-object host 195.175.65.206
 network-object host 195.175.65.98
 network-object host 195.175.66.22
 network-object host 195.235.90.122
 network-object host 195.53.118.42
 network-object host 195.53.241.210
 network-object host 195.53.245.10
 network-object host 195.53.245.26
 network-object host 195.53.245.42
 network-object host 195.53.245.58
 network-object host 195.53.245.66
 network-object host 195.76.192.154
 network-object host 195.76.202.250
 network-object host 212.156.124.154
 network-object host 213.150.169.162
 network-object host 213.4.210.58
 network-object host 213.99.25.178
 network-object host 217.125.25.164
 network-object host 5.97.200.154
 network-object host 58.137.228.98
 network-object host 77.208.19.136
 network-object host 80.106.4.130
 network-object host 80.35.254.239
 network-object host 81.192.177.170
 network-object host 81.192.226.70
 network-object host 81.192.226.74
 network-object host 81.192.233.182
 network-object host 81.192.255.66
 network-object host 81.4.137.6
 network-object host 82.178.126.74
 network-object host 82.185.206.194
 network-object host 83.110.231.119
 network-object host 83.47.23.219
 network-object host 85.114.48.210
 network-object host 85.114.55.94
 network-object host 85.114.63.186
 network-object host 85.72.43.70
 network-object host 85.72.45.148
 network-object host 87.202.120.118
 network-object host 87.202.121.134
 network-object host 87.202.121.202
 network-object host 88.10.82.55
 network-object host 88.255.153.142
 network-object host 88.255.182.188
 network-object host 88.255.249.236
 network-object host 88.255.249.244
 network-object host 88.26.236.167
 network-object host 91.73.172.150
 network-object host 94.187.31.218
 network-object host 94.91.60.210
 network-object host 95.0.103.190
 network-object host 95.0.170.134
 network-object object 190.166.237.250
 network-object object 213.249.13.46
 network-object object 213.249.49.201
 network-object object 41.187.76.33
 network-object object 41.33.102.34
 network-object object 41.33.114.210
 network-object object 41.33.124.18
 network-object object 41.33.145.242
 network-object object 41.33.48.194
 network-object object 83.235.16.9
 network-object object 97.65.24.2
object-group network DM_INLINE_NETWORK_69
object-group network DM_INLINE_NETWORK_68
object-group network DM_INLINE_NETWORK_70
object-group service DM_INLINE_SERVICE_20
 service-object object 8082
 service-object object 8083
 service-object object 8085
 service-object object 8086
 service-object object 8089
object-group network DM_INLINE_NETWORK_73
object-group network DM_INLINE_NETWORK_71
 network-object object CyberLogic
 group-object MeetingPointGroup
 network-object object CyberLogic_2
object-group network DM_INLINE_NETWORK_72
object-group network DM_INLINE_NETWORK_74
object-group service DM_INLINE_SERVICE_21
 service-object icmp
object-group network DM_INLINE_NETWORK_75
object-group network DM_INLINE_NETWORK_76
object-group service DM_INLINE_SERVICE_22
 service-object icmp
 service-object object 9200
object-group service SMB2 tcp-udp
 port-object range 137 139
 port-object eq 445
object-group network DM_INLINE_NETWORK_77
object-group service DM_INLINE_SERVICE_24
 service-object icmp
object-group network DM_INLINE_NETWORK_83
object-group network DM_INLINE_NETWORK_16
object-group network DM_INLINE_NETWORK_22
object-group network DM_INLINE_NETWORK_58
object-group network DM_INLINE_NETWORK_78
 network-object object 10.33.19.0
 network-object object 10.33.21.0
 network-object object 10.33.24.0
object-group service DM_INLINE_TCP_2 tcp
 port-object eq www
object-group network DM_INLINE_NETWORK_79
 network-object object 10.10.0.0
object-group network DM_INLINE_NETWORK_80
object-group service DM_INLINE_SERVICE_6
 service-object icmp
object-group network DM_INLINE_NETWORK_81
object-group network DM_INLINE_NETWORK_82
 network-object object FTI_10.83.41.17
 network-object object FTI_10.83.42.210
 network-object object 10.83.43.222_Bamboo
 network-object object 10.83.20.162_FTI-BI
 network-object object 10.83.20.163_FTI-BI
object-group network DM_INLINE_NETWORK_27
 network-object object InsideSRV-network-23
object-group network DM_INLINE_NETWORK_26
object-group network DM_INLINE_NETWORK_84
object-group service DM_INLINE_SERVICE_13
object-group service DM_INLINE_SERVICE_15
 service-object icmp
object-group service DM_INLINE_SERVICE_23
 service-object icmp
object-group service DM_INLINE_SERVICE_25
 service-object icmp
object-group service DM_INLINE_SERVICE_26
 service-object icmp
object-group service DM_INLINE_SERVICE_27
 service-object icmp
object-group service DM_INLINE_SERVICE_28
 service-object ip
object-group service DM_INLINE_SERVICE_29
object-group service DM_INLINE_SERVICE_30
 service-object icmp
object-group service DM_INLINE_SERVICE_31
 service-object icmp
object-group service DM_INLINE_SERVICE_32
object-group service DM_INLINE_SERVICE_33
 service-object icmp
object-group service DM_INLINE_SERVICE_34
 service-object icmp
object-group service DM_INLINE_SERVICE_35
object-group service DM_INLINE_TCP_6 tcp
 port-object eq www
 port-object eq ssh
object-group service DM_INLINE_TCP_7 tcp
 port-object eq www
object-group service DM_INLINE_TCP_8 tcp
 port-object eq www
 port-object eq ssh
object-group service DM_INLINE_TCP_9 tcp
 port-object eq www
 port-object eq ssh
object-group network DM_INLINE_NETWORK_85
object-group network DM_INLINE_NETWORK_86
object-group network DM_INLINE_NETWORK_87
object-group service DM_INLINE_SERVICE_36
 service-object icmp
object-group service DM_INLINE_SERVICE_37
 service-object icmp
object-group service DM_INLINE_SERVICE_38
 service-object icmp
object-group service DM_INLINE_SERVICE_39
 service-object icmp
object-group service DM_INLINE_SERVICE_86
object-group service DM_INLINE_SERVICE_88
object-group service DM_INLINE_TCP_10 tcp
 port-object eq www
object-group network DM_INLINE_NETWORK_88
object-group network DM_INLINE_NETWORK_89
object-group network DM_INLINE_NETWORK_90
object-group network DM_INLINE_NETWORK_91
object-group network DM_INLINE_NETWORK_92
object-group network DM_INLINE_NETWORK_100
object-group network DM_INLINE_NETWORK_101
object-group network DM_INLINE_NETWORK_102
 network-object object 192.168.222.160
 network-object object NETWORK_OBJ_192.168.194.0_23
object-group network DM_INLINE_NETWORK_103
object-group network DM_INLINE_NETWORK_104
object-group network DM_INLINE_NETWORK_105
object-group network DM_INLINE_NETWORK_106
object-group network DM_INLINE_NETWORK_107
object-group network DM_INLINE_NETWORK_108
object-group network DM_INLINE_NETWORK_93
object-group network DM_INLINE_NETWORK_94
object-group network DM_INLINE_NETWORK_95
object-group network DM_INLINE_NETWORK_96
object-group network DM_INLINE_NETWORK_97
object-group network DM_INLINE_NETWORK_98
object-group network DM_INLINE_NETWORK_99
object-group service DM_INLINE_SERVICE_40
 service-object tcp-udp destination eq www
object-group network DM_INLINE_NETWORK_109
 network-object object 192.168.222.177
object-group protocol DM_INLINE_PROTOCOL_1
 protocol-object ip
 protocol-object icmp
object-group network DM_INLINE_NETWORK_110
object-group network DM_INLINE_NETWORK_111
object-group network DM_INLINE_NETWORK_112
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_28 host 10.83.48.111
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_30 host 10.83.48.112
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_31 host 10.83.48.113
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_32 host 10.83.48.114
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_33 host 10.83.48.115
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_34 host 10.83.48.116
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_35 host 10.83.48.117
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_36 host 10.83.48.118
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_37 host 10.83.48.119
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_38 host 10.83.41.201
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_39 host 10.83.41.202
access-list To_ISPs_cryptomap_MUC01 extended permit ip 192.168.194.0 255.255.254.0 host 10.83.42.210
access-list To_ISPs_cryptomap_MUC01 extended permit ip 192.168.194.0 255.255.254.0 host 10.83.42.211
access-list To_ISPs_cryptomap_MUC01 extended permit ip 192.168.194.0 255.255.254.0 host 10.83.42.212
access-list To_ISPs_cryptomap_MUC01 extended permit ip 192.168.194.0 255.255.254.0 host 10.83.42.213
access-list To_ISPs_cryptomap_MUC01 extended permit ip 192.168.194.0 255.255.254.0 object 10.83.43.191
access-list To_ISPs_cryptomap_MUC01 extended permit ip 192.168.194.0 255.255.254.0 object 10.83.43.222_Bamboo
access-list To_ISPs_cryptomap_MUC01 extended permit ip 192.168.194.0 255.255.254.0 object-group DM_INLINE_NETWORK_26
access-list To_ISPs_cryptomap_MUC01 extended permit ip 192.168.194.0 255.255.254.0 host 10.83.41.16
access-list To_ISPs_cryptomap_MUC01 extended permit ip 192.168.194.0 255.255.254.0 host 10.83.41.17
access-list To_ISPs_cryptomap_MUC01 extended permit ip 192.168.194.0 255.255.254.0 host 10.83.41.18
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_40 host 10.83.48.121
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_41 host 10.83.48.122
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_42 host 10.83.48.123
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_43 host 10.83.48.124
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_44 host 10.83.48.125
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_45 host 10.83.48.126
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_52 object 10.83.48.19
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_53 object 10.83.48.120
access-list To_ISPs_cryptomap_MUC01 extended permit ip object-group DM_INLINE_NETWORK_72 object 10.83.48.131
access-list To_ISPs_77.65.153.254_access_in extended deny object 445 any object-group DM_INLINE_NETWORK_29
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_13 any4 object-group DM_INLINE_NETWORK_46
access-list To_ISPs_77.65.153.254_access_in extended permit ip any object 192.168.194.118
access-list To_ISPs_77.65.153.254_access_in extended permit ip object Anyconnect_Address_Pool 192.168.194.0 255.255.254.0
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_15 any host 194.213.22.129
access-list To_ISPs_77.65.153.254_access_in extended permit tcp any4 host 194.213.22.145 object-group DM_INLINE_TCP_6
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_23 any host 194.213.22.157
access-list To_ISPs_77.65.153.254_access_in extended permit tcp any host 194.213.22.143 object-group DM_INLINE_TCP_7
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_25 any host 194.213.22.151
access-list To_ISPs_77.65.153.254_access_in extended permit ip any host 194.213.22.225
access-list To_ISPs_77.65.153.254_access_in extended permit ip any host 194.213.22.203
access-list To_ISPs_77.65.153.254_access_in extended permit ip any host 194.213.22.139
access-list To_ISPs_77.65.153.254_access_in extended deny icmp any host 194.213.22.87
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_26 any host 194.213.22.121
access-list To_ISPs_77.65.153.254_access_in extended permit tcp any host 194.213.22.240 eq www
access-list To_ISPs_77.65.153.254_access_in extended permit tcp any host 194.213.22.226 object-group DM_INLINE_TCP_8
access-list To_ISPs_77.65.153.254_access_in extended deny ip any host 194.213.22.178
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_27 any host 194.213.22.68
access-list To_ISPs_77.65.153.254_access_in extended permit object 8080 any host 194.213.22.12
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_28 any host 194.213.22.140
access-list To_ISPs_77.65.153.254_access_in extended permit tcp any object acc-paysecure_public.223 object-group DM_INLINE_TCP_9
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_29 any object 194.213.22.181
access-list To_ISPs_77.65.153.254_access_in extended permit tcp any host 194.213.22.130 eq www
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_30 any object-group DM_INLINE_NETWORK_56
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_31 any host 194.213.22.165 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_32 any object-group DM_INLINE_NETWORK_83 inactive
access-list To_ISPs_77.65.153.254_access_in extended deny ip any host 194.213.22.146 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_33 any object 194.213.22.72 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object 9200 object 35.234.74.0 host 194.213.22.117 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_34 any object-group DM_INLINE_NETWORK_84 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_35 any host 194.213.22.87 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object range6k any host 194.213.22.87 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_36 any object 194.213.22.104 inactive
access-list To_ISPs_77.65.153.254_access_in extended deny ip any object 194.213.22.103 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit tcp any object 194.213.22.105 eq https inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_86 object-group DM_INLINE_NETWORK_85 object-group DM_INLINE_NETWORK_86 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object RDP_TCP object-group MeetingPointGroup object anx-cl-agent inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_88 object-group DM_INLINE_NETWORK_87 object anx-cl-server inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_37 any object 194.213.22.133 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object 27017 object 35.234.74.0 object 192.168.195.121 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object 27017 object 35.234.74.0 object 192.168.194.170 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_38 object 35.234.74.0 object NBCACC inactive
access-list To_ISPs_77.65.153.254_access_in extended permit object-group DM_INLINE_SERVICE_39 any object 194.213.22.99 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit tcp object 35.246.224.209 object 192.168.194.134 eq https inactive
access-list To_ISPs_77.65.153.254_access_in extended permit tcp any object 192.168.194.93 object-group DM_INLINE_TCP_10 inactive
access-list To_ISPs_77.65.153.254_access_in extended permit tcp object-group LogicalTrust object PCI-TEST_194.213.22.212 eq ssh inactive
access-list To_ISPs_77.65.153.254_access_in extended permit ip object 10.10.0.0 192.168.194.0 255.255.254.0
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit ip 194.213.22.0 255.255.255.0 10.117.104.0 255.255.255.0
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit ip object-group DM_INLINE_NETWORK_54 10.33.18.0 255.255.255.0
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit udp host 194.213.22.119 10.117.104.0 255.255.255.0 range 0 65535
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit tcp host 194.213.22.119 10.117.104.0 255.255.255.0 range 1 65535
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit udp host 194.213.22.119 10.33.18.0 255.255.255.0 range 0 65535
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit tcp host 194.213.22.119 10.33.18.0 255.255.255.0 range 1 65535
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit ip object-group DM_INLINE_NETWORK_47 10.117.104.0 255.255.255.0
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit ip object-group DM_INLINE_NETWORK_50 10.117.106.0 255.255.255.0
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit ip object-group DM_INLINE_NETWORK_51 10.117.105.0 255.255.255.0
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit ip 194.213.22.0 255.255.255.0 10.117.105.0 255.255.255.0
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit ip 192.168.194.0 255.255.254.0 object 10.33.20.0
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit ip object Anyconnect_Address_Pool object 10.33.20.0
access-list To_ISPs_cryptomap_Beyond-Colocation extended permit ip 194.213.22.0 255.255.255.0 object 10.33.20.0
access-list To_ISPs_cryptomap_ATM extended permit ip 10.4.0.0 255.255.0.0 194.213.22.0 255.255.255.0 inactive
access-list To_ISPs_cryptomap_ATM extended permit ip 194.213.22.0 255.255.255.0 10.5.1.0 255.255.255.0
access-list To_ISPs_cryptomap_ATM extended permit ip 194.213.22.0 255.255.255.0 10.5.143.0 255.255.255.0
access-list To_ISPs_cryptomap_ATM extended permit ip 194.213.22.0 255.255.255.0 10.6.253.0 255.255.255.0
access-list To_ISPs_cryptomap_ATM extended permit ip 194.213.22.0 255.255.255.0 10.4.0.0 255.255.0.0
access-list To_ISPs_cryptomap_ATM extended permit ip 192.168.194.0 255.255.254.0 10.6.253.0 255.255.255.0
access-list To_ISPs_cryptomap_ATM extended permit ip 192.168.194.0 255.255.254.0 10.5.1.0 255.255.255.0
access-list To_ISPs_cryptomap_ATM extended permit ip 192.168.194.0 255.255.254.0 10.5.143.0 255.255.255.0
access-list To_ISPs_cryptomap_ATM extended permit ip 192.168.194.0 255.255.254.0 10.4.0.0 255.255.0.0
access-list To_ISPs_cryptomap_ATM extended permit ip 192.168.194.0 255.255.254.0 object 10.2.0.0
access-list To_ISPs_cryptomap_ATM extended permit ip 194.213.22.0 255.255.255.0 object 10.2.0.0
access-list To_ISPs_cryptomap_AMA extended permit ip host 194.213.22.138 host 194.156.168.68 inactive
access-list To_ISPs_cryptomap_AMA extended permit ip host 194.213.22.138 host 194.156.168.69 inactive
access-list To_ISPs_cryptomap_AMA extended permit ip host 194.213.22.138 host 82.150.240.212 inactive
access-list To_ISPs_77.65.153.254_cryptomap_ATH-Office extended permit ip object-group DM_INLINE_NETWORK_27 object ATH_Office_LAN_192.168.59.0
access-list To_ISPs_cryptomap_PCI_DSS extended permit ip 194.213.22.0 255.255.255.0 10.6.1.0 255.255.255.0
access-list To_ISPs_cryptomap_PCI_DSS extended permit ip 194.213.22.0 255.255.255.0 10.6.0.0 255.255.255.0
access-list To_ISPs_cryptomap_PCI_DSS extended permit ip 194.213.22.0 255.255.255.0 10.6.254.0 255.255.255.0
access-list To_ISPs_cryptomap_PCI_DSS extended permit ip 192.168.194.0 255.255.254.0 10.6.0.0 255.255.255.0
access-list To_ISPs_cryptomap_PCI_DSS extended permit ip 192.168.194.0 255.255.254.0 10.6.1.0 255.255.255.0
access-list To_ISPs_cryptomap_PCI_DSS extended permit ip 192.168.194.0 255.255.254.0 10.6.253.0 255.255.255.0
access-list To_ISPs_cryptomap_PCI_DSS extended permit ip 192.168.194.0 255.255.254.0 10.6.254.0 255.255.255.0
access-list To_ISPs_cryptomap_ATH01 extended permit ip object CiscoSX-20-vcs11 host 10.30.2.224
access-list To_ISPs_cryptomap_ATH01 extended permit ip object CiscoSX-20-vcs12 host 10.30.2.224
access-list To_ISPs_cryptomap_ATH01 extended permit ip object CiscoSX-20-vcs11 object 10.30.2.225
access-list To_ISPs_cryptomap_ATH01 extended permit ip object CiscoSX-20-vcs12 object 10.30.2.225
access-list To_ISPs_cryptomap_BER01 extended permit ip object-group DM_INLINE_NETWORK_7 host 10.88.8.224
access-list To_ISPs_cryptomap_BER01 extended permit ip object-group DM_INLINE_NETWORK_59 host 10.88.8.225
access-list To_ISPs_cryptomap_ZRH01 extended permit ip object-group DM_INLINE_NETWORK_60 host 10.41.10.224
access-list To_ISPs_cryptomap_ZRH01 extended permit ip object-group DM_INLINE_NETWORK_61 host 10.41.10.225
access-list To_ISPs_cryptomap_DXB01 extended permit ip object-group DM_INLINE_NETWORK_8 object 10.97.2.224
access-list To_ISPs_cryptomap_DXB01 extended permit ip object-group DM_INLINE_NETWORK_66 object 10.97.2.225
access-list To_ISPs_cryptomap_DXB01 extended permit ip object-group DM_INLINE_NETWORK_67 object 10.97.2.226
access-list To_ISPs_cryptomap_AYT01 extended permit ip object-group DM_INLINE_NETWORK_48 object 10.90.0.225
access-list To_ISPs_cryptomap_AYT01 extended permit ip object-group DM_INLINE_NETWORK_62 host 10.90.0.224
access-list To_ISPs_cryptomap_MLA01 extended permit ip object-group DM_INLINE_NETWORK_63 object 10.35.2.224
access-list To_ISPs_cryptomap_MLA01 extended permit ip object-group DM_INLINE_NETWORK_55 object 10.35.2.225
access-list vpn_any_access_admin extended permit ip object-group DM_INLINE_NETWORK_3 object-group DM_INLINE_NETWORK_77
access-list InsideSRV_access_in extended deny ip object NETWORK_OBJ_192.168.194.0_23 object Serwer_Radius
access-list InsideSRV_access_in extended permit ip object-group DM_INLINE_NETWORK_21 object-group DM_INLINE_NETWORK_4
access-list InsideSRV_access_in extended permit ip object NETWORK_OBJ_192.168.194.0_23 object HITIT_ACC_129.1.20.10
access-list InsideSRV_access_in extended permit ip any4 any4
access-list management_access_in extended permit ip 192.168.254.0 255.255.255.0 192.168.194.0 255.255.254.0
access-list management_access_in extended permit ip 192.168.254.0 255.255.255.0 192.168.101.0 255.255.255.0
access-list management_access_in extended permit ip 192.168.254.0 255.255.255.0 any4
access-list management_access_in extended permit ip 192.168.254.0 255.255.255.0 object CACTI
access-list vpn_any_access_user extended permit ip object-group DM_INLINE_NETWORK_23 object-group DM_INLINE_NETWORK_73
access-list To_ISPs_access_in extended permit ip object Anyconnect_Address_Pool 192.168.194.0 255.255.254.0
access-list To_ISPs_access_in extended deny object 445 any object-group DM_INLINE_NETWORK_16
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_14 any4 object-group DM_INLINE_NETWORK_13
access-list To_ISPs_access_in extended permit ip any object 192.168.194.118
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_16 any host 194.213.22.129
access-list To_ISPs_access_in extended permit tcp any4 host 194.213.22.145 object-group DM_INLINE_TCP_1
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_17 any host 194.213.22.157
access-list To_ISPs_access_in extended permit tcp any host 194.213.22.143 object-group DM_INLINE_TCP_3
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_9 any host 194.213.22.151
access-list To_ISPs_access_in extended permit ip any host 194.213.22.225
access-list To_ISPs_access_in extended permit ip any host 194.213.22.203
access-list To_ISPs_access_in extended permit ip any host 194.213.22.139
access-list To_ISPs_access_in extended deny icmp any host 194.213.22.87
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_12 any host 194.213.22.121
access-list To_ISPs_access_in extended permit tcp any host 194.213.22.240 eq www
access-list To_ISPs_access_in extended permit tcp any host 194.213.22.226 object-group DM_INLINE_TCP_4
access-list To_ISPs_access_in extended deny ip any host 194.213.22.178
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_10 any host 194.213.22.68
access-list To_ISPs_access_in extended permit object 8080 any host 194.213.22.12
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_3 any host 194.213.22.140
access-list To_ISPs_access_in extended permit tcp any object acc-paysecure_public.223 object-group DM_INLINE_TCP_5
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_4 any object 194.213.22.181
access-list To_ISPs_access_in extended permit tcp any host 194.213.22.130 eq www
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_6 any object-group DM_INLINE_NETWORK_10
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_5 any host 194.213.22.165
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_7 any object-group DM_INLINE_NETWORK_11
access-list To_ISPs_access_in extended deny ip any host 194.213.22.146
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_11 any object 194.213.22.72
access-list To_ISPs_access_in extended permit object 9200 object 35.234.74.0 host 194.213.22.117
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_18 any object-group DM_INLINE_NETWORK_12
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_8 any host 194.213.22.87
access-list To_ISPs_access_in extended permit object range6k any host 194.213.22.87
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_2 any object 194.213.22.104
access-list To_ISPs_access_in extended deny ip any object 194.213.22.103
access-list To_ISPs_access_in extended permit tcp any object 194.213.22.105 eq https
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_40 any object 194.213.22.21
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_19 object-group DM_INLINE_NETWORK_74 object-group DM_INLINE_NETWORK_65
access-list To_ISPs_access_in extended permit object RDP_TCP object-group MeetingPointGroup object anx-cl-agent
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_20 object-group DM_INLINE_NETWORK_71 object anx-cl-server
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_21 any object 194.213.22.133
access-list To_ISPs_access_in extended permit object 27017 object 35.234.74.0 object 192.168.195.121
access-list To_ISPs_access_in extended permit object 27017 object 35.234.74.0 object 192.168.194.170
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_22 object 35.234.74.0 object NBCACC
access-list To_ISPs_access_in extended permit object-group DM_INLINE_SERVICE_24 any object 194.213.22.99
access-list To_ISPs_access_in extended permit tcp object 35.246.224.209 object 192.168.194.134 eq https
access-list To_ISPs_access_in extended permit tcp any object 192.168.194.93 object-group DM_INLINE_TCP_2
access-list To_ISPs_access_in extended permit tcp object-group LogicalTrust object PCI-TEST_194.213.22.212 eq ssh
access-list To_ISPs_access_in extended permit object-group DM_INLINE_PROTOCOL_1 object 10.2.0.0 192.168.194.0 255.255.254.0
access-list To_ISPs_cryptomap extended permit ip object NETWORK_OBJ_194.213.22.0_24 10.6.1.0 255.255.255.0
access-list vpn_acl standard permit 10.117.104.0 255.255.255.0
access-list ISPs_access_in extended permit object-group DM_INLINE_SERVICE_1 any object wheels_acc_80
access-list ISPs_access_in extended permit tcp host 151.80.35.118 host 194.213.22.145 eq https
access-list ISPs_access_in extended permit tcp host 92.43.117.104 host 194.213.22.118 eq 8088
access-list ISPs_access_in extended permit tcp any host 194.213.22.147 range 60000 60049
access-list ISPs_access_in extended permit tcp any host 194.213.22.251 range 65000 65001
access-list ISPs_access_in extended permit udp any host 194.213.22.251 range 65000 65001
access-list ISPs_access_in extended permit tcp host 87.204.125.100 host 194.213.22.204 eq ftp
access-list ISPs_access_in extended permit udp host 109.205.49.52 host 194.213.22.116 eq syslog
access-list ISPs_access_in extended permit tcp any 194.213.22.0 255.255.255.0 eq ssh
access-list ISPs_access_in extended permit ip host 194.156.168.68 194.213.22.0 255.255.255.0
access-list ISPs_access_in extended permit ip host 194.156.168.69 194.213.22.0 255.255.255.0
access-list ISPs_access_in extended permit ip host 213.70.140.105 194.213.22.0 255.255.255.0
access-list ISPs_access_in extended permit ip host 82.150.240.212 194.213.22.0 255.255.255.0
access-list ISPs_access_in extended permit tcp host 149.202.138.210 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.78.58 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.78.59 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.82.239 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.82.240 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.82.241 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.84.213 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.84.217 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.84.218 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.84.220 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.84.221 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.84.239 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.84.240 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 149.202.84.241 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 37.59.27.49 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 46.105.117.101 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 51.255.80.10 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 51.255.80.11 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 51.255.80.13 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 51.255.80.14 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 51.255.80.15 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 51.255.80.16 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 51.255.80.17 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 51.255.80.19 host 194.213.22.145
access-list ISPs_access_in extended permit tcp host 51.255.80.20 host 194.213.22.145
access-list ISPs_access_in extended permit ip host 87.105.184.224 host 194.213.22.147
access-list ISPs_access_in extended permit tcp host 51.254.128.25 host 194.213.22.150
access-list ISPs_access_in extended permit tcp host 51.254.128.61 host 194.213.22.150
access-list ISPs_access_in extended permit tcp host 51.254.128.97 host 194.213.22.150
access-list ISPs_access_in extended permit tcp host 51.254.211.50 host 194.213.22.150
access-list ISPs_access_in extended permit udp host 51.254.211.50 host 194.213.22.150
access-list ISPs_access_in extended permit tcp host 51.254.211.51 host 194.213.22.150
access-list ISPs_access_in extended permit udp host 51.254.211.51 host 194.213.22.150
access-list ISPs_access_in extended permit tcp host 51.255.160.160 host 194.213.22.150
access-list ISPs_access_in extended permit ip host 5.196.65.208 host 194.213.22.93
access-list ISPs_access_in extended permit ip host 52.58.112.76 host 194.213.22.93
access-list ISPs_access_in extended permit tcp any host 194.213.22.196 eq www
access-list ISPs_access_in extended permit tcp any host 194.213.22.196 eq https
access-list ISPs_access_in extended permit tcp any host 194.213.22.130 eq www
access-list ISPs_access_in extended permit tcp any host 194.213.22.163 eq www
access-list ISPs_access_in extended permit tcp any host 194.213.22.163 eq https
access-list ISPs_access_in extended permit tcp any host 194.213.22.164 eq www
access-list ISPs_access_in extended permit tcp any host 194.213.22.164 eq https
access-list ISPs_access_in extended permit tcp any host 194.213.22.163 eq 8098
access-list ISPs_access_in extended permit tcp any host 194.213.22.164 eq 8098
access-list ISPs_access_in extended permit tcp any host 194.213.22.163 eq 8443
access-list ISPs_access_in extended permit tcp any host 194.213.22.164 eq 8443
access-list ISPs_access_in extended permit tcp any host 194.213.22.163 eq 8099
access-list ISPs_access_in extended permit tcp any host 194.213.22.164 eq 8099
access-list ISPs_access_in extended permit tcp any host 194.213.22.117 eq 8074
access-list ISPs_access_in extended permit tcp any host 194.213.22.205 eq www
access-list ISPs_access_in extended permit tcp any host 194.213.22.205 eq https
access-list ISPs_access_in extended permit tcp any host 194.213.22.226 eq www
access-list ISPs_access_in extended permit tcp any host 194.213.22.226 eq https
access-list ISPs_access_in extended permit tcp any host 194.213.22.226 eq ssh
access-list ISPs_access_in extended permit tcp any host 194.213.22.165 eq domain
access-list ISPs_access_in extended permit tcp any host 194.213.22.111 eq 1194
access-list ISPs_access_in extended permit tcp any host 194.213.22.113 eq 3306
access-list ISPs_access_in extended permit tcp any host 194.213.22.111 eq www
access-list ISPs_access_in extended permit tcp any host 194.213.22.112 eq www
access-list ISPs_access_in extended permit tcp any host 194.213.22.111 eq 81 inactive
access-list ISPs_access_in extended permit tcp any host 194.213.22.111 eq 1022 inactive
access-list ISPs_access_in extended permit udp any host 194.213.22.3 eq 1701
access-list ISPs_access_in extended permit udp any host 194.213.22.55 eq domain
access-list ISPs_access_in extended permit udp any host 194.213.22.129 eq domain
access-list ISPs_access_in extended permit udp any host 194.213.22.147 eq domain
access-list ISPs_access_in extended permit udp any host 194.213.22.151 eq domain
access-list ISPs_access_in extended permit udp any host 194.213.22.163 eq domain
access-list ISPs_access_in extended permit udp any host 194.213.22.203 eq domain
access-list ISPs_access_in extended permit udp any host 194.213.22.154 eq domain
access-list ISPs_access_in extended permit udp any host 194.213.22.160 eq domain
access-list ISPs_access_in extended permit udp any host 194.213.22.165 eq domain
access-list ISPs_access_in extended permit udp any host 194.213.22.111 eq 1194
access-list ISPs_access_in extended permit ip any host 194.213.22.88
access-list ISPs_access_in extended permit ip any host 194.213.22.87
access-list ISPs_access_in extended permit tcp any host 194.213.22.12
access-list ISPs_access_in extended permit tcp any host 194.213.22.70
access-list ISPs_access_in extended permit tcp any host 194.213.22.71
access-list ISPs_access_in extended permit tcp any host 194.213.22.240
access-list ISPs_access_in extended permit tcp any host 194.213.22.77
access-list ISPs_access_in extended permit tcp any host 194.213.22.151
access-list ISPs_access_in extended permit ip host 193.16.240.67 194.213.22.0 255.255.255.0
access-list ISPs_access_in extended permit ip host 193.16.240.68 194.213.22.0 255.255.255.0
access-list To_ISPs_cryptomap_HER01 extended permit ip object-group DM_INLINE_NETWORK_64 object HER01
access-list ASA_to_Core_access_in extended permit ip object Serwer_Radius any
access-list ASA_to_Core_access_in extended deny ip any 192.168.254.0 255.255.255.0
access-list To_ISPs_cryptomap_GCP-3 extended permit ip object-group DM_INLINE_NETWORK_49 object GCloud_10.0.2.0
access-list To_ISPs_cryptomap_GCP-1 extended permit ip object-group DM_INLINE_NETWORK_57 object GCloud_10.0.3.0
access-list AnyConnect_Client_Local_Print extended deny ip any4 any4
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq lpd
access-list AnyConnect_Client_Local_Print remark IPP: Internet Printing Protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 631
access-list AnyConnect_Client_Local_Print remark Windows' printing port
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 9100
access-list AnyConnect_Client_Local_Print remark mDNS: multicast DNS protocol
access-list AnyConnect_Client_Local_Print extended permit udp any4 host 224.0.0.251 eq 5353
access-list AnyConnect_Client_Local_Print remark LLMNR: Link Local Multicast Name Resolution protocol
access-list AnyConnect_Client_Local_Print extended permit udp any4 host 224.0.0.252 eq 5355
access-list AnyConnect_Client_Local_Print remark TCP/NetBIOS protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 137
access-list AnyConnect_Client_Local_Print extended permit udp any4 any4 eq netbios-ns
access-list To_ISPs_cryptomap_IST01 extended permit ip object-group DM_INLINE_NETWORK_75 object 10.90.8.224
access-list To_ISPs_cryptomap_IST01 extended permit ip object-group DM_INLINE_NETWORK_76 object 10.90.8.225
access-list To_ISPs_77.65.153.254_cryptomap_1 extended permit ip 192.168.194.0 255.255.254.0 object 10.10.0.0
access-list To_ISPs_cryptomap_GCP-4 extended permit ip host 192.168.195.185 object 10.233.2.0
access-list To_ISPs_cryptomap_GCP-2 extended permit ip object 192.168.194.194 object 10.233.4.2
access-list To_ISPs_cryptomap_BeyondCloud-4 extended permit ip 192.168.194.0 255.255.254.0 object 10.33.19.0
access-list To_ISPs_77.65.153.254_cryptomap extended permit ip object-group DM_INLINE_NETWORK_111 object 10.10.0.0
access-list wifi_guest_access_in extended permit ip any any
access-list To_ISPs_cryptomap_BeyondCloud-2 extended permit ip 192.168.194.0 255.255.254.0 object 10.33.21.0
access-list To_ISPs_cryptomap_BeyondCloud-3 extended permit ip object-group DM_INLINE_NETWORK_58 object 10.33.23.0
access-list vpn_any_access_infra_lw extended permit ip object-group DM_INLINE_NETWORK_79 object AnyConnect-Infra-LW
access-list To_ISPs_cryptomap_BeyondCloud-1 extended permit ip object-group DM_INLINE_NETWORK_81 object 10.33.24.0
pager lines 24
logging enable
logging timestamp
no logging hide username
logging console informational
logging monitor informational
logging buffered debugging
logging trap informational
logging history informational
logging asdm debugging
logging mail informational
logging from-address asa-alerts@anixe.pl
logging device-id hostname
logging host InsideSRV 192.168.194.55
mtu InsideSRV 1500
mtu DMZPublic 1500
mtu Public_DMZ 1500
mtu Public2_DMZ 1500
mtu management 1500
mtu ASA_to_Core 1500
mtu wifi_guest 1500
mtu To_ISPs 1500
mtu To_ISPs_77.65.153.254 1500
mtu Public3_DMZ 1500
ip verify reverse-path interface To_ISPs
ip verify reverse-path interface To_ISPs_77.65.153.254
failover
failover lan unit primary
failover lan interface failover_int GigabitEthernet1/8
failover link statelink GigabitEthernet1/7
failover interface ip failover_int 192.168.200.1 255.255.255.0 standby 192.168.200.2
failover interface ip statelink 192.168.20.1 255.255.255.0 standby 192.168.20.2
no failover wait-disable
no monitor-interface DMZPublic
monitor-interface Public_DMZ
monitor-interface ASA_to_Core
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
icmp permit any InsideSRV
icmp permit any ASA_to_Core
icmp permit 194.181.47.128 255.255.255.240 To_ISPs
icmp permit any To_ISPs
icmp permit any To_ISPs_77.65.153.254
icmp permit 194.181.47.128 255.255.255.240 To_ISPs_77.65.153.254
asdm image disk0:/asdm-7131.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (InsideSRV,To_ISPs_77.65.153.254) source static InsideSRV-network-23 InsideSRV-network-23 destination static ATH_Office_LAN_192.168.59.0 ATH_Office_LAN_192.168.59.0
nat (InsideSRV,To_ISPs) source static InsideSRV-network-23 InsideSRV-network-23 destination static 10.2.0.0 10.2.0.0
nat (To_ISPs_77.65.153.254,ASA_to_Core) source dynamic Anyconnect_Address_Pool INSIDE_PAT_IP
nat (To_ISPs,ASA_to_Core) source dynamic Anyconnect_Address_Pool INSIDE_PAT_IP
nat (To_ISPs_77.65.153.254,To_ISPs_77.65.153.254) source dynamic DM_INLINE_NETWORK_88 INSIDE_PAT_IP destination static DM_INLINE_NETWORK_89 DM_INLINE_NETWORK_89 inactive
nat (To_ISPs,To_ISPs) source dynamic DM_INLINE_NETWORK_25 INSIDE_PAT_IP destination static DM_INLINE_NETWORK_82 DM_INLINE_NETWORK_82
nat (InsideSRV,To_ISPs_77.65.153.254) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static ATM_10.5.1.0 ATM_10.5.1.0 inactive
nat (InsideSRV,To_ISPs) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static ATM_10.5.1.0 ATM_10.5.1.0
nat (InsideSRV,To_ISPs_77.65.153.254) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static 10.4.4.254 10.4.4.254 inactive
nat (InsideSRV,To_ISPs) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static 10.4.4.254 10.4.4.254
nat (InsideSRV,Public_DMZ) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static NETWORK_OBJ_194.213.22.0_24 NETWORK_OBJ_194.213.22.0_24
nat (InsideSRV,To_ISPs_77.65.153.254) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static DM_INLINE_NETWORK_92 DM_INLINE_NETWORK_92 inactive
nat (InsideSRV,To_ISPs) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static DM_INLINE_NETWORK_14 DM_INLINE_NETWORK_14
nat (InsideSRV,To_ISPs_77.65.153.254) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static OVH_178.32.205.187 OVH_178.32.205.187 inactive
nat (InsideSRV,To_ISPs) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static OVH_178.32.205.187 OVH_178.32.205.187
nat (InsideSRV,To_ISPs_77.65.153.254) source dynamic DM_INLINE_NETWORK_93 Public_PCI-194.213.22.65 destination static DM_INLINE_NETWORK_94 DM_INLINE_NETWORK_94 inactive
nat (InsideSRV,To_ISPs) source dynamic DM_INLINE_NETWORK_5 Public_PCI-194.213.22.65 destination static DM_INLINE_NETWORK_19 DM_INLINE_NETWORK_19
nat (Public_DMZ,To_ISPs_77.65.153.254) source dynamic DM_INLINE_NETWORK_90 Public_PCI-194.213.22.65 destination static DM_INLINE_NETWORK_91 DM_INLINE_NETWORK_91 inactive
nat (Public_DMZ,To_ISPs) source dynamic DM_INLINE_NETWORK_6 Public_PCI-194.213.22.65 destination static DM_INLINE_NETWORK_20 DM_INLINE_NETWORK_20
nat (To_ISPs_77.65.153.254,To_ISPs_77.65.153.254) source dynamic DM_INLINE_NETWORK_95 193.59.39.2 destination static Beyond_Network_outside Beyond_Network_outside inactive
nat (To_ISPs,To_ISPs) source dynamic DM_INLINE_NETWORK_17 193.59.39.2 destination static Beyond_Network_outside Beyond_Network_outside
nat (InsideSRV,To_ISPs_77.65.153.254) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static DM_INLINE_NETWORK_96 DM_INLINE_NETWORK_96 inactive
nat (InsideSRV,To_ISPs) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static DM_INLINE_NETWORK_9 DM_INLINE_NETWORK_9
nat (InsideSRV,To_ISPs_77.65.153.254) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static Tap_Ebroker_91.198.90.105 Tap_Ebroker_91.198.90.105 inactive
nat (InsideSRV,To_ISPs) source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2 destination static Tap_Ebroker_91.198.90.105 Tap_Ebroker_91.198.90.105
nat (To_ISPs_77.65.153.254,To_ISPs_77.65.153.254) source dynamic DM_INLINE_NETWORK_97 INSIDE_PAT_IP destination static DM_INLINE_NETWORK_98 DM_INLINE_NETWORK_98 inactive
nat (To_ISPs,To_ISPs) source dynamic DM_INLINE_NETWORK_69 INSIDE_PAT_IP destination static DM_INLINE_NETWORK_24 DM_INLINE_NETWORK_24
nat (InsideSRV,To_ISPs_77.65.153.254) source dynamic logmachine.anixe.pl Public_194.213.22.2 inactive
nat (InsideSRV,To_ISPs) source dynamic logmachine.anixe.pl Public_194.213.22.2
nat (InsideSRV,To_ISPs_77.65.153.254) source static NETWORK_OBJ_192.168.195.142 NETWORK_OBJ_192.168.195.142 destination static RFC_10.0.0.0 RFC_10.0.0.0 no-proxy-arp inactive
nat (InsideSRV,To_ISPs_77.65.153.254) source static InsideSRV-network-23 InsideSRV-network-23 destination static 10.10.0.0 10.10.0.0
nat (To_ISPs,To_ISPs_77.65.153.254) source dynamic DM_INLINE_NETWORK_110 INSIDE_PAT_IP destination static 10.10.0.0 10.10.0.0
nat (InsideSRV,To_ISPs) source static NETWORK_OBJ_192.168.195.142 NETWORK_OBJ_192.168.195.142 destination static RFC_10.0.0.0 RFC_10.0.0.0 no-proxy-arp
nat (InsideSRV,To_ISPs_77.65.153.254) source static any any destination static RFC_10.0.0.0 RFC_10.0.0.0 unidirectional no-proxy-arp inactive
nat (InsideSRV,To_ISPs) source static any any destination static RFC_10.0.0.0 RFC_10.0.0.0 unidirectional no-proxy-arp
nat (Public_DMZ,To_ISPs_77.65.153.254) source static NETWORK_OBJ_194.213.22.0_24 NETWORK_OBJ_194.213.22.0_24 destination static DM_INLINE_NETWORK_99 DM_INLINE_NETWORK_99 no-proxy-arp route-lookup inactive
nat (Public_DMZ,To_ISPs) source static NETWORK_OBJ_194.213.22.0_24 NETWORK_OBJ_194.213.22.0_24 destination static DM_INLINE_NETWORK_1 DM_INLINE_NETWORK_1 no-proxy-arp route-lookup
nat (To_ISPs_77.65.153.254,To_ISPs_77.65.153.254) source dynamic DM_INLINE_NETWORK_100 INSIDE_PAT_IP destination static DM_INLINE_NETWORK_101 DM_INLINE_NETWORK_101 inactive
nat (To_ISPs,To_ISPs) source dynamic DM_INLINE_NETWORK_18 INSIDE_PAT_IP destination static DM_INLINE_NETWORK_78 DM_INLINE_NETWORK_78
nat (To_ISPs_77.65.153.254,Public_DMZ) source dynamic Anyconnect_Address_Pool Public_194.213.22.2 destination static acc-paysecure_public.223 acc-paysecure_public.223 inactive
nat (To_ISPs,Public_DMZ) source dynamic Anyconnect_Address_Pool Public_194.213.22.2 destination static acc-paysecure_public.223 acc-paysecure_public.223
nat (To_ISPs,To_ISPs) source dynamic DM_INLINE_NETWORK_109 INSIDE_PAT_IP destination static 10.10.0.0 10.10.0.0 inactive
nat (any,To_ISPs_77.65.153.254) source static DM_INLINE_NETWORK_27 DM_INLINE_NETWORK_27 destination static ATH_Office_LAN_192.168.59.0 ATH_Office_LAN_192.168.59.0 no-proxy-arp route-lookup
nat (To_ISPs_77.65.153.254,management) source dynamic AnyConnect-Infra-LW INSIDE_PAT_IP destination static Management_network Management_network inactive
nat (To_ISPs,management) source dynamic AnyConnect-Infra-LW INSIDE_PAT_IP destination static Management_network Management_network
nat (To_ISPs_77.65.153.254,To_ISPs_77.65.153.254) source dynamic DM_INLINE_NETWORK_103 Public_194.213.22.2
nat (To_ISPs,To_ISPs) source dynamic DM_INLINE_NETWORK_68 Public_194.213.22.2
nat (InsideSRV,To_ISPs) source dynamic NETWORK_OBJ_192.168.194.0_23 interface destination static DM_INLINE_NETWORK_15 DM_INLINE_NETWORK_15
nat (Public_DMZ,To_ISPs_77.65.153.254) source dynamic Hostmonitor_Public Public_194.213.22.2 destination static GULF_178.32.205.187 GULF_178.32.205.187 inactive
nat (Public_DMZ,To_ISPs) source dynamic Hostmonitor_Public Public_194.213.22.2 destination static GULF_178.32.205.187 GULF_178.32.205.187
nat (Public_DMZ,To_ISPs_77.65.153.254) source static NETWORK_OBJ_194.213.22.0_24 NETWORK_OBJ_194.213.22.0_24 destination static DM_INLINE_NETWORK_104 DM_INLINE_NETWORK_104 no-proxy-arp route-lookup inactive
nat (Public_DMZ,To_ISPs) source static NETWORK_OBJ_194.213.22.0_24 NETWORK_OBJ_194.213.22.0_24 destination static DM_INLINE_NETWORK_2 DM_INLINE_NETWORK_2 no-proxy-arp route-lookup
nat (Public_DMZ,To_ISPs_77.65.153.254) source static Hostmonitor_Public Public_194.213.22.2 destination static Beyond_net_109.205.52.0 Beyond_net_109.205.52.0 inactive
nat (Public_DMZ,To_ISPs) source static Hostmonitor_Public Public_194.213.22.2 destination static Beyond_net_109.205.52.0 Beyond_net_109.205.52.0
nat (Public_DMZ,To_ISPs) source dynamic Hostmonitor_Public interface
nat (Public_DMZ,To_ISPs_77.65.153.254) source static NETWORK_OBJ_194.213.22.0_24 NETWORK_OBJ_194.213.22.0_24 unidirectional no-proxy-arp inactive
nat (Public_DMZ,To_ISPs) source static NETWORK_OBJ_194.213.22.0_24 NETWORK_OBJ_194.213.22.0_24 unidirectional no-proxy-arp
nat (To_ISPs_77.65.153.254,InsideSRV) source dynamic DM_INLINE_NETWORK_105 interface destination static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23
nat (To_ISPs,InsideSRV) source dynamic DM_INLINE_NETWORK_70 interface destination static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23
nat (management,To_ISPs_77.65.153.254) source static Management_network Management_network destination static DM_INLINE_NETWORK_106 DM_INLINE_NETWORK_106 route-lookup
nat (management,To_ISPs) source static Management_network Management_network destination static DM_INLINE_NETWORK_80 DM_INLINE_NETWORK_80 route-lookup
nat (any,To_ISPs_77.65.153.254) source static NETWORK_OBJ_192.168.195.185 NETWORK_OBJ_192.168.195.185 destination static 10.233.2.0 10.233.2.0 no-proxy-arp route-lookup inactive
nat (any,To_ISPs) source static NETWORK_OBJ_192.168.195.185 NETWORK_OBJ_192.168.195.185 destination static 10.233.2.0 10.233.2.0 no-proxy-arp route-lookup
nat (any,To_ISPs_77.65.153.254) source static 192.168.194.194 192.168.194.194 destination static 10.233.4.2 10.233.4.2 no-proxy-arp route-lookup inactive
nat (any,To_ISPs) source static 192.168.194.194 192.168.194.194 destination static 10.233.4.2 10.233.4.2 no-proxy-arp route-lookup
nat (any,To_ISPs_77.65.153.254) source static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23 destination static 10.33.19.0 10.33.19.0 no-proxy-arp route-lookup inactive
nat (any,To_ISPs) source static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23 destination static 10.33.19.0 10.33.19.0 no-proxy-arp route-lookup
nat (any,To_ISPs_77.65.153.254) source static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23 destination static 10.33.21.0 10.33.21.0 no-proxy-arp route-lookup inactive
nat (any,To_ISPs) source static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23 destination static 10.33.21.0 10.33.21.0 no-proxy-arp route-lookup
nat (any,To_ISPs_77.65.153.254) source static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23 destination static 10.33.23.0 10.33.23.0 no-proxy-arp route-lookup inactive
nat (any,To_ISPs) source static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23 destination static 10.33.23.0 10.33.23.0 no-proxy-arp route-lookup
nat (ASA_to_Core,To_ISPs_77.65.153.254) source static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23 destination static DM_INLINE_NETWORK_107 DM_INLINE_NETWORK_107 no-proxy-arp route-lookup inactive
nat (ASA_to_Core,To_ISPs) source static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23 destination static DM_INLINE_NETWORK_22 DM_INLINE_NETWORK_22 no-proxy-arp route-lookup
nat (ASA_to_Core,To_ISPs_77.65.153.254) source static DM_INLINE_NETWORK_108 DM_INLINE_NETWORK_108 destination static 10.33.23.0 10.33.23.0 no-proxy-arp route-lookup inactive
nat (ASA_to_Core,To_ISPs) source static DM_INLINE_NETWORK_58 DM_INLINE_NETWORK_58 destination static 10.33.23.0 10.33.23.0 no-proxy-arp route-lookup
nat (any,To_ISPs) source static NETWORK_OBJ_192.168.194.0_23 NETWORK_OBJ_192.168.194.0_23 destination static 10.10.0.0 10.10.0.0 no-proxy-arp route-lookup inactive
object network 192.168.195.121
 nat (any,any) static 194.213.22.134 net-to-net
object network 192.168.194.170
 nat (any,any) static 194.213.22.135 net-to-net
object network NBCACC
 nat (any,any) static 194.213.22.32 net-to-net
object network Infra-Host
 nat (any,any) static 194.213.22.200 net-to-net
object network GuestsANX
 nat (wifi_guest,To_ISPs) dynamic 194.213.22.3 dns
object network 192.168.194.93
 nat (any,any) static 194.213.22.131 net-to-net
nat (ASA_to_Core,To_ISPs) after-auto source dynamic any interface
nat (InsideSRV,To_ISPs) after-auto source dynamic NETWORK_OBJ_192.168.194.0_23 Public_194.213.22.2
nat (management,To_ISPs) after-auto source dynamic Management_network interface
access-group InsideSRV_access_in in interface InsideSRV
access-group management_access_in in interface management
access-group ASA_to_Core_access_in in interface ASA_to_Core
access-group wifi_guest_access_in in interface wifi_guest
access-group To_ISPs_access_in in interface To_ISPs
access-group To_ISPs_77.65.153.254_access_in in interface To_ISPs_77.65.153.254
prefix-list bgp_in_prefix seq 5 permit 0.0.0.0/0 le 16
router bgp xxxxx
 bgp log-neighbor-changes
 address-family ipv4 unicast
  neighbor 193.59.39.241 remote-as xxxxx
  neighbor 193.59.39.241 description To_ANIXE_GBP_Router_1
  neighbor 193.59.39.241 activate
  neighbor 193.59.39.242 remote-as xxxxx
  neighbor 193.59.39.242 description To_ANIXE_GBP_Router_2
  neighbor 193.59.39.242 activate
  network 194.213.22.0
  network 193.59.39.0 mask 255.255.255.128
  network 77.65.153.0 mask 255.255.255.128
  maximum-paths 2
  maximum-paths ibgp 2
  no auto-summary
  no synchronization
 exit-address-family
route To_ISPs_77.65.153.254 62.74.200.103 255.255.255.255 77.65.153.241 1
route To_ISPs_77.65.153.254 95.211.42.219 255.255.255.255 77.65.153.241 1
route ASA_to_Core 192.168.125.0 255.255.255.224 192.168.101.254 1
route ASA_to_Core 192.168.208.0 255.255.255.0 192.168.101.254 1
route ASA_to_Core 192.168.209.0 255.255.255.0 192.168.101.254 1
route ASA_to_Core 192.168.210.0 255.255.255.0 192.168.101.254 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
aaa-server Domain_Radius protocol radius
aaa-server Domain_Radius (InsideSRV) host 192.168.194.55
 key *****
 radius-common-pw *****
aaa-server FreeRadius protocol radius
aaa-server FreeRadius (InsideSRV) host 192.168.194.100
 key *****
 authentication-port 1812
 accounting-port 1812
user-identity default-domain LOCAL
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authorization command LOCAL
aaa authorization exec LOCAL auto-enable
aaa authentication login-history
http server enable 4443
http server idle-timeout 60
http 192.168.254.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 InsideSRV
http 217.96.245.191 255.255.255.255 To_ISPs
snmp-server listen-port 162
snmp-server host management 192.168.195.128 trap community ***** version 2c udp-port 161
snmp-server location ANX HQ WRO
snmp-server contact IT Support
snmp-server community *****
snmp-server enable traps syslog
snmp-server enable traps ipsec start stop
snmp-server enable traps entity config-change cpu-temperature
snmp-server enable traps memory-threshold
snmp-server enable traps interface-threshold
snmp-server enable traps remote-access session-threshold-exceeded
snmp-server enable traps connection-limit-reached
snmp-server enable traps cpu threshold rising
snmp-server enable traps ikev2 start stop
snmp-server enable traps nat packet-discard
snmp-server enable traps config
service sw-reset-button
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ATHOffice esp-aes-256 esp-sha-hmac
crypto ipsec ikev2 ipsec-proposal LeaseWeb
 protocol esp encryption aes-256
 protocol esp integrity sha-1
crypto ipsec ikev2 ipsec-proposal ath
 protocol esp integrity sha-256
crypto ipsec ikev2 ipsec-proposal google
 protocol esp integrity sha-512
crypto ipsec ikev2 ipsec-proposal AES256-SHA1
 protocol esp encryption aes-gcm-256 aes-256
crypto ipsec ikev2 ipsec-proposal PROP-AZURE
 protocol esp integrity sha-384 sha-256 sha-1
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
 protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal BeyondCloud
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_map 2 match address To_ISPs_cryptomap_Beyond-Colocation
crypto map To_ISPs_map 2 set pfs
crypto map To_ISPs_map 2 set peer 109.205.49.52
crypto map To_ISPs_map 2 set ikev1 transform-set ESP-3DES-MD5 ESP-AES-256-SHA
crypto map To_ISPs_map 2 set security-association lifetime seconds 28800
crypto map To_ISPs_map 2 set reverse-route
crypto map To_ISPs_map 3 match address To_ISPs_cryptomap_ATM
crypto map To_ISPs_map 3 set pfs group5
crypto map To_ISPs_map 3 set peer 85.232.238.188
crypto map To_ISPs_map 3 set ikev1 transform-set ESP-AES-256-SHA
crypto map To_ISPs_map 3 set nat-t-disable
crypto map To_ISPs_map 5 match address To_ISPs_cryptomap_PCI_DSS
crypto map To_ISPs_map 5 set pfs
crypto map To_ISPs_map 5 set peer 46.229.150.206
crypto map To_ISPs_map 5 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_map 5 set security-association lifetime seconds 180
crypto map To_ISPs_map 5 set nat-t-disable
crypto map To_ISPs_map 5 set reverse-route
crypto map To_ISPs_map 6 match address To_ISPs_cryptomap_MUC01
crypto map To_ISPs_map 6 set peer 213.61.78.228
crypto map To_ISPs_map 6 set ikev1 transform-set ESP-3DES-SHA
crypto map To_ISPs_map 6 set nat-t-disable
crypto map To_ISPs_map 6 set reverse-route
crypto map To_ISPs_map 7 match address To_ISPs_cryptomap_ATH01
crypto map To_ISPs_map 7 set peer 213.249.13.46
crypto map To_ISPs_map 7 set ikev1 transform-set ESP-AES-256-SHA
crypto map To_ISPs_map 8 match address To_ISPs_cryptomap_BER01
crypto map To_ISPs_map 8 set peer 213.61.135.78
crypto map To_ISPs_map 8 set ikev1 transform-set ESP-AES-256-SHA
crypto map To_ISPs_map 9 match address To_ISPs_cryptomap_ZRH01
crypto map To_ISPs_map 9 set peer 217.192.100.82
crypto map To_ISPs_map 9 set ikev1 transform-set ESP-AES-256-SHA
crypto map To_ISPs_map 10 match address To_ISPs_cryptomap_DXB01
crypto map To_ISPs_map 10 set peer 91.73.172.150
crypto map To_ISPs_map 10 set ikev1 transform-set ESP-AES-128-SHA
crypto map To_ISPs_map 11 match address To_ISPs_cryptomap_AYT01
crypto map To_ISPs_map 11 set peer 95.0.103.190
crypto map To_ISPs_map 11 set ikev1 transform-set ESP-AES-256-SHA
crypto map To_ISPs_map 12 match address To_ISPs_cryptomap_MLA01
crypto map To_ISPs_map 12 set peer 78.133.122.98
crypto map To_ISPs_map 12 set ikev1 transform-set ESP-AES-256-SHA
crypto map To_ISPs_map 13 match address To_ISPs_cryptomap_GCP-1
crypto map To_ISPs_map 13 set peer 35.198.140.98
crypto map To_ISPs_map 13 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_map 13 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES PROP-AZURE AES256-SHA1 google
crypto map To_ISPs_map 14 match address To_ISPs_cryptomap_HER01
crypto map To_ISPs_map 14 set pfs
crypto map To_ISPs_map 14 set peer 213.249.36.6
crypto map To_ISPs_map 14 set ikev1 transform-set ESP-AES-256-SHA
crypto map To_ISPs_map 15 match address To_ISPs_cryptomap_GCP-3
crypto map To_ISPs_map 15 set peer 35.198.121.184
crypto map To_ISPs_map 15 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_map 15 set ikev2 ipsec-proposal google AES256-SHA1 PROP-AZURE DES 3DES AES AES192 AES256
crypto map To_ISPs_map 16 match address To_ISPs_cryptomap_IST01
crypto map To_ISPs_map 16 set peer 212.156.124.154
crypto map To_ISPs_map 16 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_map 16 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES PROP-AZURE AES256-SHA1 google
crypto map To_ISPs_map 18 match address To_ISPs_cryptomap_GCP-4
crypto map To_ISPs_map 18 set peer 35.234.106.215
crypto map To_ISPs_map 18 set ikev2 ipsec-proposal google AES256 AES192 AES 3DES DES AES256-SHA1
crypto map To_ISPs_map 19 match address To_ISPs_cryptomap_GCP-2
crypto map To_ISPs_map 19 set pfs
crypto map To_ISPs_map 19 set peer 35.246.169.116
crypto map To_ISPs_map 19 set ikev2 ipsec-proposal google AES256 AES192 AES 3DES DES AES256-SHA1
crypto map To_ISPs_map 19 set security-association lifetime seconds 10800
crypto map To_ISPs_map 19 set security-association lifetime kilobytes unlimited
crypto map To_ISPs_map 19 set validate-icmp-errors
crypto map To_ISPs_map 20 match address To_ISPs_cryptomap_BeyondCloud-4
crypto map To_ISPs_map 20 set pfs group5
crypto map To_ISPs_map 20 set peer 185.49.148.167
crypto map To_ISPs_map 20 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_map 20 set ikev2 ipsec-proposal google AES256-SHA1 PROP-AZURE DES 3DES AES AES192 AES256 BeyondCloud
crypto map To_ISPs_map 20 set nat-t-disable
crypto map To_ISPs_map 22 match address To_ISPs_cryptomap_BeyondCloud-2
crypto map To_ISPs_map 22 set pfs group5
crypto map To_ISPs_map 22 set peer 185.49.148.168
crypto map To_ISPs_map 22 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_map 22 set ikev2 ipsec-proposal google AES256-SHA1 PROP-AZURE DES 3DES AES AES192 AES256 BeyondCloud
crypto map To_ISPs_map 22 set nat-t-disable
crypto map To_ISPs_map 23 match address To_ISPs_cryptomap_BeyondCloud-3
crypto map To_ISPs_map 23 set pfs group5
crypto map To_ISPs_map 23 set peer 109.205.52.52
crypto map To_ISPs_map 23 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_map 23 set ikev2 ipsec-proposal google AES256-SHA1 PROP-AZURE DES 3DES AES AES192 AES256 BeyondCloud
crypto map To_ISPs_map 23 set nat-t-disable
crypto map To_ISPs_map 24 match address To_ISPs_cryptomap_BeyondCloud-1
crypto map To_ISPs_map 24 set pfs group5
crypto map To_ISPs_map 24 set peer 109.205.52.42
crypto map To_ISPs_map 24 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_map 24 set ikev2 ipsec-proposal google AES256-SHA1 PROP-AZURE DES 3DES AES AES192 AES256 BeyondCloud
crypto map To_ISPs_map 24 set nat-t-disable
crypto map To_ISPs_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map To_ISPs_map interface To_ISPs
crypto map To_ISPs_77.65.153.254_map 1 match address To_ISPs_77.65.153.254_cryptomap_ATH-Office
crypto map To_ISPs_77.65.153.254_map 1 set peer 62.74.200.103
crypto map To_ISPs_77.65.153.254_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_77.65.153.254_map 1 set ikev2 ipsec-proposal ath google AES256-SHA1 PROP-AZURE DES 3DES AES AES192 AES256
crypto map To_ISPs_77.65.153.254_map 2 match address To_ISPs_77.65.153.254_cryptomap
crypto map To_ISPs_77.65.153.254_map 2 set pfs group5
crypto map To_ISPs_77.65.153.254_map 2 set peer 95.211.42.219
crypto map To_ISPs_77.65.153.254_map 2 set ikev1 transform-set ESP-AES-256-SHA
crypto map To_ISPs_77.65.153.254_map 2 set ikev2 ipsec-proposal LeaseWeb ath google AES256-SHA1 PROP-AZURE DES 3DES AES AES192
crypto map To_ISPs_77.65.153.254_map 3 match address To_ISPs_77.65.153.254_cryptomap_1
crypto map To_ISPs_77.65.153.254_map 3 set peer 95.211.42.219
crypto map To_ISPs_77.65.153.254_map 3 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map To_ISPs_77.65.153.254_map 3 set ikev2 ipsec-proposal ath google AES256-SHA1 PROP-AZURE DES 3DES AES AES192 AES256
crypto map To_ISPs_77.65.153.254_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map To_ISPs_77.65.153.254_map interface To_ISPs_77.65.153.254
crypto ikev2 policy 1
 encryption aes-256
 integrity sha
 group 5 2
 prf sha
 lifetime seconds 86400
crypto ikev2 policy 2
 encryption aes-256 3des
 integrity sha384 sha256 sha
 group 14 5 2
 prf sha384 sha256 sha
crypto ikev2 policy 3
 encryption aes-256
 integrity sha
 group 2
 prf sha
crypto ikev2 policy 4
 encryption aes-256
 integrity sha512
 group 14
 prf sha
 lifetime seconds 36000
crypto ikev2 policy 5
 encryption aes
 integrity sha256
 group 2
 prf sha256
crypto ikev2 policy 10
 encryption aes-192
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 20
 encryption aes
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 30
 encryption 3des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 40
 encryption des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 50
 encryption aes-256
 integrity sha512
 group 14
 prf sha
crypto ikev2 policy 60
 encryption aes-256
 integrity sha256
 group 2
 prf sha
crypto ikev2 enable To_ISPs client-services port 443
crypto ikev2 enable To_ISPs_77.65.153.254 client-services port 443
crypto ikev1 enable To_ISPs
crypto ikev1 enable To_ISPs_77.65.153.254
crypto ikev1 am-disable
crypto ikev1 policy 1
 authentication pre-share
 encryption 3des
 hash sha
 group 2
 lifetime 10800
crypto ikev1 policy 5
 encryption aes-256
 hash sha
 group 5
 lifetime 28800
crypto ikev1 policy 10
 encryption aes-256
 hash sha
 group 5
 lifetime 86400
crypto ikev1 policy 20
 encryption 3des
 hash sha
 group 2
 lifetime 28800
crypto ikev1 policy 30
 encryption 3des
 hash md5
 group 2
 lifetime 86400
crypto ikev1 policy 50
 encryption 3des
 hash md5
 group 2
 lifetime 28800
crypto ikev1 policy 60
 encryption 3des
 hash md5
 group 5
 lifetime 86400
crypto ikev1 policy 80
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 120
 encryption 3des
 hash md5
 group 2
 lifetime 10800
crypto ikev1 policy 130
 encryption aes-256
 hash sha
 group 2
 lifetime 28800
crypto ikev1 policy 160
 encryption 3des
 hash sha
 group 5
 lifetime 10800
crypto ikev1 policy 200
 encryption aes
 hash sha
 group 2
 lifetime 36600
crypto ikev1 policy 220
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh stricthostkeycheck
ssh 0.0.0.0 0.0.0.0 InsideSRV
ssh 192.168.254.0 255.255.255.0 management
ssh timeout 60
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access InsideSRV
dhcpd auto_config InsideSRV
dhcpd address 172.16.1.10-172.16.1.240 wifi_guest
dhcpd dns 8.8.8.8 8.8.4.4 interface wifi_guest
dhcpd enable wifi_guest
dhcprelay server 192.168.194.55 InsideSRV
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server 91.212.242.21
ssl server-version tlsv1.2
ssl client-version tlsv1.2
ssl cipher default all
ssl cipher tlsv1 fips
ssl cipher tlsv1.1 fips
ssl cipher tlsv1.2 custom "ECDHE-ECDSA-AES256-GCM-SHA384 ECDHE-RSA-AES256-GCM-SHA384 DHE-RSA-AES256-GCM-SHA384 ECDHE-ECDSA-AES256-SHA384 ECDHE-RSA-AES256-SHA384 DHE-RSA-AES256-SHA256"
ssl cipher dtlsv1 custom "DHE-RSA-AES256-SHA DHE-RSA-AES128-SHA"
ssl dh-group group24
ssl trust-point Cisco-AnyConnect-ASA-2021
ssl trust-point Cisco-AnyConnect-ASA-2021 To_ISPs
ssl trust-point Cisco-AnyConnect-ASA-2021 To_ISPs_77.65.153.254
ssl trust-point Cisco-AnyConnect-ASA-2021 To_ISPs vpnlb-ip
ssl trust-point Cisco-AnyConnect-ASA-2021 To_ISPs_77.65.153.254 vpnlb-ip
webvpn
 enable InsideSRV
 enable To_ISPs
 hsts
  enable
  max-age 31536000
  include-sub-domains
  no preload
 anyconnect image disk0:/anyconnect-win-4.9.04043-webdeploy-k9.pkg 1 regex "Windows"
 anyconnect image disk0:/anyconnect-macos-4.9.04043-webdeploy-k9.pkg 2 regex "Intel Mac OS X"
 anyconnect image disk0:/anyconnect-linux64-4.9.04043-webdeploy-k9.pkg 3 regex "Linux"
 anyconnect enable
 tunnel-group-list enable
 cache
  no disable
 error-recovery disable
group-policy GroupPolicy_Any_Admin internal
group-policy GroupPolicy_Any_Admin attributes
 dns-server value 8.8.8.8
 vpn-tunnel-protocol ikev1 ikev2 ssl-client
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value vpn_any_access_admin
 default-domain value anixe.pl
 webvpn
  anyconnect profiles value ANIXE_VPN type user
group-policy GroupPolicy_ATM internal
group-policy GroupPolicy_ATM attributes
group-policy GroupPolicy_95.211.42.219 internal
group-policy GroupPolicy_95.211.42.219 attributes
group-policy GroupPolicy_35.198.140.98 internal
group-policy GroupPolicy_35.198.140.98 attributes
group-policy GroupPolicy_185.49.148.168 internal
group-policy GroupPolicy_185.49.148.168 attributes
group-policy GroupPolicy_185.49.148.167 internal
group-policy GroupPolicy_185.49.148.167 attributes
group-policy GroupPolicy-InfraLW internal
group-policy GroupPolicy-InfraLW attributes
 wins-server value 192.168.194.208
 dns-server value 192.168.194.201
 vpn-idle-timeout 15
 vpn-tunnel-protocol ikev2 ssl-client ssl-clientless
 default-domain value intra.anixe.pl
group-policy GroupPolicy_46.229.150.206 internal
group-policy GroupPolicy_46.229.150.206 attributes
group-policy GroupPolicy_213.249.36.6 internal
group-policy GroupPolicy_213.249.36.6 attributes
group-policy GroupPolicy_35.246.169.116 internal
group-policy GroupPolicy_35.246.169.116 attributes
group-policy GroupPolicy_AZURE internal
group-policy GroupPolicy_AZURE attributes
 vpn-tunnel-protocol l2tp-ipsec
group-policy GroupPolicy_35.234.106.215 internal
group-policy GroupPolicy_35.234.106.215 attributes
group-policy GroupPolicy_BEYOND internal
group-policy GroupPolicy_BEYOND attributes
group-policy GroupPolicy_35.198.121.184 internal
group-policy GroupPolicy_35.198.121.184 attributes
group-policy GroupPolicy_212.156.124.154 internal
group-policy GroupPolicy_212.156.124.154 attributes
group-policy GroupPolicy4 internal
group-policy GroupPolicy4 attributes
 vpn-idle-timeout 15
group-policy GroupPolicy3 internal
group-policy GroupPolicy3 attributes
group-policy GroupPolicy_62.74.200.103 internal
group-policy GroupPolicy_62.74.200.103 attributes
group-policy GroupPolicy2 internal
group-policy GroupPolicy2 attributes
 vpn-simultaneous-logins 300
 vpn-idle-timeout 15
 split-tunnel-all-dns disable
group-policy AdminVPNGroup internal
group-policy AdminVPNGroup attributes
 dns-server value 192.168.194.201 192.168.194.203
group-policy GroupPolicy_109.205.52.52 internal
group-policy GroupPolicy_109.205.52.52 attributes
group-policy GroupPolicy_109.205.52.42 internal
group-policy GroupPolicy_109.205.52.42 attributes
group-policy GroupPolicy_BER01 internal
group-policy GroupPolicy_BER01 attributes
group-policy GroupPolicy_MUC01 internal
group-policy GroupPolicy_MUC01 attributes
group-policy GroupPolicy_DXB01 internal
group-policy GroupPolicy_DXB01 attributes
group-policy GroupPolicy_AYT01 internal
group-policy GroupPolicy_AYT01 attributes
group-policy GroupPolicy_ATH01 internal
group-policy GroupPolicy_ATH01 attributes
group-policy GroupPolicy_MLA01 internal
group-policy GroupPolicy_MLA01 attributes
group-policy GroupPolicy_ZRH01 internal
group-policy GroupPolicy_ZRH01 attributes
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
 dns-server value 194.213.22.151
group-policy GroupPolicy_35.195.155.181 internal
group-policy GroupPolicy_35.195.155.181 attributes
group-policy GroupPolicy_TAP internal
group-policy GroupPolicy_TAP attributes
group-policy GroupPolicy_35.202.130.230 internal
group-policy GroupPolicy_35.202.130.230 attributes
group-policy UserVPNGroup internal
group-policy UserVPNGroup attributes
 split-tunnel-policy tunnelall
 split-tunnel-network-list value vpn_any_access_user
 webvpn
dynamic-access-policy-record DfltAccessPolicy
 vpn-group-policy UserVPNGroup
 group-lock value TunnelGroup_Admin
 service-type remote-access
tunnel-group 109.205.49.52 type ipsec-l2l
tunnel-group 109.205.49.52 general-attributes
 default-group-policy GroupPolicy_BEYOND
tunnel-group 109.205.49.52 ipsec-attributes
 ikev1 pre-shared-key *****
tunnel-group TAP type ipsec-l2l
tunnel-group TAP general-attributes
 default-group-policy GroupPolicy_TAP
tunnel-group TAP ipsec-attributes
tunnel-group 62.74.200.103 type ipsec-l2l
tunnel-group 62.74.200.103 general-attributes
 default-group-policy GroupPolicy_62.74.200.103
tunnel-group 62.74.200.103 ipsec-attributes
 ikev2 remote-authentication pre-shared-key *****
 ikev2 local-authentication pre-shared-key *****
tunnel-group 85.232.238.188 type ipsec-l2l
tunnel-group 85.232.238.188 general-attributes
 default-group-policy GroupPolicy_ATM
tunnel-group 85.232.238.188 ipsec-attributes
tunnel-group 95.211.42.219 type ipsec-l2l
tunnel-group 95.211.42.219 general-attributes
 default-group-policy GroupPolicy_95.211.42.219
tunnel-group 95.211.42.219 ipsec-attributes
tunnel-group 46.229.150.206 type ipsec-l2l
tunnel-group 46.229.150.206 general-attributes
 default-group-policy GroupPolicy_46.229.150.206
tunnel-group 46.229.150.206 ipsec-attributes
tunnel-group 213.61.78.228 type ipsec-l2l
tunnel-group 213.61.78.228 general-attributes
 default-group-policy GroupPolicy_MUC01
tunnel-group 213.61.78.228 ipsec-attributes
tunnel-group 213.249.13.46 type ipsec-l2l
tunnel-group 213.249.13.46 general-attributes
 default-group-policy GroupPolicy_ATH01
tunnel-group 213.249.13.46 ipsec-attributes
tunnel-group 213.61.135.78 type ipsec-l2l
tunnel-group 213.61.135.78 general-attributes
 default-group-policy GroupPolicy_BER01
tunnel-group 213.61.135.78 ipsec-attributes
tunnel-group 217.192.100.82 type ipsec-l2l
tunnel-group 217.192.100.82 general-attributes
 default-group-policy GroupPolicy_ZRH01
tunnel-group 217.192.100.82 ipsec-attributes
tunnel-group 91.73.172.150 type ipsec-l2l
tunnel-group 91.73.172.150 general-attributes
 default-group-policy GroupPolicy_DXB01
tunnel-group 91.73.172.150 ipsec-attributes
tunnel-group 95.0.103.190 type ipsec-l2l
tunnel-group 95.0.103.190 general-attributes
 default-group-policy GroupPolicy_AYT01
tunnel-group 95.0.103.190 ipsec-attributes
tunnel-group 78.133.122.98 type ipsec-l2l
tunnel-group 78.133.122.98 general-attributes
 default-group-policy GroupPolicy_MLA01
tunnel-group 78.133.122.98 ipsec-attributes
tunnel-group TunnelGroup_Users type remote-access
tunnel-group TunnelGroup_Users general-attributes
 address-pool AnyConnect_pool
tunnel-group TunnelGroup_Users webvpn-attributes
 group-alias Users enable
tunnel-group TunnelGroup_Admin type remote-access
tunnel-group TunnelGroup_Admin general-attributes
 secondary-authentication-server-group (InsideSRV) Domain_Radius
 default-group-policy AdminVPNGroup
tunnel-group TunnelGroup_Admin webvpn-attributes
 group-alias Admins enable
tunnel-group AnixeVPN type remote-access
tunnel-group AnixeVPN general-attributes
 authentication-server-group Domain_Radius
 default-group-policy GroupPolicy4
tunnel-group AnixeVPN webvpn-attributes
 group-alias vpnanixe enable
tunnel-group 40.114.144.209 type ipsec-l2l
tunnel-group 40.114.144.209 general-attributes
 default-group-policy GroupPolicy_AZURE
tunnel-group 40.114.144.209 ipsec-attributes
tunnel-group 35.195.155.181 type ipsec-l2l
tunnel-group 35.195.155.181 general-attributes
 default-group-policy GroupPolicy_35.195.155.181
tunnel-group 35.195.155.181 ipsec-attributes
tunnel-group 213.249.36.6 type ipsec-l2l
tunnel-group 213.249.36.6 general-attributes
 default-group-policy GroupPolicy_213.249.36.6
tunnel-group 213.249.36.6 ipsec-attributes
tunnel-group 35.198.121.184 type ipsec-l2l
tunnel-group 35.198.121.184 general-attributes
 default-group-policy GroupPolicy_35.198.121.184
tunnel-group 35.198.121.184 ipsec-attributes
tunnel-group 35.198.140.98 type ipsec-l2l
tunnel-group 35.198.140.98 general-attributes
 default-group-policy GroupPolicy_35.198.140.98
tunnel-group 35.198.140.98 ipsec-attributes
tunnel-group 109.205.52.52 type ipsec-l2l
tunnel-group 109.205.52.52 general-attributes
 default-group-policy GroupPolicy_109.205.52.52
tunnel-group 109.205.52.52 ipsec-attributes
tunnel-group 212.156.124.154 type ipsec-l2l
tunnel-group 212.156.124.154 general-attributes
 default-group-policy GroupPolicy_212.156.124.154
tunnel-group 212.156.124.154 ipsec-attributes
tunnel-group 35.234.106.215 type ipsec-l2l
tunnel-group 35.234.106.215 general-attributes
 default-group-policy GroupPolicy_35.234.106.215
tunnel-group 35.234.106.215 ipsec-attributes
tunnel-group 35.246.169.116 type ipsec-l2l
tunnel-group 35.246.169.116 general-attributes
 default-group-policy GroupPolicy_35.246.169.116
tunnel-group 35.246.169.116 ipsec-attributes
tunnel-group 185.49.148.167 type ipsec-l2l
tunnel-group 185.49.148.167 general-attributes
 default-group-policy GroupPolicy_185.49.148.167
tunnel-group 185.49.148.167 ipsec-attributes
tunnel-group 185.49.148.168 type ipsec-l2l
tunnel-group 185.49.148.168 general-attributes
 default-group-policy GroupPolicy_185.49.148.168
tunnel-group 185.49.148.168 ipsec-attributes
tunnel-group TunnelGroup1 type remote-access
tunnel-group TunnelGroup1 general-attributes
 address-pool PG_AnyConnect_pool
 secondary-authentication-server-group FreeRadius
 default-group-policy GroupPolicy3
tunnel-group TunnelGroup1 webvpn-attributes
 group-alias ANIXE-PG enable
tunnel-group Infra-LW type remote-access
tunnel-group Infra-LW general-attributes
 address-pool Any_INFRA_LW
 default-group-policy GroupPolicy-InfraLW
tunnel-group Infra-LW webvpn-attributes
 group-alias INFRA-LAN-LW enable
tunnel-group 109.205.52.42 type ipsec-l2l
tunnel-group 109.205.52.42 general-attributes
 default-group-policy GroupPolicy_109.205.52.42
tunnel-group 109.205.52.42 ipsec-attributes
class-map sfr
 match access-list sfr_redirect
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect icmp error
  inspect ipsec-pass-thru
 class sfr
  sfr fail-open
 class class-default
  user-statistics accounting
service-policy global_policy global
privilege cmd level 3 mode exec command perfmon
privilege cmd level 5 mode exec command more
privilege cmd level 5 mode exec command dir
privilege cmd level 3 mode exec command ping
privilege cmd level 3 mode exec command who
privilege cmd level 3 mode exec command logging
privilege cmd level 3 mode exec command failover
privilege cmd level 3 mode exec command vpn-sessiondb
privilege cmd level 3 mode exec command packet-tracer
privilege cmd level 5 mode exec command export
privilege show level 5 mode exec command import
privilege show level 5 mode exec command running-config
privilege show level 3 mode exec command reload
privilege show level 3 mode exec command mode
privilege show level 3 mode exec command firewall
privilege show level 3 mode exec command asp
privilege show level 3 mode exec command cpu
privilege show level 3 mode exec command interface
privilege show level 3 mode exec command clock
privilege show level 3 mode exec command dns-hosts
privilege show level 3 mode exec command access-list
privilege show level 3 mode exec command logging
privilege show level 3 mode exec command vlan
privilege show level 3 mode exec command ip
privilege show level 3 mode exec command failover
privilege show level 3 mode exec command asdm
privilege show level 3 mode exec command arp
privilege show level 3 mode exec command ipv6
privilege show level 3 mode exec command route
privilege show level 3 mode exec command aaa-server
privilege show level 3 mode exec command crypto
privilege show level 3 mode exec command ssh
privilege show level 3 mode exec command vpn-sessiondb
privilege show level 3 mode exec command dhcpd
privilege show level 3 mode exec command blocks
privilege show level 3 mode exec command wccp
privilege show level 3 mode exec command dynamic-filter
privilege show level 3 mode exec command webvpn
privilege show level 3 mode exec command service-policy
privilege show level 3 mode exec command module
privilege show level 3 mode exec command uauth
privilege show level 3 mode exec command compression
privilege show level 3 mode exec command ospf
privilege show level 3 mode exec command eigrp
privilege show level 3 mode configure command interface
privilege show level 3 mode configure command clock
privilege show level 3 mode configure command access-list
privilege show level 3 mode configure command logging
privilege show level 3 mode configure command ip
privilege show level 3 mode configure command failover
privilege show level 5 mode configure command asdm
privilege show level 3 mode configure command arp
privilege show level 3 mode configure command route
privilege show level 3 mode configure command aaa-server
privilege show level 3 mode configure command crypto
privilege show level 3 mode configure command ssh
privilege show level 3 mode configure command dhcpd
privilege show level 5 mode configure command privilege
privilege clear level 3 mode exec command crypto
privilege clear level 3 mode exec command dns-hosts
privilege clear level 3 mode exec command logging
privilege clear level 3 mode exec command arp
privilege clear level 3 mode exec command aaa-server
privilege clear level 3 mode exec command dynamic-filter
privilege cmd level 3 mode configure command failover
privilege clear level 3 mode configure command logging
privilege clear level 3 mode configure command crypto
privilege clear level 3 mode configure command arp
privilege clear level 3 mode configure command aaa-server
prompt hostname context
no call-home reporting anonymous
hpm topN enable
Cryptochecksum:1f9cc4bdf49ca37dc1b62f2626ee6b5c
: end
Interface1 = To_ISPs 193.59.39.254
Interface2 = To_ISPs_77.65.153.254
Int2 is a new interface which I'm using to migrate the VPN's, but default routing is set on Int1
I don't know the remote networks, but I'd expect a NAT rule similar to this rule below (just replace the objects I've defined in the example).
nat (To_ISPs,To_ISPs_77.65.153.254) source static RAVPN-NET RAVPN-NET destination static REMOTE-NET REMOTE-NET no-proxy
If that doesn't work run packet-tracer from the CLI to determine the cause.
