ASA- Connection timeout per session
nuria.andres
I want to fix a connection timeout for a concrete rule. I know that I can modify the timeouts for all the connections (in the section Properties/Timeouts), but I don?t know if I can modify only for one connection.
Thank you very much
Best Regards
Nuria
b.hsu
Level 11
Level 11
It can be done using the access list configuration for a particualr session.Default timeout value is 1 hour for all tcp sessions.Refer
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080624e19.shtml for more information
