ASA failover active/standby inside and outside configuration
Justin Pascal
Hi all,
Im following this document:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#lanbas
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/ha_active_standby.html#wp1097252
the scenario I have is the following:
Cisco VCS -inside- ASA-a -outside- Cisco VCS-E
                  1.1.1.1         2.2.2.1
I'm planning to configure active/standby with failover link crossover cable.
If I add a second ASA
It will be linke this:
                  1.1.1.2 ASA-b 2.2.2.2
                                | 10.10.10.2 (stateful link)
                                | 10.10.10.1
                  1.1.1.1         2.2.2.1
From document it only uses the outside interface.
[Question]
Do i need to specify my internal IP address to do failover as well?
From DOC:
In this example, the outside interface of the primary PIX is configured this way
hostname(config-if)#ip address 172.16.1.1 255.255.0.0 standby 172.16.1.2
Here, 172.16.1.1 is used for the primary unit outside interface IP address, and 172.16.1.2 assigns to the secondary (standby) unit outside interface.
rleivaoc
By default, all interfaces are monitored. Which menas all enabled interfaces need an standby IP address. I hope this helps.
Rafael
