ASA failover did not work
pratik_193
I am having ASA 5520 with active/standby configured. Around 2 days ago, the ASA stopped responding & all of my websites stopped working. when i checked the failover status it said that failover is off. I had to manually turn the failover to start my traffic flow.During this time my secondary ASA was not responding. After some time, the primary stopped responding & secondary became active......to solve this i had to make the secondary unit as failover unit primary & the primary unit as failover unit secondary.
i did get a log on ASA :-
“(Primary) Disabling Failover” with error message no.105001 which states the below:-
             Error Message %PIX|ASA-1-105001: (Primary) Disabling failover.
Explanation In version 7.x and later, this message may indicate the following: failover has been automatically disabled because of a mode mismatch (single or multiple), a license mismatch (encryption or context), or a hardware difference (one unit has an IPS SSM installed, and its peer has a CSC SSM installed).(Primary) can also be listed as (Secondary) for the secondary unit.
Also i am attaching the logs captured during the incident.
I just want to know that why did the failover turned OFF.
Pratik
Jennifer Halim
Please share the output of the following from both ASA:
- show version
- show int ip brief
Also check that the failover interface is up on both ASA.
