ASA: How to block specific IP addrs from Inside->Outside
goodwinscott
(ASA5520 v8.0(4)23)
Need a strategy recommendation on the best way to block access to specific (public) IP addresses from access by Inside hosts. Presently we have no access list rules for Inside>Outside, unlike our DMZ where these permissions are very granular.
What's the best way to do this without having to create a long list of rules to define Inside->Outside traffic?
srue
Level 7
Level 7
if you know which outside hosts need blocked from inside hosts you can either create the ACL ingress on the inside interface, or egress on the outside interface.
This would be a good place to use object-groups.
Collin Clark
Most security conscience firms do have a long list of ACE on the inside interface. Another option is to use a proxy server. It's easier to filter on content than by ever changing IP's. If th list is small you could use regex.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080940e04.shtml
Hope that helps.
