ASA Interface issue
virendra pathak
Level 4
Level 4
Dear Team,
As per attached topology attached, i would like to map ASA port eth 0 and eth 1 in INSIDE interface ?
How shall i achieve this design ? Is it possible ?
regards
Virendra p
balaji.bandi
Are you looking to separate the network, what is the goal here as Firewall -
if " i would like to map ASA port eth 0 and eth 1 in INSIDE interface ? "
If you looking DC firewall to be transparent mode - may be worth looking below example (this is my just guess what you trying to achieve)
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/110740-asafailover-transparent-mode.html
BB
Why would you want to do that? I think the only option to do it would be to create a bridge interface and place eth0 and eth1 in that bridge group, but that means both interfaces will need to be on the same subnet.
