ASA load balance per destination
gaboughanem
I have an ASA with version 8.4.4.1 connected via a switch to two routers and I have two default routes on the ASA pointing to the two routers.
The question is : Does the ASA load balance the traffic onto the two routers per-destination or per-packet?
As in routers, CEF load balances the connection per-destination by default. So, what about the ASA regardless of  the hardware.
George
mwinnett
Level 3
Level 3
No. Everything will go to lowest cost route. Matthew
