ASA Management interface remote connection
xayavongp
Level 3
Level 3
The management interface needs to be on the same subnet as the inside interface.
Is it possible to specify the management default gateway to the inside ? Will the ASA v 8.0 like this at all ?
The management interface will be remotely manage [from outside] and unfortunately the back end is all layer 2.
route management 0.0.0.0 0.0.0.0 <inside ip address of ASA>
I was also  thinking about pointing it to the layer 2 device ( which should have a DG to the ASA inside interface) ...
Pete
Julio Carvajal
It is not, each interface of the ASA needs to be on it's own broadcast domain ( unless you are running transparent mode)
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Julio Carvajal
Julio Carvajal
Ok.  I guess that makes sense.  I thought having the "management-only" command treated the interface differently.
We will have to re-design this somehow.
