ASA Management interface remote connection
xayavongp
The management interface needs to be on the same subnet as the inside interface.
Is it possible to specify the management default gateway to the inside ? Will the ASA v 8.0 like this at all ?
The management interface will be remotely manage [from outside] and unfortunately the back end is all layer 2.
route management 0.0.0.0 0.0.0.0 <inside ip address of ASA>
I was also  thinking about pointing it to the layer 2 device ( which should have a DG to the ASA inside interface) ...
Pete
Julio Carvajal
It is not, each interface of the ASA needs to be on it's own broadcast domain ( unless you are running transparent mode)
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Julio Carvajal
Julio Carvajal
Ok.  I guess that makes sense.  I thought having the "management-only" command treated the interface differently.
We will have to re-design this somehow.
