ASA Multicast routing help please
ksherwood
Level 3
Level 3
Hello all,
                 I have two ASA connected together and can't seem to get a multicast stream out the other end.
There are so many options I am confused on what to use.
Here is my network:           Source  --> outside-ASA1-inside  -->  ouside-ASA2-inside  -> destination
I want the stream to be seen on ASA2 inside but it doesn't get there !
What minimal commands do I need to effect this other than "multicast-routing" ?
Can someone please help me configure both ASA with source sending 224.1.1.1  (make up IPs on all interfaces)
Thanks in advance.
5 Replies 5
Andre Neethling
Level 9
Level 9
Do you have Access Rules allowing the Multicast traffic on both ASAs in both directions? Are you trying to enable something Specific like BGP?
Hi Andre, I tried to simplify things first so I used "permit IP any any". No specific routing enabled, just the simple mcast stream required. So can you give me a quick template with made up addressing for both ASAs. I just need the minimal config to give me confidence to proceed.
Thanks.
Hi. Can you please post the config of both ASAs?
You can try to permit the entire Multicast range of 224.0.0.0/12 through all interfaces in both directions the stream will flow through.
I've got this:
1st ASA
multicast-routing
interface GigabitEthernet0/0
 nameif outside
 security-level 0
 ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet0/1
 nameif inside
 security-level 100
 ip address 192.168.10.1 255.255.255.0
access-list mcastallowed extended permit udp any host 239.1.1.1
access-group mcastallowed in interface outside
route inside 0.0.0.0 0.0.0.0 192.168.10.2 1
2nd ASA
multicast-routing
 nameif outside
 security-level 0
 ip address 192.168.10.2 255.255.255.0
 igmp join-group 239.1.1.1
 nameif inside
 security-level 50
 ip address 192.168.11.1 255.255.255.0
 igmp forward interface outside
route outside  131.1.1.0 255.255.255.0 192.168.10.1 1
