ASA - OSPF routes Sync issue between Active and standby unit
itsecsupport
I'm facing an issue with our ASA 5500. I have configured ASA in Active/Standby mode, but OSPF routes are not getting synchronized to standby unit. Is there any way to have OSPF routes sync between Active and standby unit in ASA 5500.
Thank you for your help on my querry. But any other solution to have less outage. Currently I'm getting 11 timed outs if I ping to ASA active interface from any other OSPF routed network.
The only way to reduce the outage is to drop the idea of dynamic routing on the firewall and make it with static routing. On the network components you will have to configure HSRP to make your design fully HA.
