ASA problem updating ip address of the management interface
cuelate21
I need to change the ip address of the management interface but I can´t.
I have this error when I try in ASDM:
assertion "t->stack[0] == STKINIT" failed: file "thread.c" line 743
I see the error in the console.
ASA 5505
ASA: 8.2(1)
ASDM: 6.2 (1)
thanks a lot.
6 Replies 6
How are you making the change?
interface NAME
  no ip address
  ip address NEW_ADDRESS ???
Federico.
I make the change in ASDM.
thanks
Can you make the change via the Command-Line?
Just to make sure it works... might be an issue with ASDM...
Federico.
Yes, with command line works.
I think is a Resolved Caveats in Version 8.3  "CSCtd15605"  . But I haven 8.2 and I don´t know how to update becauses my account haven´t got enought privilege to downloads IOS.
thanks a lot
To upgrade to 8.3 you need to make sure the ASA has the enough memory.
There are heavy configuration changes, so I'll recommend you yo go over the release notes prior the upgrade.
If you have a SmartNet for the ASA or some sort of contract you should be able to download images.
Federico.
The asa has 512 MB and 128 MB flash.
I don´t hace SmartNet but the firewall is new...
The only legal way  to getIOS is paying?
thanks a lot.
