ASA running on 4100 chassi with FXOS - Smart license question
Chess Norris
Level 4
Level 4
Does someome know the license process when running ASA code on a 4100 chassi?
I understand that the license method is a bit different comparing when you run ASA code on smaller firewalls, like the 2100 with built-in FXOS, but the documentation is a bit vague about the process to register the device.
Should I register the token in chassis manager or in the FXOS CLI? Do I need to register the tooken in the ASA cli as well?
/Chess
You should register the token within the chassis manager GUI.  There is no need to register within the ASA CLI.  The FX-OS handles all of that.
5 Replies 5
Thanks. I was just reading this document  https://www.cisco.com/c/en/us/td/docs/security/asa/asa919/configuration/general/asa-919-general-config/intro-license-smart.html#id_54456 and if I understandt it correct, I need to add the ASA feature tier licens from the ASA CLI. For example if I want to add a multicontext license. Is this correct?
/Chess
Correct you specify the “features” within the ASA CLI. The FX-OS handles the token, registration, etc.
Why ASA software though? Why not FTD?
Thank you @ahollifield We were able to register FX-OS to the smart portal and also add the required features on the ASA.
The customer is running over 200 contexts, so unfortunately FTD is not an option in this case.
/Chess
Yikes!  That sounds like a nightmare.
