ASA smtp and pop3 problem
Farooq Muhammad
Hi all !
I am new in security and am facing a problem for testing asa 5510 to allow smtp and pop3 both using their standard ports .My first question is that is it necessary to configure NAT if i am using private addresses in my scenario both inside and outside ? which IMO is not necessary.
The visio diag is attached to elaborate the scenario when the firewall is not installed all users can successfully connect to the mail server.but when the firewall is brought in all stops.
I have configured the asa to allow only smtp and pop3  without nat and also tried to use esmtp option given in the cisco example document but still not working.
ip add of the server is 172.16.0.2/28
ip add of int e 0/0 of asa 172.16.0.14/28
ip add of e 0/1 of asa 172.16.0.29/30
ip add of fa 0/1 of layer 3 sw is 172.16.0.30/30  it is ospf enabled
on the firewall i have configured a default route to pointing to 172.16.0.30 so reachability is not an issue
the ACL IS
access-list SMTP-POP3 extended permit tcp any host 172.16.0.2 eq smtp
access-list SMTP-POP3 exteended permit tcp any host 172.16.0.2 eq pop3
access-grou[ smtp in int outside      ----------> e 0/1
also tried
no inspect esmtp     but still not working
PLZ  HELP !
Regards.
7 Replies 7
cadet alain
the machine trying to reach the server is on e0/1 side? which security level has this interface? if it is lower than e0/0 then you need to put the ACL inbound on this interface and not on the inside interface.
Regards.
Alain
yes ,  cadet alian !
The machine trying to reach the server is on e0/1 which is nameif out side and has a security level of Zero
where as  the server is attached to the e0/0  nameif in side and  security level of  100. The scenario is similar to cisco document id 70031.
then if nat-control is disabled( OS version >7.1 and < 8.3) , get rid of the access-list on inside interface and put it on outside interface and it shall work.
Regards.
Alain
HI,
i havn't configured any thing related to NAT and have not noted if nat-control is disabled or not so i will check it and will update you but in my original post i have asked is it necessary to configure NAT if i do not need to transition from private to public addresses in the context of asa.
Thanks for your help and prompt replies.
Hi cadet alain,
configuring    no nat-control
didn't work still the same problem and unable to connect to mail server.
post the output of this command:
packet-tracer input outside tcp x.x.x.x 2000 172.16.0.2 110  where x.x.x.x is the IP address of the PC trying to reach the server
Can you also post your sanitized running config from all L3 devices.
Regards.
Alain
no, it is not necessary to configure NAT.
Regards.
Alain
