ASA stub multicast routing Stub Multicast Routing and Forwarding IGMP Messages
plao
I can't seem to find where in ASDM (6.4.1), can we configure IGMP forwarding?
ASA5520(config-if)# igmp forward interface outside
The ASDM doc reference does not seem to be correct pointing to:
Configuring Stub Multicast Routing
    Step 1 In the main ASDM window, choose Configuration > Device Setup > Routing > Multicast > IGMP.
Step 2 In the Multicast pane, check the Enable Multicast routing check box.
Step 3 Choose MForwarding.
which generates:
ASA5520(config-if)# mfib forwarding
2 Accepted Solutions
Ronaldo Renato Punzalan
The instructions above is specific to the "mfib forwarding" command. We may need to correct our documentation.
If you are looking for the "igmp forward .." command, go to Configuration -> Device Setup -> Routing -> Multicast -> Protocol. Select the interface where you want the command and click the Edit button. On the pop-up page, it will have a portion for "Forward Interface" pulldown menu. Select there the interface where you want the target interface for the igmp forwarding.
Give that a shot.
-ron
If you want to see the error message, start adding "Rendezvous Points" both on the ASDM and CLI while the igmp forward is enabled on any interface.
Enabling or disabling PIM on the interface doesn't trigger the sanity checking.
Give that a shot.
-ron
thank you very much!!
one more thing I notice, in ASDM, even though, Configuration -> Device Setup -> Routing -> Multicast -> PIM > protocol shows PIM enabled on the interfaces, I am still be able to configure igmp forwarding from Configuration -> Device Setup -> Routing -> Multicast -> Protocol.
SImiarly, in CLI, I am not sure what are the exact conditions that will cause this error message when I enabled IGMP forwarding? It seems to be inconsistent now:
%Error: PIM-SM/Bidir and IGMP forwarding are not supported concurrently
Thanks again
Pat
THANKS AGAIN!!!!!!!!!!!!
