ASA: UDP Flow: Silent Packet Drop after a Week (Bacnet/IP)...
benoitbegin0
Here is the setup: Cisco ASA 5510 (Security Plus) 7.2(3) connected in a hub-and-spoke setup in IPSec site-to-site VPN with 5 sites, each one with Cisco 877 routers. The sites have HVAC equipments connected to them talking Bacnet/IP. The central site have a Bacnet/IP "router" behind the Cisco ASA 5510. Bacnet/IP communications are always on UDP/47808 (source and destination).
Everything runs smoothly for about a week. Past 1 week, obscur packet drop occurs. We are not able to understand why. The (temporary) solution is to flush the flow that the UDP communication is using with the command "clear local-host <IP address of Bacnet/IP router>". Once this is done, everything runs smoothly for another week. We do not think it would be related to VPN. Very weird.
oszkari
Have you any UDP flow limit set on the ASA?
How many active udp flows do you have to the Bacnet/IP router in the moment when the problem appears?
There is no UDP flow limit configured on this firewall:
asa-hvac# sh local-host router-bacnet
Interface inside: 3 active, 8 maximum active, 0 denied
local host: ,
TCP flow count/limit = 0/unlimited
TCP embryonic count to host = 0
TCP intercept watermark = unlimited
UDP flow count/limit = 2/unlimited
Conn:
UDP out ctrl-delta-maniwaki:47808 in router-bacnet:47808 idle 0:00:15 flags -
UDP out ctrl-delta-laurentienne:47808 in router-bacnet:47808 idle 0:00:00 flags -
Interface outside: 15 active, 33 maximum active, 0 denied
To answer your second question, when the problem appear, there is the same 2 flows when I issue the "show local-host bacnet-router" command.
hmm..
Have you tried ipsec over tcp?
With udp strange things could happen sometimes...
right now i don't have better ideas:)
sam.vandevelde
Did you ever solve this problem?
I'm experiencing the same problem between a ASA 5510 (8.2) and a ASA 5510 (8.0). Using the command "clear local-host " on the 8.0-version restores the UDP-communication for about a week.
