ASA with AIP-SSM-20 Module Problem
uzair.infotech
I have ASA5520 with AIP-SSM-20 module using to protect my department. My outside interface is connected to my company IT network. I need auto update for IPS signature. My IT department provide me a Ip on which internet access is open is 172.16.21.129 from outside subnet with proxy Ip 172.16.1.20. I need to configure this Ip on my ASA so my IPS can download signature automatically.
My question is where I put these Ip and proxy address on my ASA.Should I configure it on my IPS mgmt interface and connected that interface on same van of my outside interface?  Please help.
Uzair Hussain
uzair.infotech
My inside interface 172.19.x. x
Outside interface 172.16.x. x
Dmz interface 172.17.x. x
The IPS-module communicates with the dedicated SSM-management-port with the outer world. You can either:
  • connect the SSM-port to your outside network and provide an authorized outside IP-config.
  • connect the SSM-port to your internal network with an internal IP and translate this IP to the authorized IP on the outside.
I would prefer the second option.
