ASA5505 - Need help with port forwarding
northernlight
Hi everyone,
I have been struggling to get port forwarding to work on my ASA5505.
So far I have setup an ACL to permit the port traffic and NAT rule to forward to port to the specific host.
Packet tracer in the ASDM shows that the packet is allowed. However when I test using the below powershell command :
tnc  [ASA outside interface address] -port [port number]
it shows that the connection to the port is failed. ASDM syslog doesnt even have logged the tcp connnection try.
ASA Version : 9.2(4)33
ASDM Version : 7.9(2)152
after looking at the packet tracer log and looking at your nat order if seems you have a nat order issue. VPN-Server rule should be in section 1
ciscoasa(config)# show nat
Manual NAT Policies (Section 1)
1 (Lab_Outside_Gateway) to (WAN) source dynamic any interface
    translate_hits = 28304, untranslate_hits = 815
2 (Lab_Host_Network) to (WAN) source dynamic any interface
    translate_hits = 18387, untranslate_hits = 172
3 (Home_Network_1_Gateway) to (WAN) source dynamic any interface
    translate_hits = 73636, untranslate_hits = 729
4 (Home_Network_2_Gateway) to (WAN) source dynamic any interface
    translate_hits = 59292, untranslate_hits = 11423
5 (WAN) to (Lab_Outside_Gateway) source dynamic any interface
    translate_hits = 9, untranslate_hits = 0
Auto NAT Policies (Section 2)
1 (Lab_Outside_Gateway) to (WAN) source static VPN-Server interface   service tcp 1701 1701
    translate_hits = 0, untranslate_hits = 0
please do not forget to rate.
15 Replies 15
Post your CLI config and we can check.
Here is the config. Thanks.
ASA Version 9.2(4)33
interface Ethernet0/0
switchport access vlan 10
interface Ethernet0/1
switchport access vlan 11
interface Ethernet0/2
switchport access vlan 12
interface Ethernet0/3
switchport access vlan 13
interface Ethernet0/4
switchport access vlan 14
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan10
nameif WAN
security-level 0
ip address dhcp setroute
interface Vlan11
nameif Lab_Outside_Gateway
security-level 100
ip address 10.0.255.254 255.255.255.0
interface Vlan12
nameif Home_Network_1_Gateway
security-level 90
ip address 172.31.255.254 255.255.255.0
interface Vlan13
nameif Home_Network_2_Gateway
security-level 10
ip address 192.168.255.254 255.255.255.0
interface Vlan14
nameif Lab_Host_Network
security-level 100
ip address 10.0.0.254 255.255.255.0
ftp mode passive
clock timezone HKST 8
dns server-group DefaultDNS
same-security-traffic permit inter-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network VPN-Server
host 10.0.78.250
object service VPN-Service-Port-3
service tcp destination eq 1701
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list WAN_access_in extended permit icmp any 10.0.0.0 255.255.255.0
access-list WAN_access_in extended permit icmp any 10.0.255.0 255.255.255.0
access-list WAN_access_in extended permit icmp any 172.31.255.0 255.255.255.0
access-list WAN_access_in extended permit icmp any 192.168.255.0 255.255.255.0
access-list WAN_access_in extended permit object VPN-Service-Port-3 any object VPN-Server
access-list AnyConnect_Client_Local_Print extended deny ip any4 any4
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq lpd
access-list AnyConnect_Client_Local_Print remark IPP: Internet Printing Protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 631
access-list AnyConnect_Client_Local_Print remark Windows' printing port
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 9100
access-list AnyConnect_Client_Local_Print remark mDNS: multicast DNS protocol
access-list AnyConnect_Client_Local_Print extended permit udp any4 host 224.0.0.251 eq 5353
access-list AnyConnect_Client_Local_Print remark LLMNR: Link Local Multicast Name Resolution protocol
access-list AnyConnect_Client_Local_Print extended permit udp any4 host 224.0.0.252 eq 5355
access-list AnyConnect_Client_Local_Print remark TCP/NetBIOS protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 137
access-list AnyConnect_Client_Local_Print extended permit udp any4 any4 eq netbios-ns
pager lines 24
logging enable
logging asdm informational
mtu Lab_Outside_Gateway 1500
mtu Home_Network_1_Gateway 1500
mtu Lab_Host_Network 1500
mtu WAN 1500
mtu Home_Network_2_Gateway 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (Lab_Outside_Gateway,WAN) source dynamic any interface
nat (Lab_Host_Network,WAN) source dynamic any interface
nat (Home_Network_1_Gateway,WAN) source dynamic any interface
nat (Home_Network_2_Gateway,WAN) source dynamic any interface
nat (WAN,Lab_Outside_Gateway) source dynamic any interface
nat (Lab_Outside_Gateway,WAN) static interface service tcp 1701 1701
access-group WAN_access_in in interface WAN
route Lab_Outside_Gateway 10.0.11.0 255.255.255.0 10.0.255.10 1
route Lab_Outside_Gateway 10.0.14.0 255.255.255.0 10.0.255.10 1
route Lab_Outside_Gateway 10.0.78.0 255.255.255.0 10.0.255.10 1
route Lab_Outside_Gateway 10.0.254.0 255.255.255.0 10.0.255.10 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 10.0.0.0 255.255.255.0 Lab_Host_Network
no snmp-server location
no snmp-server contact
no sysopt connection permit-vpn
interface Vlan10
nameif WAN
security-level 0
interface Vlan11
security-level 100
interface Vlan12
security-level 90
interface Vlan13
security-level 10
interface Vlan14
security-level 100
ftp mode passive
host 10.0.78.250
protocol-object udp
protocol-object tcp
pager lines 24
logging enable
mtu WAN 1500
no failover
arp timeout 14400
http server enable
you config is wrong
put this command
no access-list WAN_access_in extended permit object VPN-Service-Port-3 any object VPN-Server
access-list WAN_access_in extended permit tcp any object VPN-Service-Port-3 object VPN-Server
Thanks for taking a look at the config.
I have tried to put in the two commands you listed. the second command doesn't seem to work.
ERROR : specified object <VPN-Service-Port-3> has wrong type;
test this
no access-list WAN_access_in extended permit tcp any object VPN-Service-Port-3 object VPN-Server
access-list WAN_access_in extended permit tcp any object VPN-Server eq 1701
also thought instead of this
  host 10.0.78.250
you can have this
  host 10.0.78.250
because we have access-list narrow it down to certain port no. so when someone from outside internet connects to your asa WAN link address with port 1701 will be directed to VPN-Server
The commands can be successfully applied.
However ASDM still doesnt register any hit when I try to make connection to port 1701 and the connection still fails.
Edit : I have also tried to change the NAT rule like you stated. but it seems like the asa internet facing interface (WAN) is still not registering any connection made to port 1701
run this and share the output
packet-tracer input WAN tcp 8.8.8.8 1701 10.0.78.250 1701 detail
Here is the output.
Also , I would like to thank you again for your help all along.
share the output of command
show nat
Here is the show nat result
I went on to perform packet trace again after I changed the NAT rule orders.
However this time packet trace failed at the NAT rule.
