ASA5506 - firepower / sourcefire installation problems - version 6.0.0
jni
Hello
Does any of you have problems with installation af firepower / sourcefire 6.0.0?
I have a test 5506-x firewall and I intended to use it for som firepower testing. However I do have a lot of issues with installation of version 6.0.0.
It is possible to install version 5.4, but I am not able to neither install nor upgrade it. I've tried to install and upgrade it through ASA CLI, ASDM and through a FirePower Management Center (ESX version), but all fail.
The ASA itself is running:
Cisco Adaptive Security Appliance Software Version 9.5(2)
Device Manager Version 7.5(2).
1. ASA CLI
I am able to boot into the 6.0.0 image, enter IP addresses etc. and run the system install from a FTP server. I does download, extract and starts to install image, but then simply stops.
A sh module gives me this
Mod Status Data Plane Status Compatibility
sfr Recover Not Applicable
Steps for CLI install
sw-module module sfr uninstall
debug module-boot
sw-module module sfr recover configure image disk0:asasfr-5500x-boot-6.0.0-1005.img
sw-module module sfr recover boot
session sfr console
setup
system install ftp://10.10.62.3/asasfr-sys-6.0.0-1005.pkg
2. ASDM / FMC
I tell the firewall to install the .sh file. It does start the install, but I also fails ultimately during upgrade. Some times it just fails, other times the task manager informs me about heartbeat issues and also fails.
As said before, I am able to install version 5.4, but after install I do get some errors in the log (see below) which would explain why I get heartbeat issues and cannot upgrade through ASDM or Management Center.
Jan 08 2016 12:39:17: %ASA-1-323006: Module sfr experienced a data channel communication failure, data channel is DOWN.
Jan 08 2016 12:39:20: %ASA-1-323006: Module sfr experienced a data channel communication failure, data channel is DOWN.
Jan 08 2016 12:39:24: %ASA-3-323001: Module sfr experienced a control channel communication failure.
Jan 08 2016 12:39:24: %ASA-1-323006: Module sfr experienced a data channel communication failure, data channel is DOWN.
Jan 08 2016 12:40:30: %ASA-5-505005: Module sfr is initializing control communication. Please wait...
Jan 08 2016 12:40:30: %ASA-1-323006: Module sfr experienced a data channel communication failure, data channel is DOWN.
Jan 08 2016 12:40:37: %ASA-1-505015: Module sfr, application up "ASA FirePOWER", version "5.4.1-211" Normal Operation
Jan 08 2016 12:40:37: %ASA-5-505006: Module sfr is Up.
Jan 08 2016 12:40:38: %ASA-1-505011: Module sfr data channel communication is UP.
Jan 08 2016 12:40:41: %ASA-1-505011: Module sfr data channel communication is UP.
Jan 08 2016 13:36:03: %ASA-1-323006: Module sfr experienced a data channel communication failure, data channel is DOWN.
Jan 08 2016 13:36:05: %ASA-1-323006: Module sfr experienced a data channel communication failure, data channel is DOWN.
Jan 08 2016 13:36:13: %ASA-3-323001: Module sfr experienced a control channel communication failure.
Jan 08 2016 13:36:13: %ASA-1-323006: Module sfr experienced a data channel communication failure, data channel is DOWN.
Jan 08 2016 13:37:19: %ASA-5-505005: Module sfr is initializing control communication. Please wait...
Jan 08 2016 13:37:19: %ASA-1-323006: Module sfr experienced a data channel communication failure, data channel is DOWN.
Jan 08 2016 13:37:29: %ASA-3-323001: Module sfr experienced a control channel communication failure.
Jan 08 2016 13:37:30: %ASA-5-505005: Module sfr is initializing control communication. Please wait...
Jan 08 2016 13:37:37: %ASA-1-505015: Module sfr, application up "ASA FirePOWER", version "5.4.1-211" Normal Operation
Jan 08 2016 13:37:37: %ASA-5-505006: Module sfr is Up.
Jan 08 2016 13:37:37: %ASA-1-505011: Module sfr data channel communication is UP.
Jan 08 2016 13:37:41: %ASA-1-505011: Module sfr data channel communication is UP.
Any suggestions what to try next? Am I missing something or are we talking about a bug or defect hardware?
Thank you for your time.
28 Replies 28
Hello Lucas,
Always try to keep the device in the latest version to avail all the latest features.
The latest 6.0.1.1 is available and having several issues resolved.
http://www.cisco.com/c/en/us/td/docs/security/firepower/601/6011/relnotes/firepower-system-release-notes-version-6011.html
Rate if the post helps you
Jetsy
I have the same issue stuck in Recover mode.
Status: Mapping host 0x2aab38200000 to VM with size 16777216
Warning: vlan 0 is not connected to host network
ciscoasa# sho module
Mod Card Type Model Serial No.
1 ASA 5506-X with FirePOWER services, 8GE, AC, ASA5506 JAD21470S75
sfr Unknown N/A JAD21470S75
Mod MAC Address Range Hw Version Fw Version Sw Version
1 b4de.31b9.f89c to b4de.31b9.f8a5 2.0 1.1.8 9.8(1)
sfr b4de.31b9.f89b to b4de.31b9.f89b N/A N/A
Mod SSM Application Name Status SSM Application Version
1 Up Sys Not Applicable
ciscoasa# sh flash:
--#-- --length-- -----date/time------ path
95 104489760 Nov 28 2017 02:30:06 asa981-lfbff-k8.SPA
96 26916068 Nov 28 2017 02:30:40 asdm-781.bin
97 33 Oct 06 2018 09:01:35 .boot_string
11 4096 Nov 28 2017 02:33:54 log
13 875 Oct 06 2018 08:44:41 log/asa-appagent.log
20 4096 Nov 28 2017 02:34:44 crypto_archive
21 4096 Nov 28 2017 02:34:48 coredumpinfo
22 59 Nov 28 2017 02:34:48 coredumpinfo/coredump.cfg
100 42956800 Oct 06 2018 09:14:06 asasfr-5500x-boot-6.2.3-4.img
ciscoasa# show module sfr log console
Displaying Console Log Information for Module sfr:
*** EVENT: Start Parameters: Image: /mnt/disk0/vm/vm_1.img, ISO: , Num CPUs: 3, RAM: 2253MB, Mgmt MAC: B4:DE:31:B9:F8:9B, CP MAC: 00:00:00:02:00:01, HDD: -drive file=/dev/sda,cache=none,if=virtio, Dev Driver: virtio
*** TIME: 08:46:09 UTC Oct 6 2018
*** EVENT: Start Parameters Continued: RegEx Shared Mem: 0MB, Cmd Op: , Shared Mem Key: 8061, Shared Mem Size: 16, Log Pipe: /dev/ttyS0_vm1, Sock: /dev/ttyS1_vm1, Mem-Path: -mem-path /hugepages
LILO 24.2 boot:
Loading 6.2.0.........................................................................
BIOS data check successful
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.53sf.cisco-53 (build@ajax) (gcc version 4.7.1 (GCC) ) #1 SMP PREEMPT Wed Nov 23 14:40:54 UTC 2016
[ 0.000000] Command line: auto BOOT_IMAGE=6.2.0 ro root=fd05 console=ttyS0,9600
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000008ccfdfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008ccfe000-0x000000008ccfffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feffc000-0x00000000feffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] Hypervisor detected: KVM
[ 0.000000] No AGP bridge found
[ 0.000000] e820: last_pfn = 0x8ccfe max_arch_pfn = 0x400000000
[ 0.000000] PAT not supported by CPU.
[ 0.000000] found SMP MP-table at [mem 0x000fdac0-0x000fdacf] mapped at [ffff8800000fdac0]
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] init_memory_mapping: [mem 0x8ca00000-0x8cbfffff]
[ 0.000000] init_memory_mapping: [mem 0x8c000000-0x8c9fffff]
[ 0.000000] init_memory_mapping: [mem 0x80000000-0x8bffffff]
[ 0.000000] init_memory_mapping: [mem 0x00100000-0x7fffffff]
[ 0.000000] init_memory_mapping: [mem 0x8cc00000-0x8ccfdfff]
[ 0.000000] ACPI: RSDP 00000000000fd900 00014 (v00 BOCHS )
[ 0.000000] ACPI: RSDT 000000008ccfe3e0 00034 (v01 BOCHS BXPCRSDT 00000001 BXPC 00000001)
[ 0.000000] ACPI: FACP 000000008ccfff80 00074 (v01 BOCHS BXPCFACP 00000001 BXPC 00000001)
[ 0.000000] ACPI: DSDT 000000008ccfe420 011A9 (v01 BXPC BXDSDT 00000001 INTL 20100528)
[ 0.000000] ACPI: FACS 000000008ccfff40 00040
[ 0.000000] ACPI: SSDT 000000008ccff740 007F7 (v01 BOCHS BXPCSSDT 00000001 BXPC 00000001)
[ 0.000000] ACPI: APIC 000000008ccff610 00088 (v01 BOCHS BXPCAPIC 00000001 BXPC 00000001)
[ 0.000000] ACPI: HPET 000000008ccff5d0 00038 (v01 BOCHS BXPCHPET 00000001 BXPC 00000001)
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000008ccfdfff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x8ccfdfff]
[ 0.000000] NODE_DATA [mem 0x8ccfa000-0x8ccfdfff]
[ 0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
[ 0.000000] kvm-clock: cpu 0, msr 0:8ccf9001, boot clock
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00001000-0x00ffffff]
[ 0.000000] DMA32 [mem 0x01000000-0xffffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00001000-0x0009efff]
[ 0.000000] node 0: [mem 0x00100000-0x8ccfdfff]
[ 0.000000] ACPI: PM-Timer IO Port: 0xb008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x00] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 0, version 17, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 high level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 high level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 high level)
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 3 CPUs, 0 hotplug CPUs
[ 0.000000] e820: [mem 0x8cd00000-0xfeffbfff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on KVM
[ 0.000000] setup_percpu: NR_CPUS:64 nr_cpumask_bits:64 nr_cpu_ids:3 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @ffff88008c800000 s69568 r8192 d20544 u524288
[ 0.000000] kvm-clock: cpu 0, msr 0:8ccf9001, primary cpu clock
[ 0.000000] KVM setup async PF for cpu 0
[ 0.000000] kvm-stealtime: cpu 0, msr 8c80ba40
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 568761
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: auto BOOT_IMAGE=6.2.0 ro root=fd05 console=ttyS0,9600
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Checking aperture...
[ 0.000000] Memory: 2264704k/2307064k available (4768k kernel code, 392k absent, 41968k reserved, 2399k data, 884k init)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=3.
[ 0.000000] NR_IRQS:4352 nr_irqs:704 16
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [ttyS0] enabled
[ 0.000000] allocated 9437184 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] tsc: Detected 1249.999 MHz processor
[ 0.003000] Calibrating delay loop (skipped) preset value.. 2499.99 BogoMIPS (lpj=1249999)
[ 0.004017] pid_max: default: 32768 minimum: 301
[ 0.005141] Security Framework initialized
[ 0.008768] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.015036] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.018194] Mount-cache hash table entries: 256
[ 0.020352] Initializing cgroup subsys memory
[ 0.022108] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.022108] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.022108] tlb_flushall_shift: 6
[ 0.023529] Freeing SMP alternatives: 12k freed
[ 0.027407] ACPI: Core revision 20130328
[ 0.033109] ACPI: All ACPI Tables successfully acquired
[ 0.041558] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.042010] smpboot: CPU0: Intel QEMU Virtual CPU version 1.5.0 (fam: 06, model: 02, stepping: 03)
[ 0.048000] Performance Events: unsupported p6 CPU model 2 no PMU driver, software events only.
[ 0.056290] smpboot: Booting Node 0, Processors #1[ 0.003000] kvm-clock: cpu 1, msr 0:8ccf9041, secondary cpu clock
[ 0.073090] KVM setup async PF for cpu 1
[ 0.073090] kvm-stealtime: cpu 1, msr 8c88ba40
#2 OK
[ 0.003000] kvm-clock: cpu 2, msr 0:8ccf9081, secondary cpu clock
[ 0.093193] Brought up 3 CPUs
[ 0.093097] KVM setup async PF for cpu 2
[ 0.093097] kvm-stealtime: cpu 2, msr 8c90ba40
[ 0.094011] smpboot: Total of 3 processors activated (7499.99 BogoMIPS)
[ 0.098888] devtmpfs: initialized
[ 0.102311] NET: Registered protocol family 16
[ 0.107062] ACPI: bus type PCI registered
[ 0.109670] PCI: Using configuration type 1 for base access
[ 0.160918] bio: create slab <bio-0> at 0
[ 0.164940] ACPI: Added _OSI(Module Device)
[ 0.166014] ACPI: Added _OSI(Processor Device)
[ 0.167000] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.167000] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.176032] ACPI: Interpreter enabled
[ 0.177026] ACPI: (supports S0 S5)
[ 0.178008] ACPI: Using IOAPIC for interrupt routing
[ 0.180149] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.182939] ACPI: No dock devices found.
[ 0.215387] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.216589] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[ 0.217220] PCI host bridge to bus 0000:00
[ 0.218057] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.219000] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.219000] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.220015] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.221018] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfebfffff]
[ 0.240676] pci 0000:00:01.3: quirk: [io 0xb000-0xb03f] claimed by PIIX4 ACPI
[ 0.242054] pci 0000:00:01.3: quirk: [io 0xb100-0xb10f] claimed by PIIX4 SMB
[ 0.330762] acpi PNP0A03:00: ACPI _OSC support notification failed, disabling PCIe ASPM
[ 0.331014] acpi PNP0A03:00: Unable to request _OSC control (_OSC support mask: 0x08)
[ 0.333559] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 *10 11)
[ 0.337183] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 *10 11)
[ 0.339000] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 10 *11)
[ 0.341902] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 10 *11)
[ 0.343153] ACPI: PCI Interrupt Link [LNKS] (IRQs *9)
[ 0.346000] ACPI: Enabled 16 GPEs in block 00 to 0F
[ 0.349407] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.351027] vgaarb: loaded
[ 0.352010] vgaarb: bridge control possible 0000:00:02.0
[ 0.355630] SCSI subsystem initialized
[ 0.357017] ACPI: bus type ATA registered
[ 0.361429] ACPI: bus type USB registered
[ 0.364169] usbcore: registered new interface driver usbfs
[ 0.367114] usbcore: registered new interface driver hub
[ 0.370081] usbcore: registered new device driver usb
[ 0.373677] pps_core: LinuxPPS API ver. 1 registered
[ 0.376009] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.380436] PTP clock support registered
[ 0.382648] PCI: Using ACPI for IRQ routing
[ 0.386675] NetLabel: Initializing
[ 0.388048] NetLabel: domain hash size = 128
[ 0.390009] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.391000] NetLabel: unlabeled traffic allowed by default
[ 0.395222] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.398080] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.399000] hpet0: 3 comparators, 64-bit 100.000000 MHz counter
[ 0.409405] Switching to clocksource kvm-clock
[ 0.411999] pnp: PnP ACPI init
[ 0.413192] ACPI: bus type PNP registered
[ 0.419884] pnp: PnP ACPI: found 8 devices
[ 0.421861] ACPI: bus type PNP unregistered
[ 0.458391] NET: Registered protocol family 2
[ 0.461481] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.465253] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.468557] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.471650] TCP: reno registered
[ 0.473236] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.476108] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.479422] NET: Registered protocol family 1
[ 0.481994] RPC: Registered named UNIX socket transport module.
[ 0.484761] RPC: Registered udp transport module.
[ 0.486980] RPC: Registered tcp transport module.
[ 0.489176] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.492187] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
[ 0.494974] pci 0000:00:01.0: PIIX3: Enabling Passive Release
[ 0.497713] pci 0000:00:01.0: Activating ISA DMA hang workarounds
[ 0.505025] microcode: CPU0 sig=0x623, pf=0x0, revision=0x1
[ 0.507673] microcode: CPU1 sig=0x623, pf=0x0, revision=0x1
[ 0.510329] microcode: CPU2 sig=0x623, pf=0x0, revision=0x1
[ 0.513327] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.520216] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.524080] VFS: Disk quotas dquot_6.5.2
[ 0.526086] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.531494] NFS: Registering the id_resolver key type
[ 0.533930] Key type id_resolver registered
[ 0.535898] Key type id_legacy registered
[ 0.538233] msgmni has been set to 4423
[ 0.541799] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.545226] io scheduler noop registered
[ 0.547103] io scheduler deadline registered
[ 0.549244] io scheduler cfq registered (default)
[ 0.554690] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ 0.558106] ACPI: Power Button [PWRF]
[ 0.568997] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 0.575330] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
[ 0.582187] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 0.590978] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.621429] 00:05: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.651927] 00:06: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.658285] Non-volatile memory driver v1.3
[ 0.660268] Linux agpgart interface v0.103
[ 0.663570] [drm] Initialized drm 1.1.0 20060810
[ 0.678472] brd: module loaded
[ 0.686537] loop: module loaded
[ 0.693947] vda: vda1 vda2 vda3 < vda5 vda6 vda7 >
[ 0.702836] Loading iSCSI transport class v2.0-870.
[ 0.714777] scsi0 : ata_piix
[ 0.716974] scsi1 : ata_piix
[ 0.718828] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xc0c0 irq 14
[ 0.721959] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xc0c8 irq 15
[ 0.727060] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 0.729904] e100: Copyright(c) 1999-2006 Intel Corporation
[ 0.732756] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.0.3-k
[ 0.735981] igb: Copyright (c) 2007-2013 Intel Corporation.
[ 0.738902] Fusion MPT base driver 3.04.20
[ 0.740903] Copyright (c) 1999-2008 LSI Corporation
[ 0.743219] Fusion MPT SPI Host driver 3.04.20
[ 0.745630] Fusion MPT FC Host driver 3.04.20
[ 0.748186] Fusion MPT SAS Host driver 3.04.20
[ 0.751417] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.754474] ehci-pci: EHCI PCI platform driver
[ 0.756877] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.760235] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.763874] usbcore: registered new interface driver usblp
[ 0.766878] usbcore: registered new interface driver usb-storage
[ 0.770347] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[ 0.776827] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.779239] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.782687] mousedev: PS/2 mouse device common for all mice
[ 0.787391] rtc_cmos 00:00: RTC can wake from S4
[ 0.791280] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 0.795437] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[ 0.798758] rtc_cmos 00:00: alarms up to one day, 114 bytes nvram, hpet irqs
[ 0.803337] i2c /dev entries driver
[ 0.805897] md: raid1 personality registered for level 1
[ 0.809564] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 0.813501] cpuidle: using governor ladder
[ 0.816669] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.828350] usbcore: registered new interface driver usbhid
[ 0.831087] usbhid: USB HID core driver
[ 0.833204] ipip: IPv4 over IPv4 tunneling driver
[ 0.836608] TCP: cubic registered
[ 0.838243] Initializing XFRM netlink socket
[ 0.840584] NET: Registered protocol family 10
[ 0.843300] NET: Registered protocol family 17
[ 0.845486] Key type dns_resolver registered
[ 0.848992] registered taskstats version 1
[ 0.852279] console [netcon0] enabled
[ 0.854030] netconsole: network logging started
[ 0.879942] ata1.00: ATA-7: QEMU HARDDISK, 1.5.0, max UDMA/100
[ 0.882686] ata1.00: 6291456 sectors, multi 16: LBA48
[ 0.885731] ata2.00: ATAPI: QEMU DVD-ROM, 1.5.0, max UDMA/100
[ 0.889661] ata2.00: configured for MWDMA2
[ 0.892854] ata1.00: configured for MWDMA2
[ 0.895147] scsi 0:0:0:0: Direct-Access ATA QEMU HARDDISK 1.5. PQ: 0 ANSI: 5
[ 0.900224] sd 0:0:0:0: [sda] 6291456 512-byte logical blocks: (3.22 GB/3.00 GiB)
[ 0.900951] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.906495] sd 0:0:0:0: [sda] Write Protect is off
[ 0.908276] scsi 1:0:0:0: CD-ROM QEMU QEMU DVD-ROM 1.5. PQ: 0 ANSI: 5
[ 0.911812] sr0: scsi3-mmc drive: 4x/4x cd/rw xa/form2 tray
[ 0.911816] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 0.913556] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 0.921666] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.927733] sda: sda1 sda2
[ 0.930948] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.433076] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input2
[ 1.438153] md: Waiting for all devices to be available before autodetect
[ 1.441287] md: If you don't use raid, use raid=noautodetect
[ 1.444827] md: Autodetecting RAID arrays.
[ 1.446776] md: Scanned 0 and added 0 devices.
[ 1.448898] md: autorun ...
[ 1.450261] md: ... autorun DONE.
[ 1.453675] EXT3-fs (vda5): recovery required on readonly filesystem
[ 1.456658] EXT3-fs (vda5): write access will be enabled during recovery
[ 1.504316] tsc: Refined TSC clocksource calibration: 1249.997 MHz
[ 1.736145] kjournald starting. Commit interval 5 seconds
[ 1.736743] EXT3-fs (vda5): recovery complete
[ 1.736747] EXT3-fs (vda5): mounted filesystem with ordered data mode
[ 1.736777] VFS: Mounted root (ext3 filesystem) readonly on device 253:5.
[ 1.747733] devtmpfs: mounted
[ 1.749453] Freeing unused kernel memory: 884k freed
INIT: version 2.88 booting
cat: /proc/cmdline: No such file or directory
Mounting proc file system... [ OK ]
Mounting sys file system... [ OK ]
Starting udev [ 1.968751] udevd (759): /proc/759/oom_adj is deprecated, please use /proc/759/oom_score_adj instead.
[ 1.973457] udevd version 124 started
[ 2.130558] Floppy drive(s): fd0 is 1.44M, fd1 is 1.44M
[ 2.145643] FDC 0 is a S82078B
[ 2.174240] sfpacket: module license 'Proprietary' taints kernel.
[ 2.184295] Disabling lock debugging due to kernel taint
[ 2.191064] Sourcefire Bridging Packet Driver - version 6.0.0
[ 2.202086] Copyright (c) 2004-2010 Sourcefire, Inc.
[ 2.210795] SFPacket Inter-VM Shared Memory Driver - version 6.0.0
[ 2.224107] Copyright (c) 2014 Cisco Systems, Inc.
[ 2.238573] KVM_IVSHMEM: Major device number is: 247
[ 2.241085] KVM_IVSHMEM: Probing for KVM_IVSHMEM Device
[ 2.244455] KVM_IVSHMEM: result is 0
[ 2.246277] KVM_IVSHMEM: iomap base = 0x18446683600578412544
[ 2.255242] KVM_IVSHMEM: ioaddr = fc000000 ioaddr_size = 16777216
[ 2.258494] SFIVMSHM info: Registered device 'kvm_ivshmem'.
[ 2.278867] KVM_IVSHMEM: Registered with the SFIVMShm driver.
[ 2.283343] KVM_IVSHMEM: irq = 11 regaddr = febf1000 reg_size = 256
Activating all swap files/partitions...
[ 2.591841] Adding 1000444k swap on /dev/vda2. Priority:-1 extents[ OK ]s:1000444k
Mounting root file system in read-only mode... [ OK ]
Checking file systems...
e2fsck 1.42.9 (28-Dec-2013)
3D-6.2.0: clean, 20101/244320 files, 214134/976384 blocks
BOOT: recovering journal
/Volume: recovering journal
BOOT: clean, 55/26208 files, 24498/104420 blocks
Clearing orphaned inode 983199 (uid=27, gid=27, mode=0100600, size=0)
Clearing orphaned inode 983194 (uid=27, gid=27, mode=0100600, size=0)
Clearing orphaned inode 983193 (uid=27, gid=27, mode=0100600, size=0)
Clearing orphaned inode 983192 (uid=27, gid=27, mode=0100600, size=0)
Clearing orphaned inode 983191 (uid=27, gid=27, mode=0100600, size=0)
Clearing orphaned inode 968858 (uid=0, gid=0, mode=0100600, size=217032)
Setting free inodes count to 2433463 (was 2433921)
Setting free blocks count to 8162962 (was 8163978)
/Volume: clean, 65097/2498560 files, 1816530/9979492 blocks [ OK ]
Remounting root file system in read-write mode...
[ 3.886999] EXT3-fs (vda5): using internal journal [ OK ]
Mounting remaining file systems...
[ 3.900968] kjournald starting. Commit interval 5 seconds
[ 3.903733] EXT3-fs (sda1): using internal journal
[ 3.906083] EXT3-fs (sda1): mounted filesystem with ordered data mode
[ 3.914222] kjournald starting. Commit interval 5 seconds
[ 3.914678] EXT3-fs (vda7): using internal journal
[ 3.914683] EXT3-fs (vda7): mounted filesystem with ordered data mo[ OK ]
Removing /var/run/* and /var/lock/subsys/* [ OK ]
Removing /var/sf/run/*
Removing /tmp/cgi* files
Removing temporary files
Creating new /var/run/utmp... [ OK ]
Removing possible /etc/nologin /fastboot and /forcefsck... [ OK ]
Removing dhcp lock files... [ OK ]
/etc/rc.d/rcsysinit.d/S51udev_retry: line 35: log_info_msg: command no[ OK ]
Setting clock... [ OK ]
Initializing kernel random number generator... [ OK ]
Saving dmesg boot log [ OK ]
Loading fuse module failed!
Bringing up the loopback interface...
Upping interface lo [ OK ]
Configuring address the lo interface... [ OK ]
Configuring hostname to firepower [ OK ]
Configuring IPv6 address the lo interface... [ OK ]
Disable IPv6 default route [ OK ]
Configuring Static Routes
Writing hosts file [ OK ]
Setting kernel paramaters [ OK ]
INIT: Entering runlevel: 3
Starting system log daemon... [ OK ]
Starting cron daemon... [ OK ]
Adding swapfile /Volume/.swaptwo
[ 8.534999] Adding 2258560k swap on /Volume/.swaptwo. Priority:-2 extents:571 across:2318652k
Flushing all current IPv4 rules and user defined chains: [ 9.590636] ip_tables: (C) 2000-2006 Netfilter Core Team
...success
Clearing all current IPv4 rules and user defined chains: ...success
Applying iptables firewall rules:
Flushing chain `PREROUTING'
Flushing chain `INPUT'
Flushing chain `FORWARD'
Flushing chain `OUTPUT'
Flushing chain `POSTROUTING'
[ 9.651645] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Applying rules successed
Flushing all current IPv6 rules and user defined chains: [ 9.746577] ip6_tables: (C) 2000-2006 Netfilter Core Team
...success
Clearing all current IPv6 rules and user defined chains: ...success
Applying ip6tables firewall rules:
Upping interface eth0 [ OK ]
Setting MTU... [ OK ]
No dns server or search domain specified
No ntp server specified
Configuring address the eth0 interface... [ OK ]
Unconfiguring IPv6 [ OK ]
Interface disabled, downing [ OK ]
Starting portmap... [ OK ]
Starting nscd...
mkdir: created directory '/var/run/nscd' [ OK ]
Setting video params
setterm: cannot (un)set powersave mode: Inappropriate ioctl for device
Generating public/private rsa1 key pair.
Saving key "/etc/ssh/ssh_host_key" failed: unknown or unsupported key [ OK ]
Starting , please wait......complete. [ OK ]
Starting xinetd:
Not reconfigurating
Sat Oct 6 08:46:35 UTC 2018
Starting MySQL...
Pinging mysql
Pinging mysql, try 1
Pinging mysql, try 2
Pinging mysql, try 3
Found mysql is running
Running initializeObjects...
Stopping MySQL...
Killing mysqld with pid 3085
Wait for mysqld to exit\c
done
Sat Oct 6 08:47:02 UTC 2018
We didn't shutdown properly - running DB check!
Please wait patiently. This might take a very long time (hours...)
Warning: speed or duplex not found in config file for eth0, using defaults...
modprobe: FATAL: Module ipmi_si not found in directory /lib/modules/3.10.53sf.cisco-53
Starting Cisco ASA5506, please wait...No PM running!
...started.
Oct 06 08:47:53 firepower SF-IMS[4221]: [4221] init script:system [INFO] pmmon Setting affinity to 0-2...
pid 4215's current affinity list: 0-2
pid 4215's new affinity list: 0-2
Oct 06 08:47:53 firepower SF-IMS[4223]: [4223] init script:system [INFO] pmmon The Process Manager is not running...
Oct 06 08:47:53 firepower SF-IMS[4224]: [4224] init script:system [INFO] pmmon Starting the Process Manager...
Oct 06 08:47:54 firepower SF-IMS[4225]: [4225] pm:pm [INFO] Using model number 72J
Cisco ASA5506 v6.2.0 (build 362)
firepower login: [ 92.299659] SFHS[4226] - kvm_ivshmem: Set max latency to 0 msecs (0 jiffies)
[ 92.554328] tun: Universal TUN/TAP device driver, 1.6
[ 92.556868] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 92.740785] IPv6: ADDRCONF(NETDEV_UP): tun1: link is not ready
[ 92.887394] SFIVMSHM info: Initializing Channel 0 Client Descriptor Base...
[ 92.890867] SFIVMSHM info: Initializing Channel 1 Client Descriptor Base...
[ 92.894216] SFIVMSHM info: Initializing packet buffer pool...
[ 92.897896] SFIVMSHM info: Initializing packet buffer pool done!
[ 93.523318] SFIVMSHM info: Shared Memory start addr = ffffc90000800000 size = 16777216
[ 93.527237] SFIVMSHM info: magicNum = 0x2a1337 version = 3 asa_state = INIT_COMPLETE ips_state = INIT_COMPLETE lineStatus = 1 mode = 0 totalSize = 16777216
[ 93.534282] SFIVMSHM info: Channel Info ch_count = 2
[ 93.536679] SFIVMSHM info: Channel Info #0: [TS pool_offset = 0 nextToRead = 0 nextToWrite = 0 count = 1008 pad = 0]
[ 93.541693] SFIVMSHM info: Channel Info #0: [FS pool_offset = 36288 nextToRead = 0 nextToWrite = 0 count = 1008 pad = 0]
[ 93.546908] SFIVMSHM info: Channel Info #1: [TS pool_offset = 72576 nextToRead = 0 nextToWrite = 0 count = 1008 pad = 0]
[ 93.552487] SFIVMSHM info: Channel Info #1: [FS pool_offset = 108864 nextToRead = 0 nextToWrite = 0 count = 1008 pad = 0]
[ 93.558321] SFIVMSHM info: Packet Buffer pools [server start=147456 count=6902 size=14135296] [client start=14282752 count=1218 size=2494464] [pktbuf_size = 2048]
[ 93.567437] SFIVMSHM info: Allocated 165648 bytes for the array of 6902 IvmShm Buffers.
[ 93.572846] SFIVMSHM info: [4274]: Ring kvm_ivshmem - RX/TX thread created and started (ffff880088394200)
[ 93.577706] SFIVMSHM info: [4274]: Ring kvm_ivshmem - Done with index -1 and rval 0
[ 93.843478] IPv6: ADDRCONF(NETDEV_CHANGE): tun1: link becomes ready
[ 130.496545] SFPacket_AFBP: Copied first heartbeat for future use (78 bytes)
*** EVENT: The module is shutting down.
*** TIME: 09:02:26 UTC Oct 6 2018
INIT: Switching to runlevel: 0
INIT: Sending processes the TERM signal
Stopping Cisco ASA5506...[ 964.526389] SFHS[4274] - kvm_ivshmem: Not freeing external data ring memory.
...ok
Saving random seed... [ OK ]
Stopping nscd... [ OK ]
Turning off swapfile /Volume/.swaptwo
Unmounting all other currently mounted file systems... [ OK ]
Fuse filesystem not loaded.
Stopping portmap... [ OK ]
Stopping xinetd:
Clearing static routes
Unconfiguring address on eth0 [ OK ]
Downing interface [ OK ]
Unconfiguring IPv4 [ OK ]
Bringing down the loopback interface...
Unconfiguring address on lo [ OK ]
Unconfiguring IPv6 address the lo interface... [ OK ]
Stopping system log daemon... [ OK ]
Sending all processes the TERM signal... [ OK ]
Sending all processes the KILL signal... [ OK ]
Deactivating all swap files/partitions... [ OK ]
[ 980.257939] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 980.263485] sd 0:0:0:0: [sda] Stopping disk
[ 980.267302] ACPI: Preparing to enter system sleep state S5
[ 980.270086] Power down.
*** EVENT: The module is shut down.
*** TIME: 09:02:43 UTC Oct 6 2018
*** EVENT: Creating the Disk Image...
*** TIME: 09:14:53 UTC Oct 6 2018
*** EVENT: The module is being recovered.
*** EVENT: Disk Image created successfully.
*** TIME: 09:17:16 UTC Oct 6 2018
*** EVENT: Start Parameters: Image: /mnt/disk0/vm/vm_1.img, ISO: -cdrom /mnt/disk0/asasfr-5500x-boot-6.2.3-4.img, Num CPUs: 3, RAM: 2253MB, Mgmt MAC: B4:DE:31:B9:F8:9B, CP MAC: 00:00:00:02:00:01, HDD: -drive file=/dev/sda,cache=none,if=virtio, Dev D
*** EVENT: Start Parameters Continued: RegEx Shared Mem: 0MB, Cmd Op: r, Shared Mem Key: 8061, Shared Mem Size: 16, Log Pipe: /dev/ttyS0_vm1, Sock: /dev/ttyS1_vm1, Mem-Path: -mem-path /hugepages
ISOLINUX 3.73 2009-01-25 Copyright (C) 1994-2008 H. Peter Anvin
Cisco SFR-BOOT-IMAGE and CX-BOOT-IMAGE for SFR - 6.2.3
(WARNING: ALL DATA ON DISK 1 WILL BE LOST)
Loading bzImage.............................................................
Loading initramfs.gz..................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................ready.
[ 0.000000] Linux version 3.10.107sf.cisco-1 (build@1fd5cd658885) (gcc version 4.7.1 (GCC) ) #1 SMP PREEMPT Fri Nov 10 17:06:45 UTC 2017
[ 0.000000] Command line: initrd=initramfs.gz console=ttyS0,9600 BOOT_IMAGE=bzImage
[ 0.000000] RAMDISK: [mem 0x7db0b000-0x7fffffff]
[ 0.000000] ACPI: RSDP 0x00000000000FD900 00014 (v00 BOCHS )
[ 0.000000] ACPI: RSDT 0x000000008CCFE3E0 00034 (v01 BOCHS BXPCRSDT 00000001 BXPC 00000001)
[ 0.000000] ACPI: FACP 0x000000008CCFFF80 00074 (v01 BOCHS BXPCFACP 00000001 BXPC 00000001)
[ 0.000000] ACPI: DSDT 0x000000008CCFE420 011A9 (v01 BXPC BXDSDT 00000001 INTL 20100528)
[ 0.000000] ACPI: FACS 0x000000008CCFFF40 00040
[ 0.000000] ACPI: SSDT 0x000000008CCFF740 007F7 (v01 BOCHS BXPCSSDT 00000001 BXPC 00000001)
[ 0.000000] ACPI: APIC 0x000000008CCFF610 00088 (v01 BOCHS BXPCAPIC 00000001 BXPC 00000001)
[ 0.000000] ACPI: HPET 0x000000008CCFF5D0 00038 (v01 BOCHS BXPCHPET 00000001 BXPC 00000001)
[ 0.000000] PERCPU: Embedded 24 pages/cpu @ffff88008c800000 s68672 r8192 d21440 u524288
[ 0.000000] Kernel command line: initrd=initramfs.gz console=ttyS0,9600 BOOT_IMAGE=bzImage
[ 0.000000] Memory: 2226784k/2307064k available (4805k kernel code, 392k absent, 79888k reserved, 2414k data, 896k init)
[ 0.005142] Security Framework initialized
[ 0.008053] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.015038] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.018124] Mount-cache hash table entries: 256
[ 0.020269] Initializing cgroup subsys memory
[ 0.021383] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.021383] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.021383] tlb_flushall_shift: 6
[ 0.022485] Freeing SMP alternatives: 12k freed
[ 0.026160] ACPI: Core revision 20130328
[ 0.031661] ACPI: All ACPI Tables successfully acquired
[ 0.039196] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.040009] smpboot: CPU0: Intel QEMU Virtual CPU version 1.5.0 (fam: 06, model: 02, stepping: 03)
[ 0.045000] Performance Events: unsupported p6 CPU model 2 no PMU driver, software events only.
[ 0.052294] smpboot: Booting Node 0, Processors #1[ 0.003000] kvm-clock: cpu 1, msr 0:8ccf9041, secondary cpu clock
[ 0.069091] KVM setup async PF for cpu 1
#2 OK
[ 0.069091] kvm-stealtime: cpu 1, msr 8c88ba40
[ 0.089198] Brought up 3 CPUs
[ 0.089099] KVM setup async PF for cpu 2
[ 0.089099] kvm-stealtime: cpu 2, msr 8c90ba40
[ 0.090011] smpboot: Total of 3 processors activated (7499.99 BogoMIPS)
[ 0.093512] devtmpfs: initialized
[ 0.096869] NET: Registered protocol family 16
[ 0.101421] ACPI: bus type PCI registered
[ 0.104262] PCI: Using configuration type 1 for base access
[ 0.174226] bio: create slab <bio-0> at 0
[ 0.178219] ACPI: Added _OSI(Module Device)
[ 0.180013] ACPI: Added _OSI(Processor Device)
[ 0.181015] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.182000] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.191039] ACPI: Interpreter enabled
[ 0.192025] ACPI: (supports S0 S5)
[ 0.193008] ACPI: Using IOAPIC for interrupt routing
[ 0.195035] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.197851] ACPI: No dock devices found.
[ 0.228916] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.229027] acpi PNP0A03:00: ACPI _OSC support notification failed, disabling PCIe ASPM
[ 0.230000] acpi PNP0A03:00: Unable to request _OSC control (_OSC support mask: 0x08)
[ 0.230000] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[ 0.232179] PCI host bridge to bus 0000:00
[ 0.234016] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.235018] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.236000] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.236000] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.236000] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfebfffff]
[ 0.254859] pci 0000:00:01.3: quirk: [io 0xb000-0xb03f] claimed by PIIX4 ACPI
[ 0.256053] pci 0000:00:01.3: quirk: [io 0xb100-0xb10f] claimed by PIIX4 SMB
[ 0.348732] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 *10 11)
[ 0.350000] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 *10 11)
[ 0.350000] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 10 *11)
[ 0.350000] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 10 *11)
[ 0.350000] ACPI: PCI Interrupt Link [LNKS] (IRQs *9)
[ 0.351761] ACPI: Enabled 16 GPEs in block 00 to 0F
[ 0.354799] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.356013] vgaarb: loaded
[ 0.357010] vgaarb: bridge control possible 0000:00:02.0
[ 0.360795] SCSI subsystem initialized
[ 0.362012] ACPI: bus type ATA registered
[ 0.366111] ACPI: bus type USB registered
[ 0.368430] usbcore: registered new interface driver usbfs
[ 0.370063] usbcore: registered new interface driver hub
[ 0.373083] usbcore: registered new device driver usb
[ 0.376647] pps_core: LinuxPPS API ver. 1 registered
[ 0.379051] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.383560] PTP clock support registered
[ 0.385772] PCI: Using ACPI for IRQ routing
[ 0.389894] NetLabel: Initializing
[ 0.391009] NetLabel: domain hash size = 128
[ 0.393017] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.396061] NetLabel: unlabeled traffic allowed by default
[ 0.398150] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.402092] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.404240] hpet0: 3 comparators, 64-bit 100.000000 MHz counter
[ 0.412720] amd_nb: Cannot enumerate AMD northbridges
[ 0.415010] Switching to clocksource kvm-clock
[ 0.417897] pnp: PnP ACPI init
[ 0.419158] ACPI: bus type PNP registered
[ 0.425915] pnp: PnP ACPI: found 8 devices
[ 0.428079] ACPI: bus type PNP unregistered
[ 0.465526] NET: Registered protocol family 2
[ 0.468757] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.472520] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.475883] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.479093] TCP: reno registered
[ 0.480662] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.483511] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.486842] NET: Registered protocol family 1
[ 0.489569] RPC: Registered named UNIX socket transport module.
[ 0.492332] RPC: Registered udp transport module.
[ 0.494546] RPC: Registered tcp transport module.
[ 0.496743] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.499751] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
[ 0.502533] pci 0000:00:01.0: PIIX3: Enabling Passive Release
[ 0.505266] pci 0000:00:01.0: Activating ISA DMA hang workarounds
[ 0.508598] Trying to unpack rootfs image as initramfs...
[ 2.758223] Freeing initrd memory: 37844k freed
[ 2.784361] microcode: CPU0 sig=0x623, pf=0x0, revision=0x1
[ 2.787141] microcode: CPU1 sig=0x623, pf=0x0, revision=0x1
[ 2.789812] microcode: CPU2 sig=0x623, pf=0x0, revision=0x1
[ 2.792828] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 2.799980] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 2.803929] VFS: Disk quotas dquot_6.5.2
[ 2.806116] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.810866] NFS: Registering the id_resolver key type
[ 2.813349] Key type id_resolver registered
[ 2.815323] Key type id_legacy registered
[ 2.817744] msgmni has been set to 4423
[ 2.822231] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 2.825687] io scheduler noop registered
[ 2.827543] io scheduler deadline registered
[ 2.829728] io scheduler cfq registered (default)
[ 2.835282] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ 2.838759] ACPI: Power Button [PWRF]
[ 2.850243] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 2.856691] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
[ 2.863573] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 2.872580] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.903447] 00:05: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.934338] 00:06: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 2.941428] Non-volatile memory driver v1.3
[ 2.943467] Linux agpgart interface v0.103
[ 2.946929] [drm] Initialized drm 1.1.0 20060810
[ 2.950725] Floppy drive(s): fd0 is 1.44M, fd1 is 1.44M
[ 2.963774] brd: module loaded
[ 2.967714] FDC 0 is a S82078B
[ 2.973313] loop: module loaded
[ 2.980945] vda: vda1 vda2 vda3 < vda5 vda6 vda7 >
[ 2.989953] Loading iSCSI transport class v2.0-870.
[ 3.001596] scsi0 : ata_piix
[ 3.003767] scsi1 : ata_piix
[ 3.005591] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xc0c0 irq 14
[ 3.008769] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xc0c8 irq 15
[ 3.013625] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 3.016476] e100: Copyright(c) 1999-2006 Intel Corporation
[ 3.019348] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.0.3-k
[ 3.022531] igb: Copyright (c) 2007-2013 Intel Corporation.
[ 3.025413] Fusion MPT base driver 3.04.20
[ 3.027367] Copyright (c) 1999-2008 LSI Corporation
[ 3.029663] Fusion MPT SPI Host driver 3.04.20
[ 3.032136] Fusion MPT FC Host driver 3.04.20
[ 3.034516] Fusion MPT SAS Host driver 3.04.20
[ 3.037729] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.040768] ehci-pci: EHCI PCI platform driver
[ 3.043252] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.046444] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.050112] usbcore: registered new interface driver usblp
[ 3.052950] usbcore: registered new interface driver usb-storage
[ 3.056428] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[ 3.062630] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 3.065071] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 3.068442] mousedev: PS/2 mouse device common for all mice
[ 3.073423] rtc_cmos 00:00: RTC can wake from S4
[ 3.075642] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 3.081673] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[ 3.084960] rtc_cmos 00:00: alarms up to one day, 114 bytes nvram, hpet irqs
[ 3.088869] i2c /dev entries driver
[ 3.091481] md: raid1 personality registered for level 1
[ 3.095432] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 3.099330] cpuidle: using governor ladder
[ 3.102300] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.114582] usbcore: registered new interface driver usbhid
[ 3.117309] usbhid: USB HID core driver
[ 3.119375] ipip: IPv4 over IPv4 tunneling driver
[ 3.122773] TCP: cubic registered
[ 3.124363] Initializing XFRM netlink socket
[ 3.126740] NET: Registered protocol family 10
[ 3.129711] NET: Registered protocol family 17
[ 3.131852] Key type dns_resolver registered
[ 3.135342] registered taskstats version 1
[ 3.138511] console [netcon0] enabled
[ 3.140244] netconsole: network logging started
[ 3.166445] ata1.00: ATA-7: QEMU HARDDISK, 1.5.0, max UDMA/100
[ 3.169325] ata1.00: 6291456 sectors, multi 16: LBA48
[ 3.173092] ata2.00: ATAPI: QEMU DVD-ROM, 1.5.0, max UDMA/100
[ 3.177084] ata2.00: configured for MWDMA2
[ 3.179594] ata1.00: configured for MWDMA2
[ 3.181886] scsi 0:0:0:0: Direct-Access ATA QEMU HARDDISK 1.5. PQ: 0 ANSI: 5
[ 3.186816] sd 0:0:0:0: [sda] 6291456 512-byte logical blocks: (3.22 GB/3.00 GiB)
[ 3.190646] sd 0:0:0:0: [sda] Write Protect is off
[ 3.190912] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.196196] scsi 1:0:0:0: CD-ROM QEMU QEMU DVD-ROM 1.5. PQ: 0 ANSI: 5
[ 3.196235] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.206529] sda: unknown partition table
[ 3.206585] sr0: scsi3-mmc drive: 4x/4x cd/rw xa/form2 tray
[ 3.206588] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.208862] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 3.217148] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.219656] Freeing unused kernel memory: 896k freed
INIT: version 2.86 booting
Please wait: booting...
mount: sysfs already mounted or /sys busy
mount: according to mtab, sysfs is already mounted on /sys
Starting udev [ 3.514381] udevd (765): /proc/765/oom_adj is deprecated, please use /proc/765/oom_score_adj instead.
[ 3.518745] udevd version 124 started
[ 3.717956] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input2
[ 3.781195] tsc: Refined TSC clocksource calibration: 1249.999 MHz
[ 3.850190] end_request: I/O error, dev fd0, sector 0
[ 3.873159] end_request: I/O error, dev fd0, sector 0
and populating dev cache
Root filesystem already rw, not remounting
Configuring network interfaces... done.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
Configuring kvm-ivshmem
Configuring busybox-syslog
System startup links for /etc/init.d/sysklogd already exist.
Configuring openssh-sshd
Adding system startup for /etc/init.d/sshd.
Configuring sudo
Configuring ntpdate
adding crontab
Configuring update-modules
INIT: Entering runlevel: 5
Starting OpenBSD Secure Shell server: sshd
generating ssh RSA key...
generating ssh DSA key...
done.
Starting Advanced Configuration and Power Interface daemon: acpid.
acpid: starting up with proc fs
acpid: opendir(/etc/acpi/events): No such file or directory
starting Busybox inetd: inetd... done.
Starting ntpd: done
Starting syslogd/klogd: done
Cisco FirePOWER Services Boot Image 6.2.3
asasfr login:
*** TIME: 14:34:37 UTC Oct 6 2018
*** TIME: 14:36:32 UTC Oct 6 2018
[ 0.005145] Security Framework initialized
[ 0.008052] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.015037] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.018162] Mount-cache hash table entries: 256
[ 0.020334] Initializing cgroup subsys memory
[ 0.022089] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.022089] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.022089] tlb_flushall_shift: 6
[ 0.023483] Freeing SMP alternatives: 12k freed
[ 0.027257] ACPI: Core revision 20130328
[ 0.032725] ACPI: All ACPI Tables successfully acquired
[ 0.040195] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.041009] smpboot: CPU0: Intel QEMU Virtual CPU version 1.5.0 (fam: 06, model: 02, stepping: 03)
[ 0.046000] Performance Events: unsupported p6 CPU model 2 no PMU driver, software events only.
[ 0.054294] smpboot: Booting Node 0, Processors #1[ 0.003000] kvm-clock: cpu 1, msr 0:8ccf9041, secondary cpu clock
[ 0.071101] KVM setup async PF for cpu 1
#2 OK
[ 0.071101] kvm-stealtime: cpu 1, msr 8c88ba40
[ 0.090171] Brought up 3 CPUs
[ 0.090073] KVM setup async PF for cpu 2
[ 0.090073] kvm-stealtime: cpu 2, msr 8c90ba40
[ 0.091013] smpboot: Total of 3 processors activated (7499.99 BogoMIPS)
[ 0.094830] devtmpfs: initialized
[ 0.097215] NET: Registered protocol family 16
[ 0.101804] ACPI: bus type PCI registered
[ 0.104483] PCI: Using configuration type 1 for base access
[ 0.155549] bio: create slab <bio-0> at 0
[ 0.159599] ACPI: Added _OSI(Module Device)
[ 0.160014] ACPI: Added _OSI(Processor Device)
[ 0.161000] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.161000] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.169454] ACPI: Interpreter enabled
[ 0.170026] ACPI: (supports S0 S5)
[ 0.171000] ACPI: Using IOAPIC for interrupt routing
[ 0.171238] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.174269] ACPI: No dock devices found.
[ 0.205448] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.207026] acpi PNP0A03:00: ACPI _OSC support notification failed, disabling PCIe ASPM
[ 0.208015] acpi PNP0A03:00: Unable to request _OSC control (_OSC support mask: 0x08)
[ 0.211438] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[ 0.214116] PCI host bridge to bus 0000:00
[ 0.216016] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.217016] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.218000] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.218000] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.219015] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfebfffff]
[ 0.240086] pci 0000:00:01.3: quirk: [io 0xb000-0xb03f] claimed by PIIX4 ACPI
[ 0.242053] pci 0000:00:01.3: quirk: [io 0xb100-0xb10f] claimed by PIIX4 SMB
[ 0.345245] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 *10 11)
[ 0.348689] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 *10 11)
[ 0.350119] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 10 *11)
[ 0.352000] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 10 *11)
[ 0.352470] ACPI: PCI Interrupt Link [LNKS] (IRQs *9)
[ 0.355000] ACPI: Enabled 16 GPEs in block 00 to 0F
[ 0.357671] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.358014] vgaarb: loaded
[ 0.359000] vgaarb: bridge control possible 0000:00:02.0
[ 0.360564] SCSI subsystem initialized
[ 0.361014] ACPI: bus type ATA registered
[ 0.365318] ACPI: bus type USB registered
[ 0.367549] usbcore: registered new interface driver usbfs
[ 0.369222] usbcore: registered new interface driver hub
[ 0.371365] usbcore: registered new device driver usb
[ 0.374181] pps_core: LinuxPPS API ver. 1 registered
[ 0.375010] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.376232] PTP clock support registered
[ 0.379162] PCI: Using ACPI for IRQ routing
[ 0.383166] NetLabel: Initializing
[ 0.384010] NetLabel: domain hash size = 128
[ 0.386008] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.387047] NetLabel: unlabeled traffic allowed by default
[ 0.388000] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.388000] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.389666] hpet0: 3 comparators, 64-bit 100.000000 MHz counter
[ 0.394701] amd_nb: Cannot enumerate AMD northbridges
[ 0.395011] Switching to clocksource kvm-clock
[ 0.396692] pnp: PnP ACPI init
[ 0.398228] ACPI: bus type PNP registered
[ 0.404941] pnp: PnP ACPI: found 8 devices
[ 0.406904] ACPI: bus type PNP unregistered
[ 0.449793] NET: Registered protocol family 2
[ 0.452994] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.457520] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.460919] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.464085] TCP: reno registered
[ 0.465652] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.468519] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.471856] NET: Registered protocol family 1
[ 0.474541] RPC: Registered named UNIX socket transport module.
[ 0.477306] RPC: Registered udp transport module.
[ 0.479539] RPC: Registered tcp transport module.
[ 0.481736] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.484715] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
[ 0.487499] pci 0000:00:01.0: PIIX3: Enabling Passive Release
[ 0.490251] pci 0000:00:01.0: Activating ISA DMA hang workarounds
[ 0.493549] Trying to unpack rootfs image as initramfs...
[ 2.744610] Freeing initrd memory: 37844k freed
[ 2.770738] microcode: CPU0 sig=0x623, pf=0x0, revision=0x1
[ 2.773463] microcode: CPU1 sig=0x623, pf=0x0, revision=0x1
[ 2.776117] microcode: CPU2 sig=0x623, pf=0x0, revision=0x1
[ 2.779174] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 2.786206] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 2.790134] VFS: Disk quotas dquot_6.5.2
[ 2.792153] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.796734] NFS: Registering the id_resolver key type
[ 2.799188] Key type id_resolver registered
[ 2.801171] Key type id_legacy registered
[ 2.803557] msgmni has been set to 4423
[ 2.808086] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 2.811575] io scheduler noop registered
[ 2.813440] io scheduler deadline registered
[ 2.815609] io scheduler cfq registered (default)
[ 2.820981] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ 2.824434] ACPI: Power Button [PWRF]
[ 2.835466] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 2.841830] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
[ 2.848659] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 2.857563] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.888435] 00:05: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.919220] 00:06: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 2.925951] Non-volatile memory driver v1.3
[ 2.927956] Linux agpgart interface v0.103
[ 2.931349] [drm] Initialized drm 1.1.0 20060810
[ 2.934850] Floppy drive(s): fd0 is 1.44M, fd1 is 1.44M
[ 2.946565] brd: module loaded
[ 2.950802] FDC 0 is a S82078B
[ 2.955575] loop: module loaded
[ 2.963127] vda: vda1 vda2 vda3 < vda5 vda6 vda7 >
[ 2.971991] Loading iSCSI transport class v2.0-870.
[ 2.983750] scsi0 : ata_piix
[ 2.985895] scsi1 : ata_piix
[ 2.987704] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xc0c0 irq 14
[ 2.990875] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xc0c8 irq 15
[ 2.994836] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 2.997775] e100: Copyright(c) 1999-2006 Intel Corporation
[ 3.000576] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.0.3-k
[ 3.003755] igb: Copyright (c) 2007-2013 Intel Corporation.
[ 3.006566] Fusion MPT base driver 3.04.20
[ 3.008497] Copyright (c) 1999-2008 LSI Corporation
[ 3.010816] Fusion MPT SPI Host driver 3.04.20
[ 3.013187] Fusion MPT FC Host driver 3.04.20
[ 3.015435] Fusion MPT SAS Host driver 3.04.20
[ 3.018364] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.021425] ehci-pci: EHCI PCI platform driver
[ 3.023689] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.026778] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.030280] usbcore: registered new interface driver usblp
[ 3.033088] usbcore: registered new interface driver usb-storage
[ 3.036321] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[ 3.042375] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 3.044800] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 3.048136] mousedev: PS/2 mouse device common for all mice
[ 3.053210] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 3.056282] rtc_cmos 00:00: RTC can wake from S4
[ 3.057929] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[ 3.058565] rtc_cmos 00:00: alarms up to one day, 114 bytes nvram, hpet irqs
[ 3.059128] i2c /dev entries driver
[ 3.059749] md: raid1 personality registered for level 1
[ 3.070384] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 3.075516] cpuidle: using governor ladder
[ 3.078673] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.090427] usbcore: registered new interface driver usbhid
[ 3.093060] usbhid: USB HID core driver
[ 3.095298] ipip: IPv4 over IPv4 tunneling driver
[ 3.098820] TCP: cubic registered
[ 3.100483] Initializing XFRM netlink socket
[ 3.102921] NET: Registered protocol family 10
[ 3.105904] NET: Registered protocol family 17
[ 3.108151] Key type dns_resolver registered
[ 3.111545] registered taskstats version 1
[ 3.114906] console [netcon0] enabled
[ 3.116671] netconsole: network logging started
[ 3.147989] ata1.00: ATA-7: QEMU HARDDISK, 1.5.0, max UDMA/100
[ 3.150772] ata1.00: 6291456 sectors, multi 16: LBA48
[ 3.154517] ata1.00: configured for MWDMA2
[ 3.157346] scsi 0:0:0:0: Direct-Access ATA QEMU HARDDISK 1.5. PQ: 0 ANSI: 5
[ 3.157353] ata2.00: ATAPI: QEMU DVD-ROM, 1.5.0, max UDMA/100
[ 3.159171] ata2.00: configured for MWDMA2
[ 3.167271] sd 0:0:0:0: [sda] 6291456 512-byte logical blocks: (3.22 GB/3.00 GiB)
[ 3.167883] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.173443] scsi 1:0:0:0: CD-ROM QEMU QEMU DVD-ROM 1.5. PQ: 0 ANSI: 5
[ 3.173651] sd 0:0:0:0: [sda] Write Protect is off
[ 3.173734] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.185537] sda: unknown partition table
[ 3.185939] sr0: scsi3-mmc drive: 4x/4x cd/rw xa/form2 tray
[ 3.185943] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.187933] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 3.196541] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.199108] Freeing unused kernel memory: 896k freed
Starting udev [ 3.490708] udevd (765): /proc/765/oom_adj is deprecated, please use /proc/765/oom_score_adj instead.
[ 3.495074] udevd version 124 started
[ 3.687983] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input2
[ 3.767434] tsc: Refined TSC clocksource calibration: 1249.999 MHz
[ 3.817209] end_request: I/O error, dev fd0, sector 0
[ 3.840177] end_request: I/O error, dev fd0, sector 0
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
done.
Configuring sudo
Configuring ntpdate
adding crontab
done.
Starting ntpd: done
@Mohammad Rahman,
It appears you have installed the boot image but not the system package.
Have you tried to session into the module and complete the installation?
Thank you Marvin and you are right I do not have pkg file.
Thx for your reply :-).
But I have started an fresh install and let it "run" for over 24 hours and still it status is Recovery/Unknown. During install I loose connection to the console and it isn't possible to recover.
My problem is that I have a large installation comming up which has a hard deadline in march. I really must have a running ASA w. firepower at that time. Of course I could go with 5.4, but I would really prefer to be running with a 6.x.
A quick update: I tried to install patch 5.4.1.5-24 and got another failure. See attached screenshot. The upgrade appears to attempt to install the previous incremental patches before applying the most recent one—a cumulative patch process. This attempt seems to have failed during the 5.4.1.2 phase. I went back and tried to apply the previous patches one by one and got the same error: "Unknown Failure Condition." The failure point always seems to occur between 30% and 40% into the process. Each upgrade attempt took a LONG time (about 8 hours). After the first 30 minutes or so the task status in ASDM stopped updating. A refresh of the page then throws a connection refused error. The only thing to do then is to let the patch installer reach a failure condition which takes another few hours.
–Tim
That's exactly what happens with mine. If I monitor the upgrade via ASDM task status it will update and display the % complete until the process crashes. Then you basically get the ASDM equivalent of a 404 error. Monitoring via the CLI gives a similar result. It doesn't matter whether I do a patch, upgrade, or a clean install of 6.0. It also doesn't matter whether I use the files on Cisco.com or the files from Sourcefire's support site. Same result.
This happens not only with the 6.0 upgrade, but also the simple 5.4 patches (e.g. 5.4.1.3, 5.4.1.4). I can't go beyond the default version 5.4.1 whether patching, upgrading, or a clean install.
Hi All,
I need to upgrade the patching for Firepower module in ASA5506X and I need to use CLI. I did search lots and after searching I found the processes for Firepower Management Center and ASDM but no luck for CLI process. Please help me finish my job and I need assistance immediately.
If the upgrade is failing via FMC or ASDM, using the cli likely won't make it succeed.
You need to analyze the log file and see why it failed. Often TAC assistance is required for this analysis.
If you really want to upgrade using the cli (usually not recommended and not Cisco-supported), you can follow the steps outlined in this external blog post:
https://ciscoskills.net/2017/07/12/update-firepower-devices-manually/
Thank you Marvin for your quick reply. I noticed the link you sent me that is for FTD but I have ASA 5506X with Firepower Services. I loaded image and pkg files. I need to install Cisco_Network_Sensor_Patch-6.2.3.5-52.sh.REL.tar now. I am confused about Cisco said do not untar and what it means please explain me. I am new for this. I have browsed lot of links but I did not find any reliable answers. Thank you again for your responses.
Mohammad Rahman
Ah OK - it is a patch file not an upgrade. I haven't seen any instructions for applying a patch via cli.
For upgrade files, FTD and ASA Firepower module behave pretty similarly.
In either case, I would recommend you open a TAC case if the patch installation isn't completing properly when attempting via a manager (whether it be ASDM or FMC). If a previous attempt is "stuck", manual intervention by a qualified TAC engineers may be necessary. If you try to "force" it via cli it may make things worse.
Thank you Marvin for your quick response and you are right Patch can not be done with CLI. I did search lots but I did not find any material about. I also got help from Cisco TAC and they said like you. I will notify my Lead about it.
Mohammad Rahman
Hi All,
I need to upgrade the patching Network_Sensor_Patch-6.X.X.X-52.sh.REL.tar to 5506X for Firepower module in ASA5506X and I need to use CLI. I did search lots and after searching I found the processes for Firepower Management Center and ASDM but no luck for CLI process. Please help me finish my job and I need assistance immediately.
Sheraz.Salim
Same issue with mine 5506x. running
Cisco Adaptive Security Appliance Software Version 9.6(1)
Device Manager Version 7.6(1)
firepower 6.0 pkg not working either on mine.
Data Plane Status:  Not Applicable
Console session:    Ready
Status:             Recover
kindly please suggest what is the fix.
please do not forget to rate.
