ASA5510 SMTP problems
Adam Hudson
Up until recently one of my sites was able to get to a postini subnet. Then we started recieving "host unreachable" e-mails. Postini told us SMTP traffic was not getting let in. I've compared the current config to a config that was saved before the issue popped up and found really no noticeable difference.
I tried a packet tracer trace with no luck:
SiteB-Firewall# packet-tracer input outside tcp 11.2.2.36 12345 65.19.0.0 25
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Attached is a sanitized config. I'm not entirely convinced it's a firewall issue, but I need to some successful testing to prove otherwise.
18 Replies 18
Reconfigured NAT to use seperate public IP addresses for our mail (SMTP) and RDP, using the following commands on the existing config:
no static (inside,outside) tcp interface 3389 11.22.33 3389 netmask 255.255.255.255
no static (inside,outside) tcp interface smtp access-list postini-nat
static (inside,outside) 25.107.253.4 11.22.33 netmask 255.255.255.255
static (inside,outside) 25.107.253.5 11.22.36 netmask 255.255.255.255
access-list incoming extended permit tcp any host 25.107.253.4 eq 3389
access-list incoming extended permit tcp 65.19.0.0 255.255.240.0 host 25.107.253.5 eq smtp
access-list incoming extended permit icmp any any
access-group incoming in interface outside
These commands did not let the mail through. In addition, after restarting the router, now the firewall can't get to anything on the internal network and I can't remote directly into it. I have to telnet into it through the local router.
Attached is sanitized config of that router. I need to figure out why the mail isn't getting through and additionally why now the firewall can't get into the internal network.
Ping results:
Router to inside int of Firewall: Good
Rtr to outside int of FW: Good
Rtr to IPS address (past FW): Good
Firewall to router on int that connects the 2: Good
FW to RTR int on the internal network: Fail
FW to RTR's mpls port: Fail
FW to internal network address (it's own Site): Fail
FW to internal network address (another site): Fail
Tried "clear xlate", have not power cycled the ASA though.
More output:
SiteB-Firewall# sh eigrp neighbors
EIGRP-IPv4 neighbors for process 102
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   11.255.2.2              Et0/1            14  19:25:28 2    200   0   11
SiteB-Firewall# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 25.107.253.1 to network 0.0.0.0
C    25.107.253.0 255.255.255.248 is directly connected, outside
C    11.255.2.0 255.255.255.252 is directly connected, inside
S*   0.0.0.0 0.0.0.0 [1/0] via 25.107.253.1, outside
SiteB-Firewall# sh eigrp topology
EIGRP-IPv4 Topology Table for AS(102)/ID(25.107.253.3)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 0.0.0.0 0.0.0.0, 1 successors, FD is 28160
        via Rstatic (28160/0)
P 11.255.2.0 255.255.255.252, 1 successors, FD is 2816
        via Connected, Ethernet0/1
Complete updated ASA config attached.
