ASA5525-x Failed to locate egress interface for ICMP from Inside:
benningtonr
I am swapping out a 5505 with a 5525-X and I am having trouble setting it up. Than you for any and all help.
y.y.y is my main office public subnet
x.x.x is the remote site IP address
.3.0 is the inside at remote site and
96.0, 5.0, 172.16. are at main office
ASA Version 9.1(2)
hostname ASA5525
domain-name my.local
enable password fgzfbgfzdgfdszgz encrypted
passwd sdfgvszxDFgSZDfv encrypted
names
interface GigabitEthernet0/0
description Outside Interface
nameif Outside
security-level 0
ip address x.x.x.179 255.255.255.240
interface GigabitEthernet0/1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/6
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/7
description Inside Interface
nameif Inside
security-level 100
ip address 192.168.3.1 255.255.255.0
interface Management0/0
management-only
shutdown
nameif management
security-level 100
boot system disk0:/asa912-smp-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name hello.local
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network NETWORK_OBJ_192.168.3.0_24
subnet 192.168.3.0 255.255.255.0
object network NETWORK_OBJ_192.168.96.0_22
subnet 192.168.96.0 255.255.252.0
object network Global_NAT
object-group network DM_INLINE_NETWORK_1
network-object 172.16.16.0 255.255.255.0
network-object 192.168.5.0 255.255.255.0
network-object 192.168.96.0 255.255.252.0
access-list Outside_access_in extended permit ip host y.y.y.2 any
access-list Outside_cryptomap extended permit ip 192.168.3.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
access-list Inside_access_in extended permit ip 192.168.3.0 255.255.255.0 any
pager lines 24
logging enable
logging timestamp
logging buffer-size 1048576
logging asdm-buffer-size 512
logging monitor informational
logging buffered informational
logging asdm informational
mtu Outside 1500
mtu Inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit host y.y.y.2 Outside
icmp permit host y.y.y.230 Outside
icmp permit 192.168.3.0 255.255.255.0 Inside
icmp permit 192.168.96.0 255.255.240.0 Inside
asdm image disk0:/asdm-716.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (any,Outside) source dynamic any interface
nat (Inside,Outside) source static NETWORK_OBJ_192.168.3.0_24 NETWORK_OBJ_192.168.3.0_24 destination static DM_INLINE_NETWORK_1 DM_INLINE_NETWORK_1 no-proxy-arp route-lookup
access-group Outside_access_in in interface Outside
access-group Inside_access_in in interface Inside control-plane
route Outside 0.0.0.0 0.0.0.0 98.174.222.177 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 192.168.3.0 255.255.255.0 Inside
http 192.168.96.0 255.255.240.0 Inside
http y.y.y.2 255.255.255.255 Outside
http y.y.y.230 255.255.255.255 Outside
snmp-server host Inside 192.168.99.69 community ***** version 2c
snmp-server location remote Office
snmp-server contact my name
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto ipsec security-association pmtu-aging infinite
crypto map Outside_map 1 match address Outside_cryptomap
crypto map Outside_map 1 set pfs group1
crypto map Outside_map 1 set peer y.y.y.2
crypto map Outside_map 1 set ikev1 transform-set ESP-AES-256-MD5
crypto map Outside_map 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map Outside_map interface Outside
crypto ca trustpool policy
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable Outside
crypto ikev2 enable Inside
crypto ikev1 enable Outside
crypto ikev1 enable Inside
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh y.y.y.2 255.255.255.255 Outside
ssh 192.168.3.0 255.255.255.0 Inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access Inside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
group-policy GroupPolicy_y.y.y.2 internal
group-policy GroupPolicy_y.y.y.2 attributes
vpn-tunnel-protocol ikev1 ikev2
username ronb password dasfdfsdfasdfasdfasdf encrypted privilege 15
tunnel-group y.y.y.2 type ipsec-l2l
tunnel-group y.y.y.2 general-attributes
default-group-policy GroupPolicy_y.y.y.2
tunnel-group y.y.y.2 ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Rishabh Seth
Level 7
Level 7
Can you provide some more details about the issue that you are facing. Also share packet tracer output for the intended traffic.
Rishabh Seth
It could be a missing icmp-inspection. Add the following to your config:
  inspect icmp
