ASDM Problem After Upgrade
ctucker
I upgraded an asa5510 fw to asa version 8.0.4 and asdm to version 6.1.3. Since the asdm upgrade I am able to login to asdm, but when I click on the "Configuration" tab I receive the following error, "You are authorized only Home and Monitoring Views."
Can someone please help me with this problem?
wong34539
Level 6
Level 6
ASDM 6.1(1)F is not working from browser against 3.2.x images. The reason is that ASDM 6.1(1)F switched to java webstart instead of java applet. In FWSM 4.0 platform team made some changes to support ASDM 6.1(1)F web start. At this point we have this limitation. You may see the bug CSCsu00734.
Thanks Wong for the information, but I contacted Cisco and they solved the problem I had by doing the fillowing:
(config)# no username administrator
(config)# username administrator password privilege
(config)# wr mem
It is not clear why the upgrade changed the privilege level.
