BGP between two remote FTD
I have two Firepowers in two remote offices and i have two ISPs in each office, i had configured vti ipsec vpn between two offices but they are working with static routes, can i configure dynamic routing protocols for failover vpn? I tried to configure BGP but neighbours idle, what can you advice?
18 Replies 18
Share the config of vti and bgp of ftd
MHM
Site A FMC configuration
Site B FDM configuration
Thanks for sharing
Now each FW have dual ISP
-config two VTI each one have it interface
- config two static route one for each VTI tunnel destination
-config bgp with two neighbors' one for each vti
MHM
i have configured two vti and static routes everything works fine except BGP, i can ping each side with static route but i want dynamic update routes by BGP, in my case BPG neighbours are idle configuration i shared you, what can i do to up neighbours? Do i need to open 179 port from WAN?
Can I see
Show run router <- from firepower cli
MHM
Sure
Spoiler
> show route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, V - VPN
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, + - replicated route
SI - Static InterVRF, BI - BGP InterVRF
Gateway of last resort is x.x.x.x to network 0.0.0.0
S* 0.0.0.0 0.0.0.0 [1/0] via y.y.y.x, Link-to-ISP1
C 10.20.82.0 255.255.255.252 is directly connected, vti_10.20.82.1
L 10.20.82.1 255.255.255.255 is directly connected, vti_10.20.82.1
C 10.20.82.4 255.255.255.252 is directly connected, vti_10.20.82.5
L 10.20.82.5 255.255.255.255 is directly connected, vti_10.20.82.5
C 10.20.82.12 255.255.255.252 is directly connected, vti_10.20.82.13
L 10.20.82.13 255.255.255.255 is directly connected, vti_10.20.82.13
C 10.20.82.16 255.255.255.252 is directly connected, vti_10.20.82.17
L 10.20.82.17 255.255.255.255 is directly connected, vti_10.20.82.17
S 10.57.0.0 255.255.0.0 [1/0] via 10.20.82.2, vti_10.20.82.1
C 10.56.0.0 255.255.254.0 is directly connected, Network_Management
L 10.56.0.1 255.255.255.255 is directly connected, Network_Management
C 10.56.10.0 255.255.254.0 is directly connected, Server_Management
L 10.56.10.1 255.255.255.255 is directly connected, Server_Management
C 10.56.12.0 255.255.255.0 is directly connected, Shared_Server
L 10.56.12.1 255.255.255.255 is directly connected, Shared_Server
C 10.56.14.0 255.255.254.0 is directly connected, WLAN_Management
L 10.56.14.1 255.255.255.255 is directly connected, WLAN_Management
C 10.56.16.0 255.255.254.0 is directly connected, Production_3
L 10.56.16.1 255.255.255.255 is directly connected, Production_3
C 10.56.18.0 255.255.255.128 is directly connected, PRODUCTION_1
L 10.56.18.1 255.255.255.255 is directly connected, PRODUCTION_1
C 10.56.18.128 255.255.255.128 is directly connected, PRODUCTION_2
L 10.56.18.129 255.255.255.255 is directly connected, PRODUCTION_2
C 10.56.19.0 255.255.255.0 is directly connected, PRODUCTION_Server
L 10.56.19.1 255.255.255.255 is directly connected, PRODUCTION_Server
C 10.56.20.0 255.255.254.0 is directly connected, 4_PRODUCTION
L 10.56.20.1 255.255.255.255 is directly connected, 4_PRODUCTION
C 10.56.22.0 255.255.254.0 is directly connected, Wi-Fi_Leaders
L 10.56.22.1 255.255.255.255 is directly connected, Wi-Fi_Leaders
C 10.56.24.0 255.255.248.0 is directly connected, Wi-Fi_Employee
L 10.56.24.1 255.255.255.255 is directly connected, Wi-Fi_Employee
C 10.56.32.0 255.255.248.0 is directly connected, Wi-Fi_Guest
L 10.56.32.1 255.255.255.255 is directly connected, Wi-Fi_Guest
C 10.56.40.0 255.255.248.0 is directly connected, Maintenance_Device
L 10.56.40.1 255.255.255.255 is directly connected, Maintenance_Device
C 10.56.48.0 255.255.248.0 is directly connected, VoIP
L 10.56.48.1 255.255.255.255 is directly connected, VoIP
C 10.56.56.0 255.255.252.0 is directly connected, End_Device
L 10.56.56.1 255.255.255.255 is directly connected, End_Device
C 10.56.64.0 255.255.240.0 is directly connected, End_User
L 10.56.64.1 255.255.255.255 is directly connected, End_User
V 10.56.80.10 255.255.255.255
connected by VPN (advertised), Link-to-ISP1
C 10.56.86.0 255.255.254.0 is directly connected, Camera
L 10.56.86.1 255.255.255.255 is directly connected, Camera
S 10.58.0.0 255.255.0.0 [1/0] via 10.20.82.14, vti_10.20.82.13
C y.y.y.0 255.255.255.0 is directly connected, Link-to-ISP2
L y.y.y.y 255.255.255.255 is directly connected, Link-to-ISP2
V 192.168.70.6 255.255.255.255
C x.x.x.y 255.255.255.240
is directly connected, Link-to-ISP1
L x.x.x.x 255.255.255.255
The neighbor command you have configured should be the VTI interface IP of the remote side, verify that this is correct on both ends.
Is BGP flapping or just never being established?
Are you using BGP authentication? if yes, have you verified that the passwords match on both sides?
Are you redistributing connected and / or static?  If yes, remember to configure route maps to exclude the public IP (VTI source IP) from being learned over BGP as this will cause problems.
Please remember to select a correct answer and rate helpful posts
@Marius Gunnerud  написал (-а):
I need BGP to failover VTI interfaces, to send traffic from secondary VTI if main VTI down. I configured BGP neighbours with WAN IP and it is never estabilished, i don't use authentication
You need to use the VTI interface IP in the neighbor command, not the WAN IP.
VTI IP need to use in bgp 10.20.82.14' 10.20.82.13'
The WAN IP need to add as static for both ISP' i.e.
WAN IP for VTI1 have it static route
WAN IP of VTI2 have it static route
Please I need to see
Show run router
not show route
MHM
@MHM Cisco World  написал (-а):
Spoiler
Show run router
not show route
MHM
> show running-config router
router bgp 4XXXXXXX8
bgp log-neighbor-changes
bgp router-id vrf auto-assign
address-family ipv4 unicast
neighbor a.a.a.a remote-as 4XXXXXXX9
neighbor a.a.a.a transport path-mtu-discovery disable
neighbor a.a.a.a activate
network 10.56.0.0 mask 255.255.0.0
no auto-summary
no synchronization
exit-address-family
Can you give example for this please i dont understand?
this is topology and not you need for your requirement
Sorry for my stupid question but i cant understand why we need static route toward WAN IP1 using interface WAN IP2
static route toward WAN IP1 (FTD2) using interface WAN IP1 (FTD1)
This what I meaning
MHM
