Block Certain Websites (URLs) Using Regular Expressions
jibinkg
hello everyone i am kinda new to cisco product, i have cisco asa 5510 as firewall, i was trying to block some site using the link provided below
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080940e04.shtml#tshoot
and its working fine, but the problem i am having, when i go to download attachment from hotmail its not downloading, from gmail and other mails its
working any one could help me on this
14 Replies 14
Nagaraja Thanthry
Can you please post your configuration here (both regular expression statements and class-map/policy-map statements)?
NT
thanks for reply, and sorry for the late reply from i was away for some time from the work  iam attaching the screen shots of regular expression, classmap and inspect map also policy which i created
from CLI can you paste the show run regex, show run class-map and show run policy-map?
yes these are the results, and thanks for the reply
show run regex
regex urllist1 ".*\.([Ff][Ll][Vv])HTTP/1.[01]"
regex domainlist1 "\.youtube\.com"
regex ares "[ares]"
regex contenttype "Content-Type"
regex applicationheader "application/.*"
show run class-map
class-map inside-unres-band-in
description Assign 16MB  unrestricted IPs outgoing request
match access-list inside_mpc
class-map inside-class-unrestricted-in
description Prioritize unrestricted IPs outgoing request
match access-list inside_mpc_2
class-map type regex match-any DomainBlocklist
match regex domainlist1
class-map type inspect http match-all BlockDomainClass
match request header host regex class DomainBlocklist
class-map type regex match-any block
match regex _default_x-kazaa-network
match regex _default_aim-messenger
match regex _default_gator
class-map inside-unres-band-out
description Assign 16MB unrestricted IPs return traffic
match access-list inside_mpc_1
class-map inspection_default
match default-inspection-traffic
class-map inside-class-unrestricted-out
description Prioritize unrestricted IPs return traffic
match access-list inside_mpc_3
show run policy-map
in the policy-map i have some rules for badwidth restrictions. and i have the httpaccess rule (site blocking). on top of the default class map rule
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect sip
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect xdmcp
  inspect rtsp
policy-map type inspect http http_inspec_allow
parameters
  protocol-violation action drop-connection
match request method connect
  log
class BlockDomainClass
  log
policy-map type inspect http Ares
parameters
match request uri regex ares
  drop-connection log
policy-map type inspect http block
parameters
match request uri regex class block
  drop-connection log
policy-map type inspect http http_inspec_pol
parameters
  drop-connection log
  reset
policy-map type inspect im IM-Inspect-map
parameters
match protocol msn-im yahoo-im
  drop-connection
policy-map inside-policy-res-bandwidth
class inside-unres-band-in
  police input 16000000 8000
  police output 16000000 8000
class inside-class-unrestricted-in
class inside-unres-band-out
class inside-class-unrestricted-out
class httpaccess
class class-default
  police input 4500000 2700
  police output 4500000 2700
policy-map type inspect im imallow
parameters
  log
Hi Jibin,
Does the ASA log any syslogs when the connection is blocked?
Also,  could you get a packet capture on the client for a connection that is  blocked? I don't have a Hotmail account to test with, but I'm wondering  if this regex might be matching something in the request:
regex ares "[ares]"
-Mike
hello
yes syslog is ther, and also i have another problem one i put this rule in policy after sometime syslog will loose connection
i dont know i have can i capture packet from asa can you help me on this.
i have the syslog reports if you want below
attaching as txt file
and the regex ares wasnt really using i was using that for testing i removed all that and tried its same problem
can you include the show run service-policy?
yes this is the result
Result of the command: "show run service-policy"
service-policy global_policy global
service-policy inside-policy-res-bandwidth interface inside
have you tried applying the inspect http inside the global policy?
Like this:
class httpaccess
i havent tried in global policy i will try that i let you know
thanks
yes i tried in the global policy still same problem
Hey folks,
i have also used the same method and it just work fine additionally i have placed a small policy map on internet edge router which deprecate the required traffic which is identified by NBAR to dscp 1 and a url list which says nothing comins in with .torrent.
after this i have seen a huge difference in my network traffic which is aprox 289 Gigs IN and 345 Out the difference is from last 15 days.
vinlata2007
Hi Jibbin,
I know it's been awhile, but wonder if you got solutions to your issues? I tried to do the same, want to block some cloud video service and internet radio like netflix, hulu, pandora...it seemed working great as for blocking those sites but at the same time it block certain web forms and active-X apps from other business sites (not on the url block lists) as well.  I can log on to hotmail, gmail and check
email no problem.
