Can I drop an inbound to outside interface connection to my ASA 5520
whiteford
From Netflow Analyazer I can see a connection from an external IP to my ASA's outside interface that's been going for 2 hours and downloaded 3GB of data so far, how can I kill this conenction? It's a http connection.
6 Replies 6
cisco24x7
Level 6
Level 6
you can shun the connection or perform a "clear
xlate" on that connection
Thanks, would do I type after "clear xlate"? if the IP I need to drop is 1.2.3.4?
clear local-host is good for this also.
Thanks, will this drop that single external IP that's comming inbound? I don't want to drop all connections.
that will drop all active network connections by whichever address you specify:
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/c3_72.html#wp2046006
Brent Rockburn
Level 2
Level 2
Why don't you just put up an ACL blocking that IP on the outside interface?
