Certified Timer problem on NAC v4.7.2
s.demosthenous
I have upgraded a NAC server pair from v4.1.3 to v4.7.2.Before the upgrade the upgrade the Cerified timer was working and all the clients were removed each day at a specified time.After the upgrade the timer is not working properly.Each day i have to manually removed the cerified.
Any help?
Thank you,
Stratos Demosthenous
Faisal Sehbai
Level 7
Level 7
Stratos,
Did you verify after the upgrade that there weren't any database errors? This can be done by running the showstate.sh script (as detailed in the upgrade notes)
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
Hello Faisal,
I have switch to the CAM secondary appliance and the Certified timer is working fine now.
I will check for DB errors and move back to CAM primary to verify.
Thank you,
