Cisco 515 Static Translation problem
thestagman
I'm having some problems connecting to an address specified in the static translation command (194.70.60.3). I can ping the outside interface 194.70.60.2 no probs. But not this .3 address.
The Pix outside interface is connected to a Router 194.x.60.1 and all routing is correct.
Below is my Pix config.. I for one can't see what I have done wrong.. A fresh pair of eyes may spot the issue straight way.
nameif ethernet0 outside security0
nameif ethernet1 inside security100
interface ethernet0 100full
interface ethernet1 100full
ip address outside 194.x.x.2 255.255.255.224
ip address inside 10.250.1.10 225 255.255.255.252
hostname MIL-PIX-001
arp timeout 14400
no failover
logging buffered debugging
nat (outside) 0 0.0.0.0 0.0.0.0
nat (inside) 0 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 194.70.60.1 1
route inside 10.0.0.0 255.0.0.0 10.250.1.9
access-list ping_acl permit icmp any any
access-group ping_acl in interface inside
access-group ping_acl in interface outside
Static (inside,outside) 194.70.60.3 10.250.1.9 netmask 255.255.255.255
Jon Marshall
Mike
have you tried debugging on the inside and outside interface to see how far the packet is getting
ie
debug packet inside dst 10.250.1.9
debug packet inside src 10.250.1.9
Jon
