Cisco ASA 5505 SSL/HTTPS/ASDM Won't work, Cipher fail
davebornack
Level 2
Level 2
Does my device not support enough encryption to get ASDM/SSL/HTTP working?
First time I've ever seen this...:
%ASA-7-609001: Built local-host inside:192.168.1.10
%ASA-7-609001: Built local-host identity:192.168.1.1
%ASA-6-302013: Built inbound TCP connection 13 for inside:192.168.1.10/61194 (192.168.1.10/61194) to identity:192.168.1.1/443 (192.168.1.1/443)
%ASA-6-725001: Starting SSL handshake with client inside:192.168.1.10/61194 for TLSv1 session.
%ASA-7-725010: Device supports the following 1 cipher(s).
%ASA-7-725011: Cipher[1] : DES-CBC-SHA
%ASA-7-725008: SSL client inside:192.168.1.10/61194 proposes the following 11 cipher(s).
%ASA-7-725011: Cipher[1] : DHE-DSS-AES256-SHA
%ASA-7-725011: Cipher[2] : AES256-SHA
%ASA-7-725011: Cipher[3] : DHE-RSA-AES256-SHA
%ASA-7-725011: Cipher[4] : DHE-RSA-AES128-SHA
%ASA-7-725011: Cipher[5] : DHE-DSS-AES128-SHA
%ASA-7-725011: Cipher[6] : RC4-MD5
%ASA-7-725011: Cipher[7] : RC4-SHA
%ASA-7-725011: Cipher[8] : AES128-SHA
%ASA-7-725011: Cipher[9] : EDH-RSA-DES-CBC3-SHA
%ASA-7-725011: Cipher[10] : EDH-DSS-DES-CBC3-SHA
%ASA-7-725011: Cipher[11] : DES-CBC3-SHA
%ASA-7-725014: SSL lib error. Function: SSL3_GET_CLIENT_HELLO Reason: no shared cipher
%ASA-6-302014: Teardown TCP connection 13 for inside:192.168.1.10/61194 to identity:192.168.1.1/443 duration 0:00:00 bytes 7 TCP Reset by appliance
%ASA-7-609002: Teardown local-host inside:192.168.1.10 duration 0:00:00
%ASA-7-609002: Teardown local-host identity:192.168.1.1 duration 0:00:00
14 Replies 14
Panos Kampanakis
Do you have "ssl encryption" command on the ASA that sets ciphers that are not matched with the client proposed ciphers?
Can you check using the ssl command?
PK
It responds with :
XXX algorithms require a VPN-3DES-AES activation key.
I've tried like.. 8 of the ones it says my client is proposing.
I shouldn't need a special license to get ASDM working out of the box..
Hmm, do you have a 3DES license on your ASA, or DES? "sh ver" should show you that.
If you have DES it will not do the algorithms for SSL encryption etc.
PL
"This platform has a base license"
So this means that I can't even run ASDM with a base license?
It is better you get a 3DES license for your ASA.
Otherwise, one way to get it working would be to change the cipher suites being sent by the client's browser. I am not really sure of how to do that but i am pretty sure google will give you good results.
Let me now how it goes!
Cheers,
Prapanch
You tried with different browsers and ssl settings?
Regards.
Great Answer Panagioti, it worked for me.. the answer was in front of our eyes!
%ASA-6-725001: Starting SSL handshake with client inside:xx.xx.xx.xx/59308 for TLS session.
%ASA-7-725010: Device supports the following 3 cipher(s).
%ASA-7-725011: Cipher[1] : AES256-SHA
%ASA-7-725011: Cipher[2] : DHE-RSA-AES128-SHA
%ASA-7-725008: SSL client inside:10.10.8.25/59308 proposes the following 2 cipher(s).
%ASA-7-725011: Cipher[1] : AES128-SHA
%ASA-7-725011: Cipher[2] : DES-CBC3-SHA
Thank you for pointing this!
Where is the answer? I dont see any comments from Panagioti
It was helpful, thanks!
I had the same problem which I was fighting with last couple days. I had to format and erase my flash during flash replacement, and ASA lost  activation code and all ciphers. After reading your post I realized what is wrong, restored the activation key and applied ciphers to SSL.
Thanks again!
Igor
MARK BAKER
Level 8
Level 8
I found this post, but didn't see the answer. I did find the answer elsewhere and wanted to update this post in case someone else has this issue. I had to enable a cipher that was compatible with my browser using the below command on the ASA.
ssl encryption aes256-sha1
Hope this helps someone find the answer quicker.
Mark
I have the same issue. It is helpful for me
Thanks...this was very helpful
THIS worked for me:
Thank you so much!!!!1
Fahadk
Visitor
firmware version 9.2 it doesn't support tlsv1.2
firmware version 9.4 on wards it support
QRCS-DC# sh run all ssl
ssl server-version any
ssl client-version any
ssl encryption rc4-sha1 dhe-aes128-sha1 dhe-aes256-sha1 aes128-sha1 aes256-sha1 3des-sha1
ssl certificate-authentication fca-timeout 2
version 9.4
ssl server-version tlsv1
ssl client-version tlsv1
ssl cipher default medium
ssl cipher tlsv1 medium
ssl cipher tlsv1.1 medium
ssl cipher tlsv1.2 medium
ssl cipher dtlsv1 medium
ssl dh-group group2
ssl ecdh-group group19
