Cisco ASA 5525 - Connection Loops observed on Outside interface
Dear Community,
We have HQ Site & 2 remote offices Site-A & Site-B. All 3 site are connected within MPLS managed cloud. We are seeing the Connection loops of the internal LAN subnets of Site-A & B  on the outside interface of HQ firewall(Cisco 5525-X). We have verified the routing on BGP & found on issues. Internal LAN subnets are configured behind the L3 switch with SVIs for both Site - A & Site -B.
Site-A : 10.28.0.0/16
Site-B : 10.41.0.0/16
Find logs, pls help us to understand this behavior , if it would have any adverse effect on the performance of the perimeter firewall?
pri/Firewall/act# show conn all | in OUTSIDE.*OUTSIDE
UDP OUTSIDE 10.28.17.58:5060 OUTSIDE 10.28.12.92:0, idle 0:00:16, bytes 0, flags ti
UDP OUTSIDE 10.28.17.58:9363 OUTSIDE 10.28.12.92:0, idle 0:00:16, bytes 0, flags mi
UDP OUTSIDE 10.28.17.58:9362 OUTSIDE 10.28.12.92:0, idle 0:00:16, bytes 0, flags mi
UDP OUTSIDE 10.41.18.144:5060 OUTSIDE 10.41.12.12:0, idle 0:00:48, bytes 0, flags ti
UDP OUTSIDE 10.41.18.144:8093 OUTSIDE 10.41.12.12:0, idle 0:00:48, bytes 0, flags mi
UDP OUTSIDE 10.41.18.144:8092 OUTSIDE 10.41.12.12:0, idle 0:00:48, bytes 0, flags mi
14 Replies 14
@ManadarDesai2895  traffic is spoofed or more likely a routing issue.
We'd need more information to determine the cause, please provide the output of "show route" and also run packet-tracer from the CLI between 10.41.18.144 and 10.41.12.12.
Hi Rob,
Find below output.
SH ROUTE:
sec/FIREWALL/act# sh route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, V - VPN
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, + - replicated route
SI - Static InterVRF
Gateway of last resort is 10.82.111.13 to network 0.0.0.0
S* 0.0.0.0 0.0.0.0 [1/0] via 10.82.111.13, OUTSIDE
S 10.0.222.212 255.255.255.255 [1/0] via 10.82.111.8, OUTSIDE
S 10.0.222.213 255.255.255.255 [1/0] via 10.82.111.8, OUTSIDE
D EX 10.0.236.204 255.255.255.255
[170/136960] via 10.82.111.8, 1d06h, OUTSIDE
C 10.1.1.0 255.255.255.0 is directly connected, LANFAIL
L 10.1.1.2 255.255.255.255 is directly connected, LANFAIL
D EX 10.1.101.97 255.255.255.255
D EX 10.1.103.0 255.255.255.0 [170/136960] via 10.82.111.8, 1d06h, OUTSIDE
C 10.2.1.0 255.255.255.0 is directly connected, LINKFAIL
L 10.2.1.2 255.255.255.255 is directly connected, LINKFAIL
D EX 10.4.139.0 255.255.255.0 [170/136960] via 10.82.111.8, 1d06h, OUTSIDE
D EX 10.4.140.22 255.255.255.255
D EX 10.4.238.220 255.255.255.255
D EX 10.10.0.0 255.255.0.0 [170/208640] via 10.82.111.2, 2d19h, OUTSIDE
D EX 10.10.111.0 255.255.255.224
D EX 10.10.135.9 255.255.255.255
D EX 10.10.135.10 255.255.255.255
D EX 10.10.135.11 255.255.255.255
D EX 10.28.0.0 255.255.0.0 [170/208640] via 10.82.111.2, 2d19h, OUTSIDE
D EX 10.28.52.0 255.255.254.0 [170/208640] via 10.82.111.2, 2d19h, OUTSIDE
D EX 10.28.111.0 255.255.255.240
D EX 10.57.0.0 255.255.0.0 [170/208640] via 10.82.111.2, 2d19h, OUTSIDE
D EX 10.57.111.0 255.255.255.240
D EX 10.57.111.224 255.255.255.252
D EX 10.59.119.66 255.255.255.255
D EX 10.59.120.52 255.255.255.255
D EX 10.41.0.0 255.255.0.0 [170/208640] via 10.82.111.2, 2d19h, OUTSIDE
D EX 10.41.111.0 255.255.255.240
D 10.82.0.0 255.255.0.0 is a summary, 2d19h, Null0
D 10.82.2.0 255.255.254.0 [90/3072] via 10.82.4.3, 2d19h, SBI
[90/3072] via 10.82.4.2, 2d19h, SBI
C 10.82.4.0 255.255.254.0 is directly connected, SBI
L 10.82.4.210 255.255.255.255 is directly connected, SBI
C 10.82.6.0 255.255.254.0 is directly connected, BKOFFICE
L 10.82.6.1 255.255.255.255 is directly connected, BKOFFICE
D 10.82.8.0 255.255.255.0 [90/3072] via 10.82.4.3, 2d19h, SBI
D 10.82.9.0 255.255.255.128 [90/3072] via 10.82.4.3, 2d19h, SBI
D 10.82.9.128 255.255.255.192 [90/3072] via 10.82.4.3, 2d19h, SBI
D 10.82.10.0 255.255.255.240 [90/3072] via 10.82.4.3, 2d19h, SBI
S 10.82.11.0 255.255.255.0 [1/0] via 10.82.4.1, SBI
D 10.82.12.0 255.255.255.128 [90/3072] via 10.82.4.2, 2d19h, SBI
D 10.82.12.128 255.255.255.128 [90/3072] via 10.82.4.2, 2d19h, SBI
S 10.82.16.0 255.255.254.0 [1/0] via 10.82.4.1, SBI
D EX 10.82.18.0 255.255.254.0
[170/2585856] via 10.82.111.13, 2d19h, OUTSIDE
S 10.82.20.0 255.255.255.0 [1/0] via 10.82.4.1, SBI
D 10.82.30.16 255.255.255.240 [90/3072] via 10.82.4.3, 2d19h, SBI
D 10.82.30.32 255.255.255.240 [90/3072] via 10.82.4.3, 2d19h, SBI
D 10.82.36.0 255.255.255.224 [90/3072] via 10.82.4.3, 2d19h, SBI
D 10.82.37.0 255.255.255.224 [90/3072] via 10.82.4.3, 2d19h, SBI
D 10.82.40.0 255.255.255.224 [90/3072] via 10.82.4.3, 2d19h, SBI
C 10.82.50.0 255.255.255.192 is directly connected, HCC
L 10.82.50.1 255.255.255.255 is directly connected, HCC
D 10.82.52.0 255.255.254.0 [90/3072] via 10.82.111.13, 2d19h, OUTSIDE
C 10.82.54.0 255.255.255.0 is directly connected, MPLS-DMZ
L 10.82.54.1 255.255.255.255 is directly connected, MPLS-DMZ
C 10.82.111.0 255.255.255.240 is directly connected, OUTSIDE
L 10.82.111.6 255.255.255.255 is directly connected, OUTSIDE
D 10.82.111.16 255.255.255.252
D 10.82.253.0 255.255.255.240 [90/3072] via 10.82.4.3, 2d19h, SBI
D EX 10.85.0.0 255.255.0.0 [170/208640] via 10.82.111.2, 2d19h, OUTSIDE
D EX 10.85.111.0 255.255.255.240
D EX 10.92.32.16 255.255.255.252
D EX 10.92.32.56 255.255.255.252
D EX 10.92.32.136 255.255.255.252
D EX 10.92.33.132 255.255.255.252
D EX 10.92.33.160 255.255.255.252
D EX 10.92.35.72 255.255.255.252
[170/239104] via 10.82.111.3, 2d19h, OUTSIDE
D EX 10.92.35.248 255.255.255.252
D EX 10.92.35.252 255.255.255.252
D EX 10.92.42.40 255.255.255.252
D EX 10.92.42.224 255.255.255.252
D EX 10.92.42.240 255.255.255.252
D EX 10.92.43.12 255.255.255.252
D EX 10.92.43.240 255.255.255.252
D EX 10.92.43.244 255.255.255.252
D EX 10.176.0.0 255.255.0.0
[170/136960] via 10.82.111.8, 00:10:41, OUTSIDE
D EX 10.177.128.57 255.255.255.255
D EX 10.186.49.146 255.255.255.255
[170/136960] via 10.82.111.8, 01:24:06, OUTSIDE
D EX 10.187.52.146 255.255.255.255
D EX 10.189.0.0 255.255.0.0
D EX 10.191.0.0 255.255.0.0
S 10.191.148.156 255.255.255.255 [1/0] via 10.82.111.8, OUTSIDE
S 10.191.148.157 255.255.255.255 [1/0] via 10.82.111.8, OUTSIDE
D EX 10.200.0.0 255.255.128.0 [170/208640] via 10.82.111.2, 2d19h, OUTSIDE
D EX 10.200.49.0 255.255.255.0
D EX 10.200.111.0 255.255.255.224
D EX 10.200.128.0 255.255.128.0
D EX 10.200.152.0 255.255.254.0
D EX 10.200.222.0 255.255.255.224
D EX 10.200.222.80 255.255.255.240
D EX 10.200.240.0 255.255.255.192
D EX 10.200.240.64 255.255.255.192
D EX 10.200.240.96 255.255.255.240
S 100.81.5.137 255.255.255.255 [1/0] via 10.82.111.7, OUTSIDE
S 100.81.5.185 255.255.255.255 [1/0] via 10.82.111.7, OUTSIDE
D EX 192.168.242.25 255.255.255.255
D EX 192.168.243.31 255.255.255.255
D EX 192.168.243.32 255.255.255.255
D EX 192.168.247.110 255.255.255.255
D EX 192.168.247.122 255.255.255.255
D EX 192.168.253.0 255.255.255.0
S 198.148.79.58 255.255.255.255 [1/0] via 10.82.111.13, OUTSIDE
Packet Tracer Output:
sec/FIREWALL/act# packet-tracer input outside udp 10.41.18.144 5060 10.41.12.12 5060
Phase: 1
Type: INPUT-ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
Found next-hop 10.82.111.2 using egress ifc OUTSIDE
Phase: 2
Type: ECMP load balancing
Subtype:
Result: ALLOW
Config:
ECMP load balancing
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: DROP
Config:
access-group OUTSIDE in interface OUTSIDE
access-list OUTSIDE extended deny ip any4 any4
Result:
input-interface: OUTSIDE
input-status: up
input-line-status: up
output-interface: OUTSIDE
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule, Drop-location: frame 0x000055fe77d4d73c flow (NA)/NA
@ManadarDesai2895 output interface from packet-tracer is the OUTSIDE interface.
Result:
input-status: up
output-status: up
Action: drop
This route is routing out the outside interface. - D EX 10.41.0.0 255.255.0.0 [170/208640] via 10.82.111.2, 2d19h, OUTSIDE
If this network (10.41.12.X ) is on the inside interface, add a static or resolve your routing issues.
HI Rob,
Both 10.41.12.XX & 10.41.18.XX are belongs to remote SITE-A. These both would learn from the OUTSIDE interface only.
@ManadarDesai2895 so the upstream device routing is incorrect if that traffic is routed to the ASA.
No Rob Have verified it on upstream router. Its forwarding towards PE router to the service provider end.
Wait sec
Both for site A then sure asa point to outside interface'
Why the source of packet is from ASA?
Make double check subnet
I Think asa is run as hub interconnect both site
I.e.
Site a to connect to site b the traffic must pass through asa.
No , Site-A would directly communicate with Site-B & vice versa. HQ is not a HUB for Site-A & Site-B. Its a mesh infra. Just wanted to know if this behavior would have any impact on the performance of the ASA?
sec/FIREWALL/act# packet-tracer input outside udp 10.41.18.144 5060 10.41.12.12 5060 <<- both for site-A so the packet tracer is OK no issue
ARE THE 10.28.17.x is for Site-B ??
UDP OUTSIDE 10.41.18.144:8092 OUTSIDE 10.41.12.12:0, idle 0:00:48, bytes 0, flags mi <<- this need to investigate. the site-A send packet to ASA and ASA reforward it to Site-A
why Site-A assume that this IP is not direct connect ?
can I see show route of Site-A
you meaning the overlapping ?
If Yes
then the SVI use /16 and what you receive from the MPLS is must be /24 not /16
Hi MHM,
SVIs are created with CIDR /23 or /24 & from BGP we have advertised /16 network.
Asa always prefer longest match'
SVI is correct/23 or /24
The bgp use redistrubte try' disable autosummary.
Or make bgp advertise/24 not /16
HI MHM,
IS there any impact of this doing to the production?
