06-14-2020 07:58 AM
Once the Firewall is set up, is there a way to configure the management port as regular ethernet port?
How can I do that and what would be the limitations?
Can I still have access to ASDM through this or other ports if I change it to regular port?
Thank you.
06-14-2020 08:11 AM
Try the following command from the CLI:-
interface management 0/0
no management-only
06-14-2020 08:20 AM
06-14-2020 08:15 PM
06-14-2020 10:33 PM
As far as I know, an ASA will not allow you to use any dedicated management interface (interface management x/x) for traffic through the device.
