05-17-2011 02:32 PM - edited 03-11-2019 01:34 PM
A customer's ASA is presenting the System LED flashing red.I have already analysed the show tech-support and show environment output: Found nothing, everythink seems OK.
They are not experiencing problems with the appliance.
Do you have any tips?
Cisco ASA 5580-20 - 8.2.1
Single appliance, no failover, multiple context and transparent mode.
Thanks in advance,
Pedro Mazzoni
05-17-2011 05:24 PM
Typically when the LED is flashing RED, there would have been syslog messages generated for that.
Since you have checked the show environment output and it's showing OK, I would open a TAC case to get it further investigated.
05-17-2011 05:27 PM
You can try accessing the diagnostic panel of the 5580 to see if it indicates where the problem might be.
http://www.cisco.com/en/US/docs/security/asa/hw/maintenance/5580guide/procedures.html#wp1101358
Hope this helps!
05-18-2011 01:14 AM
Did you find any problem checking rear panel of ASA?
http://www.cisco.com/en/US/docs/security/asa/hw/maintenance/5580guide/overview.html#wp1034846
Pavel
05-18-2011 07:11 AM
I have checked both rear panel and the diagnostic panel, everything seems OK.
I will try to check syslog messages again and find any systems problems.
05-24-2011 07:47 AM
I have checked the syslog messages and found nothing. I have reloaded the Firewall and everything is OK now, but the customer is not satisfied at all.
Unfortunately I don't know what happened, even analysing syslog messages and show tech-support output.
Pedro Mazzoni
04-16-2020 04:35 AM
I know this is an old post but I think this might be helpful to someone who might be having a similar issue with their ASA5580 with system led red and flashing.
With respect to the above issue what you can also do is to reseat or remove all the memory and replace them back. I have done this several time and it work, so give it a try before RMA the unit.
