Cisco ASA 9.X Packet flow
MoulaAli480
Could someone please help with Cisco ASA 9.X Packet flow. And also what is the exact difference between veriosn 8.2 and 9.X.
Moula Ali
That is high level i have provided,  if there is no NAT it go in to ACL Process. ( or am i confused here with question ?)
BB
6 Replies 6
balaji.bandi
ASA  packet flow as below :
ASA  8.2 to 9.X  Many changed , you can view by release :
https://www.cisco.com/c/en/us/td/docs/security/asa/roadmap/asa_new_features.html
BB
Hi Balaji,
Thanks for the explanation.
But I see in the latest versions packet tracer after the ingress interface
packet reaches it is checking nat first. Could you please confirm on this
one.
Moula Ali
Simulator or Packet Tracer of ASA ? please clarify and show is the output if you can.
BB
Hello Balaji,
Sorry I don't have lab to show packet tracer output. My query is simple and
clear ASA packet flow of latest version 9.x. I could not see NAT
untranslate step in your explanation.
Moula Ali
BB
IEbound
5/16/2023 Update to keep this current and hopefully assist.
Balaji had a good question about packet tracer. This data is from Cisco Modeling Labs (CML) 2.5 with the ASA v9.18(2) (System image file is "boot:/asa9182-smp-k8.bin"). The order below shows it depends if you are going from high security-level to low or if it's low to high as might be expected. Access lists are required low to high, but the traffic send high to low is permitted without them, so no check is made below.
Attached is a summary after which the full details (standard not detailed) are shown for further analysis for reviewers. These are for allowed traffic. It looks like the diagram above is good. A few more details are shown in the data, but nice work Balaji!
OUTSIDE to INSIDE: packet-tracer input outside icmp 150.1.35.5 8 0 150.1.55.8
Phase:
1 ROUTE-LOOKUP
2 ACCESS-LIST
3 NAT
4 IP-OPTIONS
5 QOS
6 INSPECT
7 FLOW-CREATION
8 ACCESS-LIST
9 NAT
10 IP-OPTIONS
11 INPUT-ROUTE-LOOKUP-FROM-OUTPUT-ROUTE-LOOKUP
12 ADJACENCY-LOOKUP
Result:
Action: allow
INSIDE TO OUTSIDE: packet-tracer input inside icmp 150.1.55.8 8 0 150.1.35.5
Phase:
1 ROUTE-LOOKUP
2 NAT
3 IP-OPTIONS
4 QOS
5 INSPECT
6 FLOW-CREATION
7 NAT
8 IP-OPTIONS
9 INPUT-ROUTE-LOOKUP-FROM-OUTPUT-ROUTE-LOOKUP
10 ADJACENCY-LOOKUP
Result:
Action: allow
