Cisco ASA drops communication between two interface even with an ACL allowing it
dtrinidad
Hello all,
currently I'm troulbeshooting the following Topology:
image 1
scenario:
  - All interface have access-list allowing the communication to every other IP range.
  - All the routes are known for each node.
  - The security-level of each interface is assigned as depicted in "image 1"
  - All ASA have the OS version 9.8(1)
  -  My focus is in ASA1 which is the one droping the packets
Problem:
  - hosts in the range 10.10.111.0/24 can't ping end diveces in network  10.10.222.0/24 and viceversa
  - host in the range of 10.10.111.0/24 and 10.10.222.0/24 can communicate 10.10.0.0/24 Bidirectionally
  - when I issue a packet tracer is tells the packet is droped by matching implicit deny by complete ignoring the "permit any any  ip" wich is the first line in the acl-rule.
My understanding:
   by default traffic from lower and equal security-level to higher is droped, however as I have access-list configured in each interface it should overwrite the security-level rule and if the rule allows some traffic it should be permited.
   however i notice in my situation I have traffic from security-level 60 to 100 being permited by the acl and it works,  but between the same security-level it doesn't.
   at the begining I though it could be related to some concept like nat-control but as I understood it should, the ASA version don't even support that feature.
Hello Community and thanks for your attempts of contacting, however I got to a solution, I did change the security level of one of the interface to be different and that allowed the ACL to take effect.
I had understand that  if there was an ACL in place the security level rule would be overwrite the apply ACL, but in my case it didn't.
Can you provide your configuration please?
Can you also provide the full output of the packet-tracer you ran
