Cisco ASA Inside Interface not pinging Router's LAN interface
Laide
Community Member
My Cisco ASA inside interface is not pinging the router's LAN interface but its pinging the public interface of the router.
what can be the cause.
"The error message is destination host unreachable".
9 Replies 9
Jon Marshall
It is not clear how the devices are interconnected but that error message suggests the ASA does not have a route for  the IP address assigned to the router’s LAN interface.
Jon
 What ASA? 5506? Could you enter the command (show interface ip brief) and post print? I would like to help you.
If you prefer you can call in private.
Hello silva,
thanks for the reply, the ASA is 5516-X
Do you have the command "icmp permit any INSIDE" in your firewall config?
John
**Please rate posts you find helpful**
Laide
Community Member
I did, but i got the message "entry for address/mask = 0.0.0.0/0.0.0.0 exists
Failed to add NP permit rule"
Do you have a route on your firewall for that IP address ?
Jon
Can you post teh configuraiton to have a look and let us know what code this device running.
BB
suggest to post the configuration as suggested, the routing is not configured that that designation.
BB
ciscoasa# sh interface ip brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet1/1         192.168.4.2     YES CONFIG up                    up
GigabitEthernet1/2         192.168.1.1     YES CONFIG down                  down
GigabitEthernet1/3         192.168.0.3     YES CONFIG up                    up
GigabitEthernet1/4         unassigned      YES unset  down                  down
GigabitEthernet1/5         unassigned      YES unset  administratively down down
GigabitEthernet1/6         unassigned      YES unset  administratively down down
GigabitEthernet1/7         unassigned      YES unset  administratively down down
GigabitEthernet1/8         unassigned      YES unset  administratively down down
Internal-Control1/1        127.0.1.1       YES unset  up                    up
Internal-Data1/1           unassigned      YES unset  up                    up
Internal-Data1/2           unassigned      YES unset  up                    up
Internal-Data1/3           unassigned      YES unset  up                    up
Internal-Data1/4           169.254.1.1     YES unset  up                    up
Management1/1              unassigned      YES unset  up                    up
ciscoasa#
