Command required for trouble shooting .
k_jeevanandhan
Hi ,
As I am new to Cisco , request to suggest the most matching command to trouble shoot the Cisco ASA and  FWSM  in the command line interface.
Pls  find the below questions.
  1. How can I check the traffic   hit   for a particular ip   address   in command line  interface .
   Ie   how can I check  whether a   particular ip address   traffic allowed through the firewall  or is it blocking in the firewall .  ACL   traffic is allowed by specifying   network group only . No individual host ip address   are using.
 2 . How   do I   know  the  TCP three way hand shake getting completed or not  .
Ie for a particular ip  address  how do I know TCP  sync or flag  status .I mean how do I confirm the  tcp   three way handshake is getting completed or not.
jeevanandhan
Rishabh Seth
Level 7
Level 7
>>To check how ASA will treat a particular flow you can use packet-tracer utility:
++link for packet tracer: https://supportforums.cisco.com/document/29601/troubleshooting-access-problems-using-packet-tracer
>> To check and understand tcp connection status you can use sh conn address <ip-add>
++ refer this for tcp connections: http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/113602-ptn-113602.html
hope it helps.
