Configuration mapping between Interfaces and routing definition
suwaisfa_Sec
I would ask if this configuration is right or not,
I have this list of interfaces
interface    Vlan240
    shutdown
    nameif    dmz2
    security-level    50
    ip    address    10.180.63.193    255.255.255.192    standby    10.180.63.194
interface    Vlan3
    nameif    dmz1
    security-level    70
    ip    address    10.60.3.1    255.255.255.0    standby    10.60.3.2
interface    Vlan997
    nameif    outside
    security-level    0
    ip    address    10.59.255.120    255.255.255.0    standby    10.59.255.121
interface    Vlan1506
    nameif    DCN_Router
    security-level    70
    ip    address    10.60.255.249    255.255.255.248    standby    10.60.255.250
then this is the routing
6722    route    dmz2    10.60.29.11    255.255.255.255    10.60.4.69    1
6723    route    dmz2    10.60.29.12    255.255.255.255    10.60.4.69    1
6724    route    dmz2    10.60.29.22    255.255.255.255    10.60.4.74    1
6725    route    dmz2    10.60.29.13    255.255.255.255    10.60.4.70    1
6726    route    dmz2    10.60.29.14    255.255.255.255    10.60.4.70    1
6727    route    dmz2    10.60.29.23    255.255.255.255    10.60.4.46    1
6728    route    outside    0.0.0.0    0.0.0.0    10.59.255.1    1
my Q is about the routing definition, for the last one "6728" it looks fine, as the IP@ 10.59.255.1 is part of the outside interface,
but how about the other routing definition, is it wrong, or i should somewhere else in the configuration, to check its validity?
2 Accepted Solutions
I am ont sure where these routes are installed from ? I think you can check the configuration and see if they are manually configured.
Thanks and Regards,
Vibhor Amrodia
Are the interfaces you posted above the only VLANs configured on your 5505?  If so then the 10.60.4.x network is not  even connected to your ASA and will never be used as a next hop as the ASA has no idea where the next hop is.  If this is the case, then these routes can safely be removed.
Please remember to select a correct answer and rate helpful posts
5 Replies 5
Vibhor Amrodia
This is only pointing that you default Gateway Ip is 10.59.255.1 .
Thanks and Regards,
Vibhor Amrodia
Thanks Vibhor,
does this mean those routes
are not required, and could be removed,
as 10.60.4.xxx is not part of any interface?
Thanks and Regards,
Vibhor Amrodia
HI,
any specific place in configuration I should look at?
as I couldn't find it
